EXT V3 Gamma and contrast screws dont do anything at all.
redfox001
Posted: Wed Oct 08, 2014 9:51 am    Post subject:
CasetheCorvetteman wrote:
Press zero on the remote.
No I mean by removing some resistors. What resistors or what connections?
Posted: Wed Oct 08, 2014 11:40 am    Post subject:
Never heard of that.
Posted: Wed Oct 08, 2014 2:43 pm    Post subject:
redfox001 wrote:
I wound it all the way anti clockwise , nothing changed
Im quite sure it do, but you need to meassure it, dobt you will be able to detect by eye.
I always deactivate the gama section of the card.
Do you have a pic of your card, from the inside, so i can see the print layout.?
How do you deactivate the gamma? I would like to try that too.
No idea where those resistors are on the EXT V3.
Posted: Mon Oct 20, 2014 8:35 pm    Post subject:
Case, to get your contrast correct again set the EXT to 16-235 and run a white window into the HDMI at 100 IRE. Make sure the source is also outputting luma in range 16-235. You can use a test Bluray or a pattern generator.
Connect your oscilloscope to the GREEN RGB output and measure the p-p voltage. Adjust contrast such that the p-p is 0.7 volts.
If you send me a photo of the front and back of the EXT I can tell you what to pull off to disable gamma.
redfox001
Posted: Fri Oct 31, 2014 1:36 pm    Post subject:
This is the external Moome v3. Can you tel how to disable the gamma on this one? The top yellow wires go to blue gamma and contrast pots.
