Barco CineMAX / Cine9 / 909 1:1 shots collection
Posted: Tue Sep 30, 2014 4:55 pm    Post subject:
An inch of single wire has an inductance of about 20nH, a coaxial cable might have less inductance but I bet it is in the same ballpark as its capacitance.
redfox001
Posted: Tue Sep 30, 2014 5:12 pm    Post subject:
Ok you are right but than it makes an L filter with the cap and the inductance. Don't know by hearth what the characteristics are but think they are worse than low pass only.
I experimented with pi filters once and with transmission lines. I could not get a characteristic impedance with 1 meter on 3 MHz.
redfox001
Posted: Thu Oct 02, 2014 6:14 pm    Post subject:
Well I took the trouble of ordering 30m of the best RG6 I could find and was affordable. Three times shielded and 100 meter would be 18db down at 1GHz. So 1 db for 5 meter at 1 GHz. If it acts as a transmission line it will be an almost flat response.
Also a connector to the VGA without any cabling or stray capacitance.
So I must have a comparable setup as Casey.
And all of that in the name of science Very Happy I do believe there is something special happening here and the fact that I could not immediately reproduce it can be explained by the exceptional setup so I took exactly the same length cables and that I believe might be the most important parameter. At 50MHz the wavelength is around 6 meter so above that we might get a transmission line behavior just not very much. I can't wait to test this Very Happy
redfox001
Posted: Wed Oct 08, 2014 5:21 pm    Post subject:
Ok I tried again with bad results. I have a high quality rg6 vga to bnc cable of 6 meters just like Casey.
It still shifts the image vertical on 1080p on 720p the image was a little better and more stable but on both the bandwidth was nowhere near the screenshots that where placed here.
I remember Francisco wrote in the Eisemann thread that he tried too with coax soldered to the vga card and got nowhere near these results.
To conclude it is a complete mysterie and I am a little pissed that I had to spend another 50 euro on this Sad
redfox001
Posted: Wed Oct 08, 2014 6:40 pm    Post subject:
This is what Francisco wrote on the topic
Francisco wrote:
CasetheCorvetteman wrote:
See in my case using RG6 straight from the PC, it is a better option than HDMI to the MOOME V3 external. Its noticable.
Fox, i cant remember the name of the thread, it was a while ago, Mike posted a fair few pics of his modded Marquee with the same pattern.
I think it was this threat: https://www.curtpalme.com/forum_archived/viewtopic.php@t=34512.html
But also analog RGBHV RG6 cables doesn't resolve full bandwidth 1080p. For my own experiences Moome ext. V2 is better than analog RGBHV straight from PC, IMHO.
http://www.curtpalme.com/forum/viewtopic.php?p=408247&highlight=#408247
redfox001
Posted: Thu Oct 09, 2014 10:35 am    Post subject:
I still will not give this up. My next idea is that it has to do with the implementation of the Nvidea chipset. Mine is an Asus GTX750ti. Casey's is a Gigabyte. Perhaps the analogue stage is different filtered.
So I am going to try a cheap Gigabyte card. Anyone have experience with Gigabyte that confirms this like 'he I had great results on that ... and I used a Gigabyte too'? Very Happy
Posted: Thu Oct 09, 2014 6:49 pm    Post subject:
I wouldn't think there would be that huge differences between the cards, what you'd notice on the barco. If you have a few hundred euros to spare you could buy a neat tektronix oscilloscope with a BW >300MHz, plus you'd want a 0,5-1GHz FET probe and you could measure through the whole signal chain where the BW is lost, instead of guessing Smile
Well, if someone wants to send me his barco I can measure these things Laughing
redfox001
Posted: Thu Oct 09, 2014 10:14 pm    Post subject:
Good tip the scope. I'll look for one.
But how do you explain Caseys one on one picture if it was not the graphics card because everything else is the same as far as I can think of.
It might even explain why you don't get the bandwidth out the Nec where Casey does. Perhaps you don't use the same vga card? Or did you use a generator for the signal? Hmm you probable measured after the vga and everything was ok?
Wat is strange with mine is that they also show bad one on one on the Marquee while the Marquee even has MP mods I can not understand that the Marquee would also have a problem with bandwidth. Therefore I keep thinking it must be the vga card.
redfox001
Posted: Thu Oct 09, 2014 10:54 pm    Post subject:
He I am thinking could it be that the configuration parameters like anisotropic filtering x times and anti aliasing etc also work on the analogue output?
@Casey how did you fidle with these configuration of the digital filters?
Posted: Fri Oct 10, 2014 3:25 am    Post subject:
I leave all those on default.
redfox001
Posted: Fri Oct 10, 2014 4:14 am    Post subject:
Ok but there is some procedure to optimise the system. In my case all these buttons are disabled because my motherboard is very old and I have only 1 GB memory.
Posted: Fri Oct 10, 2014 6:35 am    Post subject:
I have set them all up at max settings before, couldnt really see a difference in movies with it.
Ive got 4 gig video card memory and 32 gig system memory, not that i think itll matter much in this case.
gnnash
Posted: Fri Oct 10, 2014 1:01 pm    Post subject:
Those settings have absolutely nothing to do with video playback. They are only used for 3D rendering, like when playing games.
redfox001
Posted: Fri Oct 10, 2014 2:19 pm    Post subject:
Indeed they do nothing.
The only facts I found after trying 1080p from the 750ti on the Cine 9 and on the Marquee with mods is that the Marquee resolved the bandwidth much better but not 100%. So I don't know if the vga is not 100% or the Marquee is not 100%.
What are the experiences with the Marquee without mods does it resolve 1080p 100% from a Moome?
Also the image from vga is very stable. No jitter and I see little noise but I only looked at testpictures, no movies.
Seems to me the vga card is a great solution for video playback. It looks great.
Posted: Fri Oct 10, 2014 9:19 pm    Post subject:
The ones in the top menus do, but there are others further down that affect video.
Posted: Fri Oct 10, 2014 9:21 pm    Post subject:
I always used it where possible before, for those very reasons you state.
Melifluonze
TV/Projector: 9500LC Ultra
Posted: Fri Oct 10, 2014 9:29 pm    Post subject:
Ok, so this is ancient stuff...
I used to run an ATI Radeon card back in the day, with a Faroudja chip-based scaler in another slot of the HTPC. I always had a problem with signal quality going through 25 feet of coax to BNC inputs until I purchased an Extron 203 Rxi (or equivalent).
These things accept a VGA input (15 pin DIN plug) and output RGBHV. They DO NOT scale or modify the image, but they do display the frequency (dot clock) and they allow you to peak the interface (adjust the signal level and impedance to match the line you are driving) and they allow you to move the image in the x and y direction.
The peaking part of it REALLY improved my image by removing the ringing on the edges of everything...
Is that something you guys need? If so, there are several versions of the Rxi boxes. They are super cheap now ($25 on ebay), you just need one that has the dot clock bandwidth capability you are looking for.
This is a link to the 203 Rxi manual:
http://media.extron.com/download/files/brochure/rgb_203_rxi_bro_revA.pdf
You keep the VGA to VGA cable short (from PC to Extron box) and then drive the long BNC to BNC cable to the projector. And then peak the thing out.
Does a nice job...
Posted: Fri Oct 10, 2014 10:13 pm    Post subject:
Hey, Case… I don't mean to thread-crap, but would you mind chiming in on my old thread where I'm asking about video cards? Thanks!
http://www.curtpalme.com/forum/viewtopic.php?p=420999#420999
Posted: Fri Oct 10, 2014 10:39 pm    Post subject:
No problem at all Crabb, you know things like that dont bother me Wink
Ill take a look shortly.
Posted: Fri Oct 10, 2014 10:43 pm    Post subject:
Does a nice job...
It possibly could help, but in my case im not having an issue, i use a PCB to convert from 15 pin to 5 BNC, which although it is powered, the power is not required unless i connect something to the SCART socket on that board.
Page 3 of 8
