Focus G2 Block Barco 808s
barco_75
Posted: Wed Nov 12, 2014 3:41 am    Post subject: Focus G2 Block Barco 808s
Hi, can some one tell me what the correct wiring is for the Red, Green, and Blue focus voltage wires which are hooked up to the focus block. Does the wiring match the order of the trim pots behind the focus block? I've taken a couple of photos of possible options. The wires are color coded.
Option 1 matches the order of the trimpots
Option 2 matches the photo of the board shown on Curts 808s layout page (under setup tips & manuals).
I'm thinking it is option 1 but Curt's photo shows differently. It could be the wires in his photo are not properly color coded.
If I get it wrong will I blow anything up?
Option 2_match layout photo
 Filesize:  73.46 KB
 Viewed:  5789 Time(s)
Option 1_match trimpot order
 Filesize:  64.91 KB
Posted: Wed Nov 12, 2014 6:50 am    Post subject:
I believe you don't need to connect those so if you want to connect them it shouldn't matter which order.
barclay66
Posted: Wed Nov 12, 2014 7:50 am    Post subject:
Correct!
The service manual shows the input connector (cable arriving from Quadrupler) connected only. This sealed pack contains resistors used as voltage dividers and on the BG808 a portion of the HV from the Quadrupler is used as G2 voltage source. On older ES focused models a similar voltage divider produces the focus voltages too. As the BG808 is EM focused it won't need any focus voltages. Strange enough that Your neck boards have focus cables at all...
Regards,
barclay66
Decibel
Posted: Wed Nov 12, 2014 8:01 am    Post subject:
BG808s have Sony tubes matching R762721 RGB amps, that have focus wires.
Domenico (Barco fan!)
Posted: Wed Nov 12, 2014 8:05 am    Post subject:
They sure do have the red focus wire but its not necessary. I have found no practical reason for Barco to include this wire. perhaps someone else has.
Decibel
Posted: Wed Nov 12, 2014 8:33 am    Post subject:
Yes.
The owners have two options.
1) Cut the wires
2) Put the wires somewhere
Laughing Laughing Laughing Laughing
cosaw
Posted: Wed Nov 12, 2014 10:19 am    Post subject:
I think I've misunderstood all this. All machines with Panasonic tubes don't have the focus voltage wires - I'm correct on that, yes? barco_75 you've put Sony tubes in your 808?
So are people saying that even the Graphics 808s with the Sony tubes and the focus wires doesn't need the wires connecting to the focus block in order for the projector to work?
Simon
redfox001
Posted: Wed Nov 12, 2014 10:46 am    Post subject:
Do connect the wire from the quadrupler if you let that one hang it will spark. Doesn't matter to what pin. I worked with a quadrupler from a 808 in a cine 9 and let that wire in a piece of wood but later I also connected this block and the whole starting noise is less and seems faster. And I had sparks once without. Oh and it that case also let the black ruber on the pins if you open the crt while operating you don't want 1000V.
I think the order is completely irrelevant as it only splits a voltage.
barco_75
Posted: Wed Nov 12, 2014 2:00 pm    Post subject:
I converted my BG808 to a BG808S. I now have sony tubes and the 120 mhz amps. Each RGB amp has a red wire which is to be hooked up to the focus block. Per Curts 808 description:
"In BG 808s sets that use Sony tubes, this block also feeds the 5Kv focus voltage to the tubes (not used in the other 808 models.)"
One wire does go to the quadrupler and that is not in question (it's the wire on the left in my photos).
I think it is important to have the wire hooked up...the order I'm not sure. Why would Barco add the wire if it had no reason to?. Also, I think the order is important otherwise they would not have color coded the wires.
Here are a few references I found:
http://www.curtpalme.com/Barco808_Layout1.shtm
http://www.curtpalme.com/Barco808_Layout7.shtm
I would go by Curt photo is layout 1, but I can't be certain he hasn't switched the RGB amps (for instance from Blue to Red). I know in mine, I actually have the color coded RGB amps switched. Does anyone have a 808s that they can check?
cosaw
Posted: Wed Nov 12, 2014 3:40 pm    Post subject:
I agree with everything you said.
Don't want to confuse the matter so feel free to ignore this: I have a Barco Data 500 and the Blue wire is at the back of the focus block while the red wire is at the front of the focus block.
I'm sure Curt will know the answer to this when he sees the thread.
barco_75
Posted: Wed Nov 12, 2014 4:36 pm    Post subject:
If I understand correctly it matches my option 1 photo (see titles, its the second photo)? Is the focus block the same part #? I don't know if the data 500 is the same.... Anyone with an 808s?
cosaw
Posted: Wed Nov 12, 2014 7:22 pm    Post subject:
Yes you are right. Wait for a definitive answer though cos the data 500 is quite a different machine I'm sure. I've just acquired a Graphics 808s but the Sony tubes have been replaced by Panasonic ones so I can't help there I'm afraid.
redfox001
Posted: Wed Nov 12, 2014 7:30 pm    Post subject:
The splitter that is in the CRT part also has three wires going out and it does not matter what order you use as the splitter does nothing with the voltage but make three connections.
The splitter in the back you are talking about can not split different voltages for different tubes. There is nothing in it but a lot of siliconkit to not get sparks.
Posted: Wed Nov 12, 2014 11:17 pm    Post subject:
You are mixing ES and EM tube types both supplied by Sony. The 808s uses EM tubes and these do not require the red focus wire to be connected. You can of course connect it if you wish and the order on the focus block is not relevant. On the other hand ES focusing tubes MUST have the red focus wire connected as this is the only method for focus on these tubes and the order of connection does matter on the focus block for ES tubes. I believe the 500 is an ES set.
All of this is different to the much larger HT wire which must be connected in all cases.
cosaw
Posted: Thu Nov 13, 2014 10:48 am    Post subject:
Ah I see. A very interesting point and it would seem like where the difference lies. So we can assume then that these Sony tubes have been used in Electrostatic Focus projectors. Anybody know what models?
Ok so I'm guessing the G2/Diagnostic board is different between the Graphics 808 and the Graphics 808s and the outputs on the focus block are not live for the 808s?
Yes it is.
barco_75
Posted: Thu Nov 13, 2014 2:01 pm    Post subject:
So I'm a bit confused. It seems the consensus with those responding to this post state the wire has no use. However, Curt states it
"In "BG 808s sets that use Sony tubes, this block also feeds the 5Kv focus voltage to the tubes (not used in the other 808 models.)"
The above thoughts seem to contradict each other. Regardless it seems that it can't hurt to hook the wires up but I'm not sure why the order would be important for the ES set and not the EM set if the focus block has the same function. Does anyone have a Barco reference (schematic or the like) they could share which confirms some of the conflicting information.
cosaw
Posted: Thu Nov 13, 2014 3:56 pm    Post subject:
I can't argue with your logic at all barco_75, that's why I agreed with you further up in the post.
If I knew the focus block was just a voltage divider then I'd say the order didn't matter anyway - but I don't know that.
I think Curt is holding out on us just to see where this thread goes. Smile Come on Curt you've had your fun - what's the definitive answer. Wink Wink
Posted: Thu Nov 13, 2014 10:04 pm    Post subject:
The order is Important on an ES set as this is the only focus method on those sets and there is a separate focus control for each colour on the focus block. It's irrelevant on an EM set as there are no individual focus controls on the focus block. I would add that ES focus is a mechanical process and EM electronic.
The other 808 models are all EM focus and these use a different brand tube that does not have the red focus wire installed in the Set. All the 808 series including BG808s use EM tubes so are focused using external coils on the tube neck.
cosaw
Posted: Fri Nov 14, 2014 10:20 am    Post subject:
Thanks for elucidating km987654. It makes sense now - each wire must correspond to each potentiometer on the other side of the block.
To clear up all confusion. What does the term Electrostatic actually refer to then. I understand where the Electromagnetic control is on the tube. However at one point you say there is a control for focus on the focus block - for Electrostatic machines. But then you say "ES focus is a mechanical process". Now both types of sets have the astigmatism magnets of course - but we're not refering to those in any way, are we?
I'm not trying to be pedantic I just literally don't understand.
How is the focus potentiometer on the G2 board a mechanical process?
What does the term Electrostatic actually refer to? (I can see the astigmatism magnets as Electrostatic but, as said, we know that both types of machine have those.)
Hope you can clear this up and then we'll have finally gotten to the bottom of this. Thanks.
Posted: Fri Nov 14, 2014 10:36 am    Post subject:
Electrostatic focus is carried out by a grid inside the tube. On the focus block of an ES set there is a potentiometer for each color and you adjust those making it a mechanical adjustment. ES tubes loose there ability to focus as hours go up. EM tubes are less likely to loose focus.
