Focusing CRT tubes, how to move the dials? (Ampro 2600)
Goto page 1, 2, 3  Next
veelangs
Posted: Fri Oct 24, 2014 10:10 pm    Post subject: Focusing CRT tubes, how to move the dials? (Ampro 2600)
So did some searching and I found the two adjustment knobs per tube but how am I supposed to move them? They're screwed in pretty tight, I don't want to break anything so I figured I'd ask before I do anything
also, i haven't actually programmed the convergence yet (still waiting for a bnc cable to come in) but my red tube is still off. Is that normal? I'll be able to actually connect it all together tomorrow when I have my bnc cable and can load a test video
Posted: Sat Oct 25, 2014 1:08 am    Post subject: Re: Focusing CRT tubes, how to move the dials? (Ampro 2600)
Those knobs can get pretty tight. I am assuming you mean the 2 larger knobs on the top. Somehow you will have to get them loose to adjust the focus. Someone must of really cranked them down before. Try your best I guess and hopefully they won't break off. I have never broke one yet and I have had some really tight.
veelangs
Posted: Sat Oct 25, 2014 2:04 am    Post subject:
thanks! I finally got the suckers loose
but I've run into a new snag (of course lol) I have to do the lens positioning and can't figure out where the lens position hex screws are
are they the two hex screws on either side of the red tube?
I know i'm like live posting my set up, but damn this is a lot more diffcult than I thought.
Also, I have some keystoning of the images (i'm assuming because of th angle) is there a way to correct that later?
Posted: Sat Oct 25, 2014 2:37 am    Post subject:
Which remote do you have? The rectangle one or the L shaped one?
veelangs
Posted: Sat Oct 25, 2014 2:46 am    Post subject:
the L shape.
I'm onto the pin cushion/keystoning step.
I'm not 100% satisfied with my focusing, but now that I've done it once it's not as daunting to do it again
Posted: Sat Oct 25, 2014 2:48 am    Post subject:
veelangs wrote:
the L shape.
You'll find each time you do it it will be allot of back and forth. I usually do it 3 times, each time.
Posted: Sat Oct 25, 2014 2:54 am    Post subject:
For master keystone, registration must be off. Select code then 55 and see if it says registration on or off. If it says on then do code then 55 again until it says registration off. Then for master key adjust, press green, static and key and then use the left and right arrows to adjust. For pin you would select green, static and pin and then use the left and right arrows to adjust.
If you are unable to get both sides equally straight there is an individual key adjustment for just left or right. But see how you make out with master key first. Same goes for pin.
veelangs
Posted: Sat Oct 25, 2014 3:09 am    Post subject:
thanks guys so much! I actually have the keystone and pincushion right where I want it. It was a pita but hey it worked!
I'm just going through all the fine edging things that the help menu has. I actually had the projector too far back so when i pushed it forward a bit, all the fine touches were all outta sync haha. Oh CRT :p
I don't feel like focusing the thing again tonight, I'll double check it with some ref images tomorrow
Posted: Sat Oct 25, 2014 6:02 am    Post subject:
Don't forget to measure the distance between the red lens and the blue lens to the screen and make sure they are equal
AND do the mechanical lens tow in before going to the electronics for alignment
veelangs
Posted: Sat Oct 25, 2014 5:57 pm    Post subject:
ok so a couple questions
a) how do i measure that distance? aren't they going to be the same
b) what's mechanical lens tow in?
sorry I did a search and is that like mechanically focusing the lenses?
EDIT: got the red tube back on using the codes
veelangs
Posted: Sat Oct 25, 2014 5:58 pm    Post subject:
Also, I just have my computer connected directly to the projo
should I even bother with the dream vision scaler? Or is it not worth it?
veelangs
Posted: Sat Oct 25, 2014 6:54 pm    Post subject:
redundant
veelangs
Posted: Sat Oct 25, 2014 7:10 pm    Post subject:
apparently you can turn CRT tubes on and off :p
veelangs
Posted: Sat Oct 25, 2014 8:00 pm    Post subject:
CRT time: 106:22:55
is that a lot?
veelangs
Posted: Sun Oct 26, 2014 12:25 am    Post subject:
so it's a nice bright and sharp 720p image
but the edges are definitely out of focus. basically I'm focused in the center and out of focus on the top/bottom.
this has to be a pretty common complaint I'd assume, but it's really really annoying haha
How do you guys get so good at getting everything focused?!
Posted: Sun Oct 26, 2014 2:05 am    Post subject:
There are multiple focus adjustments of different types. Have you redone the focus with the internal help/setup menu or install manual?
You also need to be sure you have the image centered on the tube face and properly pivot the outer tubes or you may have trouble adjusting the edge focus. Astig also needs to be properly set to achieve the best possible overall focus.
Posted: Sun Oct 26, 2014 4:16 am    Post subject:
Have you performed a proper mechanical setup as Mac says. This would include lens flapping adjustments. As I understand the Ampro lens flapping because its the lenses that move there is a spot either at the top or bottom of the image that doesn't quite focus but it doesn't like your anywhere near that yet.
veelangs
Posted: Sun Oct 26, 2014 6:08 am    Post subject:
i used the help guide to focusit but like i only got so good.
my biggest problem now that i think about it is that the image is flipped, so the unit is upside down and all tne adjustments are on top (obviously because ceiling mount)
i doubt the mechanical focus is rigjt but i'm more thanwilling to learn the ampro secrets. whatever isin focus looks real good, so i'm sure ill be fiddling with it for abit
Posted: Sun Oct 26, 2014 3:05 pm    Post subject:
I read this sentence a few times and I can assume a couple different things as to what you mean. So I need you to be more precise in what you mean.
Also, do you have a user/install manual for it?
veelangs
Posted: Sun Oct 26, 2014 6:43 pm    Post subject:
no i don't have the install manual (the spiral bound book)
but as for that sentence
when the projector is emitting an image, wingnuts for the lens adjustment are underneath the tubes, which as i understand means that it was ceiling mounted (which it was) so the image had been flipped.
From googling a bit, there are some plugs i have to switch about to get the image flipped back to front projection table top (which is what I'm doing)
does that make sense? It explains why I was having so much trouble focusing the unit
Page 1 of 3
