BG808 -> 120MHz mod
Posted: Fri Dec 05, 2014 4:25 pm    Post subject: BG808 -> 120MHz mod
I have a buddy, who has a BG808 non -s fitted with LC tubes from a retrographics, he is running on stock RGB boards. He wants to get rid of the common streaking problem. He has the "120MHz" neckboards and all the matching input and driver boards from the retrographics too, the only thing he doesn't have the firmware, so he can't run them in the machine, right now... Can someone selp us out with a firmware dump matching to those retro boards?
Posted: Fri Dec 05, 2014 9:37 pm    Post subject:
Cant just swap the whole system board out?
Posted: Fri Dec 05, 2014 9:40 pm    Post subject:
He is missing that board actualy...
Posted: Fri Dec 05, 2014 11:22 pm    Post subject:
Oh....
Posted: Fri Dec 05, 2014 11:23 pm    Post subject:
Oh....
Oh....
Oh....
Posted: Fri Dec 05, 2014 11:25 pm    Post subject:
Dont know how that happened...
Posted: Sat Dec 06, 2014 12:19 am    Post subject: Re: BG808 -> 120MHz mod
What happens when he attempts to start the projector.
Decibel
Posted: Sat Dec 06, 2014 7:49 am    Post subject:
I have eproms with BG808s or Cine 8 firmware.
Domenico (Barco fan!)
Posted: Sat Dec 06, 2014 8:24 am    Post subject: Re: BG808 -> 120MHz mod
Generally it works, but throws I2C errors on screen, guess one of the boards is not recognised
Posted: Sat Dec 06, 2014 8:43 am    Post subject:
Some firmwares need newer convergence driver board, right? This BG808 is a 1995 vintage.
Do you have the content of those firmwares or just in phisical way? We have no problem with programming the EPROM.
Decibel
Posted: Sat Dec 06, 2014 9:11 am    Post subject:
With the older convergence driver board, the projector will work the same but when you go to act on the incompatible adjustments the projector return an IC error.
I think that your friend has to change also the two boards rgb input and driver.
Posted: Sat Dec 06, 2014 10:25 am    Post subject: Re: BG808 -> 120MHz mod
I2C error is from convergence board. Make sure the convergence tray connectors are clean and that there are no bent pins.
Posted: Sat Dec 06, 2014 10:34 am    Post subject: Re: BG808 -> 120MHz mod
But he only gets these errors if he puts in the 120MHz neckboard with its matching RGB switcher and driver boards. Only swapping the neckboards introducing too much ringig, but no errors eventually. The machine works fine with the stock boards too. However we are not sure if the boards from the retographics are all flawlwess, but except from the random errors it throws they seems to be working otherwise.
Posted: Sat Dec 06, 2014 10:48 am    Post subject: Re: BG808 -> 120MHz mod
What RWI chip and what Firmware chip does it have?
Posted: Sun Dec 07, 2014 12:18 pm    Post subject: Re: BG808 -> 120MHz mod
CTRL V6.20
RWI V5.06
Posted: Sun Dec 07, 2014 12:35 pm    Post subject:
Also a picture of the actual board:
BG808 control board
Posted: Mon Dec 08, 2014 4:41 am    Post subject: Re: BG808 -> 120MHz mod
gjaky wrote:
CTRL V6.20
RWI V5.06
Thats very old Firmware and RWI. The latest BG808s firmware is 7.61 and RWI is 5.10. I would suggest 7.61 Firmware and at least 5.09 RWI or Decibel has Cine 8 Firmware. No matter which of the two options you choose you may need more than one control board as not all control boards work with the later chips even though they have the same part number. I have a box full of control boards and had to go through several before I found one that would work correctly. If you find that the board won't work try an older RWI chip with what ever Firmware chip you use but not too old a couple of versions different doesn't seem to matter but it may make the board work.
Posted: Mon Dec 08, 2014 7:47 am    Post subject: Re: BG808 -> 120MHz mod
km987654 wrote:
gjaky wrote:
CTRL V6.20
RWI V5.06
He has about three spare control boards, all of them have an even older firmware and RWI though.
