Nec 9 pg
Zubik
Posted: Sun Sep 14, 2014 6:07 pm    Post subject: NEC Pic
Here is one pic. One more to follow
here is one pic
 Filesize:  120.77 KB
 Viewed:  5333 Time(s)
Zubik
Posted: Sun Sep 14, 2014 6:10 pm    Post subject: NEC Pic 2 of 3
NEC Pic 2 of 3
NEC Pic 2 of 3
 Filesize:  120.77 KB
 Viewed:  5327 Time(s)
Zubik
Posted: Sun Sep 14, 2014 6:11 pm    Post subject:
NEC Pic 2 of 3
Zubik
Posted: Sun Sep 14, 2014 6:13 pm    Post subject: nec pic 2
nec pic 2
nec pic 2
 Filesize:  120.77 KB
 Viewed:  5320 Time(s)
Zubik
Posted: Sun Sep 14, 2014 6:14 pm    Post subject:
here is another pic
Zubik
Posted: Sun Sep 14, 2014 6:24 pm    Post subject:
That looks like a double picture. Is it the same picture top and bottom? One over the other?
Are you sure you have the correct memory location selected in the projector?
yes
Posted: Mon Sep 15, 2014 12:15 am    Post subject:
That input screen does not mean anything at this point. Even if you select that input does not mean that is what is being sent to the projector. IIRC push the info button and post that screen.
Posted: Mon Sep 15, 2014 1:01 am    Post subject:
That will tell you which input is in use yes, it should automatically select the correct one anyway.
Posted: Mon Sep 15, 2014 1:10 am    Post subject:
Actually it should give you the current input resolution. It can only select an entry that was made for that resolution. It will not select an entry that is not specifically for it and cannot be force to.
Maybe I am thinking the wrong screen. It has been a while since I've looked at the NECs menus. I will look it up.
Posted: Mon Sep 15, 2014 1:25 am    Post subject:
The scanning frequency should be on that source info page.
Posted: Mon Sep 15, 2014 2:26 am    Post subject:
Thats basically what i was confirming happens when upu press info yes, it wont say the resolution, only the scan rates.
Zubik
Posted: Mon Sep 15, 2014 2:42 am    Post subject: Nec PJ
Well what looks like what happened was that one cable came disconnected and I tried to make adjustments. I still am not 100% if the white or yellow BNC connector is horizontal or vertical. The PJ looks like it is flashing like crazy in the green tube. I still don't feel I have a stable pic. Case I'm willing to call you in Australia if you have time. I sure could use some guidance here.
Posted: Mon Sep 15, 2014 3:35 am    Post subject:
okey dokey. Very Happy
Posted: Mon Sep 15, 2014 4:05 am    Post subject: Re: Nec PJ
We can do that, but itll be abit later on in the week before i will have time.
There is no harm in trying both white and yellow cables on both H and V, if its wrong it just wont work. If it works with just the H lead connected id say that is in the right spot.
Posted: Mon Sep 15, 2014 4:06 am    Post subject:
You know my writing is hard to read Wink Laughing
Zubik
Posted: Mon Sep 15, 2014 4:30 am    Post subject:
Awesome. What day and what time would you like me to give you a call? What is the time zone difference from Australia to Texas. What year is your Vette?
Posted: Mon Sep 15, 2014 4:45 am    Post subject:
It was 94, i sold that though Wink
Its 2:45pm right now.
I will confirm a time with you when i know more Smile
Zubik
Posted: Mon Sep 15, 2014 11:56 pm    Post subject:
Let me know the day and time
