Barco Cine 8
Goto page Previous  1, 2, 3 ... 23, 24, 25, 26, 27  Next
dentree
TV/Projector: BARCO GRAPHICS 808 BARCO GRAPHICS 801
Posted: Wed Jan 28, 2015 1:05 pm    Post subject: Barco Cine 8
Hi Casey.
Yes I did see the ad for the Cine 7, but did not imagine that would be considered as an upgrade from my point of view, but I was wondering about the Quad, EHT and splitter, but did not know whether they would be of any use to me, also with regard to the HD145 (I assume that the Cine7 is a 7" machine), in which case the lenses would fit that machine without any mods as the lens bases would be correspondingly smaller to suit the 7" tubes (yes/no?)
Will have another look at it although I think I might have emptied the coffers somewhat with the Canadian purchase, but It was absolutely essential to get back up and running again,
I will check in on you later
Regards
Trev
PS: hope you are begining to feel better as the days pass
cosaw
Posted: Wed Jan 28, 2015 2:13 pm    Post subject:
Quad, splitter and colour filtered HD145 if you want to upgrade.
Get the lenses for the upgrade bit right? I presume the Cine 8 is filtered already - is that at the lenses?
Yes Trevor you'll need adapter plates to fit the HD-145s to the Cine 8. I'm thinking of doing the same here to my Graphics 808. I'd make my own plates from plastic or mdf.
Simon
Posted: Thu Jan 29, 2015 12:43 am    Post subject:
Trev im not sure what you mean about the Cine 7 mate?? Its an ES focusing entry level set, not sure what use itll be to you.
Posted: Thu Jan 29, 2015 12:47 am    Post subject: Re: Barco Cine 8
Hulio wrote:
dentree wrote:
this Laptop is 64 bit,
Unzipped the files, but will not install, I think this must be 32 bit, which I imagine is the same as the old one I had
Trev, unzip the soft to your desired map and try to install it with diagnostic startup. Click start and type msconfig in the search box, than enter. On the general tab, select diagnostic start up and restart. Try than to install and don't forget to select normal start up after installation.
Oh yeah, another tip : a guy from Point Cook (Seabrook) is selling his non working Cine 7 for 100 AUD on the bay AU.
Ok, NOW i see where the Cine 7 came in!!
$100 AUD for a non working Cine 7 is f***en highway robbery, you can buy a working XG for $150 here when they come up.
dentree
Posted: Thu Jan 29, 2015 2:30 am    Post subject:
Sorry Casey It was Hulio who sent me that post, for some reason I thought it was you, please rewind/delete/erase or whatever............ more to the point, recuperation going well?
Regards
Trev
Posted: Thu Jan 29, 2015 4:20 am    Post subject:
Getting there thanks mate yeah, still a bit of trouble getting around, and still abit swollen in the stomach which is quite uncomfortable at times, but im getting better.
Hulio
Posted: Thu Jan 29, 2015 8:28 am    Post subject: Re: Barco Cine 8
[/quote]
Yepp, that was me...
Ofcourse Cine 7 is a 7" ES machine. I was only saying quad, splitter and lenses for 100 bucks could be right. I remember Trev talking about changing his non colour filtered HD8's with colour filtered HD145's. It was not about downgrading to Cine 7, size do matters guys.... Very Happy
@ Trev
I don't recall if you already mensioned the part nr. of the splitter in the Cine 8. It is R762718 right ? Because if is the old style R7617447, the quads will keep oscillating and get warm.
Posted: Thu Jan 29, 2015 8:53 am    Post subject:
Yeah mate i knew you meant all those items, but he allready has a good set of HD-145s there, and a non working Cine 7 may not have a working HV section Wink
The fact is though, $100 is a rort for a Cine 7 here that isnt perfect, its just a fact. I know and respect what youre saying Hulio, but it's the principle!! $100 for a dead Barco to 'maybe' get a quad and splitter, VS a few more bucks and get a much better CRT in working order, or buy known good parts.
If the Cine 7 was $20, absolutely, if it was $50, maybe, if we knew the owner and it could be vouched for, even better, if Trevor was a retro gamer that could sure make good use out of a 7" ES focusing set for some 15.7kHz RGB action, possibly, but $100 for another boat anchor, and Trevor doesnt even have a boat!!
dentree
Posted: Thu Jan 29, 2015 9:11 am    Post subject:
Ok Hulio, I now understand what you were getting at, Firstly I already have a set of HD 145 color corrected lenses, it's the adapter plate problem I have to deal with.
the splitter I did change with the one out of the BG 808 to test it against the CINE 8, it seemed OK in the CINE 8 so I have left it in there, but maybe if the numbers do not add up I should possibly change it back to the original, I suppose that because there seems to be a selection of non original parts/boards in this thing, that even the one that I took out might not be original either.
At this point I do not know the part numbers on either one, I will pull them out and have a look, but because of a previous post it was mentioned that all the splitters were pretty much compatible with all these projectors, but now after reading what you have said I shall check
As far as the CINE 7 goes I did not know whether the Quad would have been of any use to me, and obviously I have no idea as to the usefulness of any other parts in the CINE 7, but will keep you informed as to the pedigree of the splitters.
Thanks Hulio
Regards
Trev
dentree
Posted: Thu Jan 29, 2015 9:27 am    Post subject:
Hulio,
In fact the splitter that I took out of the CINE 8 has what I think is the old number which reads: 7617447 / 5 / 9441
That is the complete line of numbers,There is NO "R" prefix
So now I am wondering what number I might find on the Splitter (currently installed) in the CINE 8 (Ex BG 808) I cannot imagine that it will in any way correspond to the numbers you have mentioned, that being the case then it would suggest that I have a further possible issue to deal with??
dentree
Posted: Thu Jan 29, 2015 9:39 am    Post subject: Barco Cine 8
A boat???.................................I don't even have a trailer, or a towbar !!!!
But there is a Catamaran in the docks in Melbourne which I think will be going very,very cheap Could be a good buy there, as far as I can see the only thing wrong with it is the fact that 3 days ago it burnt to the waterline...........but it is still afloat, what do ya reckon Casey..........................should I dump the projector idea and become a boat owner ???!!!!!
Cheap boat
 Filesize:  46.1 KB
 Viewed:  5434 Time(s)
Hulio
Posted: Thu Jan 29, 2015 10:45 am    Post subject:
Forget Barco's, get that boat ( now the spanish forum members are confuse as hell, barco means boat in spanish ).
I take a long holiday, we pick up Case and fix that boat. I'll love to see the Gold Coast again...
About the splitter : 7617447 is a NO GO with the new style quad, EHT and chassis. That's why your second quad got smoked too.
Posted: Thu Jan 29, 2015 11:36 am    Post subject:
Sounds like a plan Hulio, although ive got 5 and a bit weeks to go on a 5kg lift limit!!
dentree
Posted: Thu Jan 29, 2015 12:13 pm    Post subject:
Ok Hulio, I have the Quad numbered R762717 coming from Canada,also another EHT number R7627165
What Splitter do I need now so the F*****g thing does not end up looking like that boat !!
dentree
What Splitter do I need now so the F*****g thing does not end up looking like that that boat !!
dentree
Posted: Thu Jan 29, 2015 12:14 pm    Post subject:
Hulio
No problem Case, time to finaly use those ceiling mounts with pulley system Very Happy
Posted: Thu Jan 29, 2015 9:23 pm    Post subject:
The CM100? I have that very mount Wink
Trevor needs to know which splitter number to use!
Trevor, are both those splitters you have there of the same number?
Hulio
Posted: Thu Jan 29, 2015 9:44 pm    Post subject:
Sorry, just back from work.
Well, you need the 762718 splitter.
dentree
Posted: Fri Jan 30, 2015 12:25 am    Post subject:
I have 2 splitters one each from the Cine 8 and one from the BG 808 the id',s and original locations are as follows:
CINE 8 splitter no: 7617447/5
BG 808 splitter no: 7617447/2
Original Quad installation.
CINE 8 Quad no: R 762717 (Burned as in posts on page 2)
BG 808 Quad no: R 7622091 (metallic burning smell--no visible damage) when installed in CINE 8
with Splitter no:7617447/2
Original burnout combination numbers in Cine 8 Quad=R762717 + Splitter 7617447/5
Original combination numbers in BG 808 Quad =R7622091 + splitter 7617447/2 (these 2 worked fine in BG 808)
Page 24 of 27
