Sony G90 units found locally. Trying to weigh the risk.
redfox001
Posted: Fri Jan 02, 2015 1:49 pm    Post subject:
stridsvognen wrote:
redfox001 wrote:
One of the points that I do not get when we compare CRT's is that we agree on using the MTF function, that is the modulation transfer function to see how well it can produce fine detail or sharpness.
Now sometimes people say there is a lot more to MTF than just bandwidth. I think that is true because the lenses also contribute to MTF but if I look at the definition of MTF it is a way to calculate a number that expreses the contrast between the white and the black line at high spatial frequencies. In other words if we look at the 1:1 testpattern we also take in account the 'other' parameters that make up the MTF liek the lenses and the CRT that make perfect black to white is clearly resolving better.
So what other parameters are there to make a CRT that has worse 1:1 have a better MTF?
MTF is a good meassurement, but you can get that up by put sharper tubes, peak the video chain, and improve on focus magnets.
All that dont mean you have a clean high bandwidth linear non distorted video chain.
Ill prefer a softer, tube lens and focus system with a clean linear high bandwidth video chain.
If we can get both a super sharp and clean linear high bandwidth machine that for sure is to prefer, just that nobody has ever made that one.
I guess someone someday will have to build a Marquee with LUG tubes and G90 focus yokes, HD10E lenses and a complete MP modedet video chain / electronics. And run a nice clean digital video chain with as few processors as possible.
From a theoretical point of view I think that if there is enough focus to clearly distinguish between two lines/pixels than the MTF would not improve on making the focus dot smaller.
The definition of MTF is the maximum luminance - the minimum luminance / the sum of the two.
Or is it so that a smaller dot is brighter?
haireez
Posted: Fri Jan 02, 2015 2:01 pm    Post subject:
I've seen Barco Cinemax in action & had 2 Vision 1. However, I hardly heard anyone in Singapore own a Sony G90 and if there is anyone here locally offer 2 G90 at $USD 1250, I would not hesitate to buy both even though I already got 2 Vision 1. I agree it's a no brainer as what Craigr mentioned.
2 White Vision 1
Posted: Fri Jan 02, 2015 2:21 pm    Post subject:
And the tubeface phosfor will always have some bleed at hi level, so the tighter the dot, and less bleed who spill into the dark area, the higher MTF.
But If MTF should be used as a reference meassurement ill think you need to meassure it in steps from 0-100% IRE and again the first vertical line to the last, as most CRT video chains seems to have a unstable reference level.
It wont help much on PQ if you can only hold performance on 1 spot on the tube face at a very specifik resolution and level.
So that númber can be as misleading to PQ as the contrast number on a new digital projector.
Posted: Fri Jan 02, 2015 2:34 pm    Post subject:
HogPilot wrote:
stridsvognen wrote:
Why is there none of you guys who pick up on my post, and document me wrong on some of the week/ bad points i state related to the G90.?
Because that's not how this works. No one is right until proven wrong; the burden of proof lies upon you to prove your position. I'm not a CRT guy, but your track record of grossly misinformed/biased/subjective comments about digital projectors in general (and JVC projectors) doesn't imbue me with any confidence that this situation is different. Prove me wrong Mr. Green
I would think that i have proven and documented most of what i have pointed out, with calibration files, screen shots and so on, i cant remember you do anything else than writing your opinion. Smile
redfox001
Posted: Fri Jan 02, 2015 3:16 pm    Post subject:
Ok but the 909 is also a very bright CRT I think. When I do a little boosting on the white is very bright so evenif the bandwidth is lower the details might still be there because of the brightness making for big contrast. I do not know if the Marquee is just as bright or if the G90 is. The few experiments I did with my Marquee seemed less bright in first impression but that was without proper setup.
Posted: Fri Jan 02, 2015 3:25 pm    Post subject:
Thats a different thing, more light is not the same as higher MTF, or better contrast.
The G90 is bright and sharp, i even think i posted that in my original post in this thread.
redfox001
Posted: Fri Jan 02, 2015 3:29 pm    Post subject:
Ah ok. More brightness also makes the black brighter if the bandwidth is limited.
HogPilot
Posted: Fri Jan 02, 2015 4:36 pm    Post subject:
You've done nothing of the sort, at least not with respect to your JVC. You do pass off a lot of your personal preferences and purely subjective opinions as fact in addition to making completely factually incorrect statements about it and digital proejctors in general. But there's no need to rehash all the specifics of that, I and others here have shut you down at almost every attempt to rant about digital projectors because you made some poor purchasing choices and didn't like the outcome.
I know that you know a lot about CRT setup and maintenance, but you're also very opinionated about your projectors, and you suffer from the false idea that the former makes the latter fact. Many of your statements remind me of audiophiles discussing things like which exorbitantly expensive HDMI cable results in a better sound from their "reference" systems. In other words, grounded not in fact, but personal observations that are nothing more than the result of our senses being poor absolute measuring devices.
Posted: Fri Jan 02, 2015 4:46 pm    Post subject:
Did anyone ever post a detailed gamma drift, cold to hot measurement of another JVC projector as i asked for, to confirm im mine behaved normal or was defect.? I dont remind anyone picking that up.
And lately ecrab made a very nice new pattern who is good to tell how the projectors handles different resolutions from black to white, if its linear or not.
I think redfox was the only one who had the balls to jump on that one, maybe someday if you grow up to be big girl you can also join. Wink
But to keep it relevant to this thread, lets hear about your G90 experience, and how it compares to mine. Who knows, you might be able to tell me how to set it up to work around some issues. Thumbs Up
Posted: Fri Jan 02, 2015 5:01 pm    Post subject:
Just slightly off topic here but I sometimes think of some english words that sound funny when you pronounce them. You wonder who thought of it and when you say it, it just sounds funny. Example: obsessed. It just sounds funny, doesn't it? LOL. Anybody else ever notice this?
Jeremy112
Posted: Fri Jan 02, 2015 5:04 pm    Post subject:
Rofl Laughing Great way to break up the convo mac Razz
HogPilot
Posted: Fri Jan 02, 2015 5:18 pm    Post subject:
Edit: My apologies mac, my original post was based on the incorrect assumption that your comments were directed at me when they were not.
It's a shame that what useful knowledge that Kurt has to offer is often lost in the noise of him bloviating about whatever display tech (or specific display) he's deemed doesn't meet his odd personal needs/standards.
HogPilot
Posted: Fri Jan 02, 2015 5:29 pm    Post subject:
Lol, perhaps you should have sent your JVC back for warranty work once you started unearthing all of these "problems." JVC USA would have been happy to take a look for you. Or are you too cheap to do that, which is what led you to buy a projector not warrantied in your part of the world in the first place?
The OP already made his decision, so at this point the thread is whatever we make it. Besides, I've never pretended to have any knowledge or real interest in CRT. I don't have the time or desire to keep one of those things running. I'm just here for the occasional entertainment, something you always seem to provide on queue!
Posted: Fri Jan 02, 2015 5:41 pm    Post subject:
Thank you much. Glad we could resolve this issue! Thumbs Up
Posted: Fri Jan 02, 2015 5:52 pm    Post subject:
I think "crusade" sounds even a tad funnier than "obsession". Wink
Posted: Fri Jan 02, 2015 5:57 pm    Post subject:
Yes, that is funnier. Laughing
redfox001
Posted: Fri Jan 02, 2015 5:58 pm    Post subject:
But the whole discussion of G90 and 909 and Marquee is based on dvd source material. Even if you upscale to 1080p you still have around 3 pixels with almost the same brightness. With 1080p source material we do need higher bandwidth to keep up with digital that have unnatural sharpness by the way Wink
Posted: Fri Jan 02, 2015 9:46 pm    Post subject:
redfox001 wrote:
stridsvognen wrote:
CIR Engineering wrote:
I would like to buy the projectors if they aren't located too far from me. Two G90's for less than $625 a piece is a no brainer. This thread is absurd.
...and the only person on this forum who would not consider a G90 a top reference projector is Kurt. As soon as I saw him post in this thread I was thinking "here we go again." Good lord this place has descended into royal crapulence. No wonder I have been coming here less and less.
Happy new year for you to.. Thumbs Up
I have no financial interest in how different projectors players or processors performs, but i can understand why it might not be so for all of us.
I just state what i see, your welcome to argue or comment to the speciffik post you dont like, and we can take it from there, but the outcome might not be a great G90 sales add.
It is to bad that most people underestimate Kurt especially when they are experts in the field. Think they forget that Kurt is a very close tester for Mike Parker and a lot of what he says is backup by Mike Parker with very much experience in the field. So if you read Kurt saying something you better take it serious and you do not get away with 'here we go again. I do not have to debate this because it is ridiculous because of.. what?' CRT has never before done 300HMz we better pay close attention if this does not change the best projector out there listings that where made in the days of dvd's.
If so than a Marquee that canbe bought pretty cheap with some $1000 of modifications might be a far better choice these days.
No one underestimates him, just that no one cares. Theyre over it.
Posted: Fri Jan 02, 2015 9:53 pm    Post subject:
And who really cares? Thats the source material available to home theatre users.
Since you love to back Kurt so much, maybe you can have a go, in your own words ofcourse, at explaining why a G90 is not a good machine for home theatre use?
redfox001
Posted: Fri Jan 02, 2015 10:33 pm    Post subject:
Ok I removed that but you are very sensitive to criticism on you projectors. When I say something about your Nec you go completely nuts. Now Kurt is saying something about a G90 and you feel offended. I do not get that. He said a lot about 909 and I learned from his knowledge. Some things I just let go and I still enjoy the 909 but it is the hobby to search for something even better.
Page 4 of 9
