Bad new tube. Anyone ever seen this.?
Posted: Sat Feb 28, 2015 5:43 pm    Post subject:
That's possible, I never saw the old E'home packaging as I never ordered tubes from them. I did send a number of tubes throughout the US in factory packaging only, not double boxed, and all arrived intact, then I switched to double boxing with additional bubble wrap between the factory box and the outside box.
Kurt does have pictures of the tubes the way I got them when they first came in, and I also send him pictures of the tubes, front and back. Not sure if I ever took pictures of the double boxing, but I thought I did send them to him before shipping. I have more of those boxes here, so taking those pictures isn't an issue.
Posted: Sat Feb 28, 2015 6:14 pm    Post subject:
I never got pics of the shipped tubes.
But i asked for pics of the 3th set. And got it. That set i was never shipped.
Posted: Sat Feb 28, 2015 6:22 pm    Post subject:
Well the pictures are the same, whether I sent them today or a year ago. Same tubes, same packing, same shipment of tubes, how they got to me in the first place.
I can't remember whether I sent you pictures of the tube shipments back in 2014, but you're right, I did in January of 2015.
Posted: Sun Mar 01, 2015 8:30 am    Post subject:
Here is some pics of the new replacement red.
 Filesize:  190.25 KB
 Viewed:  4281 Time(s)
 Filesize:  212.59 KB
 Viewed:  4282 Time(s)
 Filesize:  229.95 KB
 Filesize:  216 KB
 Viewed:  4283 Time(s)
 Filesize:  140.42 KB
redfox001
Posted: Sun Mar 01, 2015 11:22 am    Post subject:
Is the bellow leaking? Shocked
Posted: Sun Mar 01, 2015 4:08 pm    Post subject:
Kurt, I'm not sure what you're trying to do here, but every tube I sent to you and everyone else was new in the box. NONE of the boxes I sent out had red packing tape on it, let alone corrosion on the screws, or wear on the plastic housing. I've also used about 40 or so tubes myself, and all were in perfect shape, and not what you've posted here. It's also clear that you've got a number of Marquee sets and tubes, so perhaps you're posting pictures of an old tube with Marquee packing from one of my boxes, I'm not sure.
If anyone here reads all of your posts above, you're all over the map and have contradicted yourself a number of times in this thread. Had a tube showed up that I sent you back in October that was leaking glycol or appeared used, I'm sure you would have screamed at me via email. Every tube I sent out or installed in sets myself was in the clear plastic bag and corrosion free as per the pictures below which are ones from random tubes out of the same lot, and these are pictures that I sent you last month.
Oh, it also looks like there are styrofoam bits around the black ring of the C element. While the tubes that I sent out are packed in the foam that you've posted above, that foam does not crumble and leave little bits of styrofoam around the black ring. Also, the tubes I sent out have the C element covered with a round plastic disc to protect it, taped in place, so nothing can touch it.
At this point you have no credibility with me whatsoever.
 Filesize:  236.68 KB
 Viewed:  4214 Time(s)
 Filesize:  239.31 KB
 Filesize:  217.61 KB
Posted: Sun Mar 01, 2015 4:26 pm    Post subject:
The red tape is the tape the postal service use, this red one is the last red i got, wich i made the last claim about, the one with the bend rear cover i showed here.
Are you saying that this is not the tube you sent me.?
Here is a pic from the post office where i opened it and left it just before new year.
If you like ill be happy to take a pic of the tube lable serial nr. I have 5 red tubes, do you like to see a pic of them all. ?
You can see a bit of the red counter on the pic.
Post the pic of the last red tube you sent me instead of another green one.. Im sure you have pics of the tube with serial nr, as documentation for a insurance claim.
 Filesize:  461.46 KB
 Viewed:  4205 Time(s)
 Filesize:  483.48 KB
 Filesize:  434.81 KB
Posted: Sun Mar 01, 2015 4:59 pm    Post subject:
I have no idea whether you are posting pix of the tubes I sent you or not. What I am saying is that if there ever was any problem with anything I've ever sent you, you emailed me right away. Heck, even the last set of tubes that I didn't send, but sent you pictures of, you criticized, and in the end didn't take them. You now want me to believe that I sent you a tube where the box had water damage, the tube screws were corroded, the outside case shows signs of wear, and you have said NOTHING for the last 3 months since you've taken possession? You're right, I don't believe that.
It's also interesting that considering you've bought a number of tubes from me in the last year, and I'm sure from other people, you accept a box that shows significant signs of damage on the outside, it's been opened by customs, yet you don't refuse it at the post office, and don't file an insurance claim? If someone sent me a tube box in that condition, new, used or otherwise, I would have refused it, or opened it in front of a post office employee and checked for damage on the spot.
The outside boxes I use for double boxing are brand new. Short of folding the boxes and putting a shipping label on them, they never show external signs of damage.
I sent you that replacement red tube on Nov 10, 2014, as per my shipping record, and you can even read that on the mailing label in your picture, yet somehow this is all my fault? I repeat, short of shipping the box in a lead or wooden case, there's no way any sort of normal packing would have protected that tube, given the shipping damage you show above.
Posted: Sun Mar 01, 2015 5:13 pm    Post subject:
Hang on a sec. im picturing all my red tubes, going to post the bell lable, and you can tell wich ones you sent me.
I mailed the postal service insurance department to get the pics they made in this case, let see what they come up with, let me know what kind pics you like so that we can find out if the tubes was swapped somewhere in the shipping.
If the pictured red tube is not from you, then i better call the police and report the one you sent me stolen.
Please post the serial nr, and pic of the 3 red you have sent me, so everybody can see, and ill also be able to use it for the claim.
I see i have 7 reds, 3 is from you, one is a LUG. In 14 days ill have 7 set of tubes more, if you like i can picture those show they are Panasonic tubes.. I have nothing to hide.. Im just picturing what i got, i also have a hard time understand how you were able to ship a tube like that out as new, a bit like how the G90 got all the dirt and scratches on the back of the lenses, and the side cover with the serial nr changed, all happening while it was in the hands of the shipping company, as it was not like that wen it left your place.
Posted: Sun Mar 01, 2015 5:15 pm    Post subject:
I don't have any pictures here of the tubes I sent you last year, sorry. I'm sure it's far too late to file a claim now, here you need to file within 2 weeks I believe, not 2 1/2 months later.
Also FWIW, I scrapped a bunch of Marquee tubes from my stock that were used and worn. I left the LC housings with the bad tubes outside in the rain for 3 days. When I picked them up from being face down, all screws were heavily oxidized.
I did take the replacement red tube out of the box before shipping to make absolutely sure it was perfect, and IF there was any corrosion on the screws, and IF there was damage to the box, and IF the back of the metal housing was damaged, I would have seen it here, and not sent the tube. As I said, no other tubes out of the 80+ that I have personally used and sold showed signs of corrosion. Tim and Nashou also got 12 tubes each (if I remember correctly), and I'm sure they will also verify that none of their tubes had corrosion on them.
Posted: Sun Mar 01, 2015 5:19 pm    Post subject:
Curt, lets do some drop test of your packing, and ill spend some time find some alternative filling, bit like Tim wrote, and see how the drop test come out with some small changes in packing.
Lets keep this thread simple and easy to read, 1 thing at a time.
Let finish the red tube first, find out where it came from, if its not the one you shipped.
Posted: Sun Mar 01, 2015 5:23 pm    Post subject:
As I said a page ago, I'm done here. You didn't file a claim with the post office as you should have. I'll monitor this thread to see how else you want to bash me, and to see if anyone here agrees with you. I'm not defending what I sent you, I have no need to. I know what I sent out, as do many other customers that I've dealt with over the years. I know there's no way I can make you happy at this point, and frankly I'm OK with that. I've given you no less customer service than any other client, and no one seems to disagree with me.
It's your inaction to file a claim that has caused your problems, and you want me to pay for it.
Posted: Sun Mar 01, 2015 5:25 pm    Post subject:
Curt.. This is also the 1st one looking like that.. What proof is it that no one else got a tube like that.?
Lets focus on this one, get it documented / proved. As i say i asked the postal service for the pics they made of this one.
The tube was left at the post office, for the postal service to inspect, so a claim is made 29th December.
I just got it delivered this week, for inspection in agreement with the postal service.
Did i not send those pics from the post office to your mail at the time.?
Posted: Sun Mar 01, 2015 5:28 pm    Post subject:
OK, so now you have made a claim? This is new, you've added yet another version of the story. And the tube sat at the post office now for how long?
Great, you DO have a claim in! Get it paid out, as they well should, then you get your money back, and you can then buy another tube. Not from me though, you'll need to find them somewhere else. I am happy to assist if you need any paperwork regarding the tube, and the pictures that I've already sent you the way the other tubes are packed should be sufficient as proof how the tube condition was before I sent it.
Posted: Sun Mar 01, 2015 5:32 pm    Post subject:
Ill tell you 1 more time, that this tube was left at the post office for a inspection 29th December, and i got it back this week.
There was filed a claim at the same time.
I requested the pics the postal service have made in this case. Your welcome to contact USPS to confirm the case, i dont like to be called a lier.
So ill keep this going until you accept the proofs.
Posted: Sun Mar 01, 2015 5:34 pm    Post subject:
Sent: December-30-14 5:23 AM
To: Curt Palme
Subject: RE: Tubes.
Heppy new year.
I just went to the post office to pick up the red tube today, after a lot of mess with the customs service.
The box had taken a hard corner landing who had softened both the outer and inner box, and bend the neckboard cover totaly.
I inspected the tube face, and noticed a few black marks, was not able to see if it was on the inside or outside of the tube face, so i left the box at the post office for them to handle insurance claim and return shipping.
I noticed that the inner box looked like it has been wet at some time, and that some of the black screws were rusty, im not sure if they will comment on that when they have to evaluate if the packing is sufficiant.
After newyear we have to find a alternative shipping method to get the last tubes over here, the USPS/ Danish postal service simply wont work.
All the problems started this summer, all the tubes i had before that never had any issues, so something has changed.
Best regards.
Posted: Sun Mar 01, 2015 5:39 pm    Post subject:
Anyone who like the full email dialog is welcome to send me a PM with a mail address, and ill forward it.
Posted: Sun Mar 01, 2015 5:43 pm    Post subject:
I think the bottom line here, as I've already explained to Kurt in two other threads, is that his problems arise from his obtuse and dickish personality. Kurt has such a refined sense of self entitlement and self value that he actually believes he is deserving of special treatment over everyone else. Kurt has clearly exemplified this on the forums here regarding myself and now also Curt.
Kurt has proven to be delusional and a real pain in the ass to almost every professional he comes in contact with. Curt and I have talked about the requests (demands) that Kurt made on Curt for some of his orders, and I have to say that they are ridiculous.
In that vein, it's surprising to me how notorious Kurt is in the video industry as a whole, not to mention with hardware manufacturers and retailers. And that said, nobody important who works in the video industry that has had prolonged contact with Kurt likes or respects his positions or opinions. Unfortunately, most are too polite, kind, and frankly professional to say anything in public. In my case, I just don't care anymore and I am done humoring Kurt in any situation. Kurt has slandered my name on these forums and is now doing the same to Curt. I don't buy any of the bull that Kurt is serving and I personally think he should be banned from the forums here. His primary accomplishment is to perpetuate his erroneous findings and spread miss information.
Kurt, nobody likes or respects you in the video industry. You are just a dick who is full of himself and I don't feel bad for you at all.
Posted: Sun Mar 01, 2015 5:48 pm    Post subject:
Craig i have invited you to a G90/ Marquee competition, in USA, with a prize to the winner.. Just to get a end to your bitching.
Im still waiting for your reply, the outcome should be you winning , leaving with the suggested 5000$ deposite, and all the gear i used for the setup. And you holding the right to put me into the mud every time i show up.
The price should be well worth your trouble, If not mention how much you would like to gamble.
Posted: Sun Mar 01, 2015 5:51 pm    Post subject:
To: Curt Palme
Subject: RE: Tubes.
Heppy new year.
Best regards.
Page 3 of 6
