9500 Ultra Software version 6.1?
Posted: Sat Aug 23, 2014 5:27 pm    Post subject:
stridsvognen wrote:
gjaky wrote:
stridsvognen wrote:
gjaky wrote:
stridsvognen wrote:
gjaky wrote:
IT HAS THE LATEST VNB WITH THE SANYO TRANSISTORS !!!!!!!!!!! Shocked Shocked Shocked
No matter what, stick to this machine!
Was it not you that had the diagram of those and told it had 7 peakings on those VNB.?
Yes, it was a response to your statement that everything is better without peaking, I was to show that the right ammount of peaking is inevitable for the good performance... Wink
When this board was new, Mike Parker checked these boards briefly at VDC and he said that these boards are masterpieces and tuned for perfection, these VNBs need a special matching VIM (because the clamping was removed from the VNB).
Would be interesting to see the performance of a set of those neckboards, at the moment im running neckboards with 0 peaking, and they do 200Mhz without any trouble.
Whats the bandwidth of those SANYO transistors, and the old Motorola transistors, i thought they had to redesign the board as they were unable to find a transistor who matched the specs of the old Motorola.?
Special VIM.. And whats the name of that one.?
As you can see it is a "peaking cap" -02p, with modifications, not a big deal, but still not compatible with the plain VIMs.
Scott (aka. tse) designed the new board, the output transistors are not better than the original Motorolas (~700 vs. ~1000MHz) but the driver transistors are significantly better (2,2GHz vs. 1,3GHz) and that matters more.
Im not sure your right about the VIM, it looks very much like a standard 02VIM with the standard factory mods, who all the late 02VIM have.
Someone should try it out.
Scott told this... maybe the difference lies only in the firmware of the board.
Melifluonze
TV/Projector: 9500LC Ultra
Posted: Sat Aug 23, 2014 5:34 pm    Post subject:
(As "someone" figures out how to get the monster down to his HT...)
Posted: Sat Aug 23, 2014 5:47 pm    Post subject:
Can you please hurry up, and shoot some screen shots.. Wink
Posted: Sat Aug 23, 2014 6:00 pm    Post subject:
I see the green tube has a clear C element, dont you have a green C element in one of the other machines you can move over.?
I have a new green LUG tube with clear C element, its made for a 9520LC
Melifluonze
Posted: Sat Aug 23, 2014 6:03 pm    Post subject:
I need to lookat tthese as well and get them out of my driveway...
 Filesize:  394.3 KB
 Viewed:  3225 Time(s)
Melifluonze
Posted: Sat Aug 23, 2014 6:05 pm    Post subject:
That one facing the other way is a 2007 8500, with only green tubes... The center one is ravaged with a CAD image... The other two tubes look untouched!
Is that weird or what... This projector is... SUPER GREEN! Wink
Melifluonze
Posted: Sat Aug 23, 2014 6:07 pm    Post subject:
I have some green C elements, and a red too... I want to try blending, but I can't find enough info yet.
Posted: Sat Aug 23, 2014 6:12 pm    Post subject:
What a nice driveway.
Ill have to admit im a bit jealous.
It takes some time to get around these Marquee machines, but if your willing to spend some money on them they will kill all other CRT machines out there.
Blending.. Ohh my thats a lot of work and money, how big a screen are you planing to run ?
Please pick up those lens caps while there still might be one who is not broken.
Melifluonze
Posted: Sat Aug 23, 2014 6:35 pm    Post subject:
Lens caps were all broken by UPS or the packer, including about half the lenses. I've rescued the couple that are not broken.
120" AT screen. I've already got VV1 Ultra (from Curt) on my ceiling... I am trying to get the latest, and I think I did. I've been running Marquees since 2000, starting with an 8500LC.
These, even though the cases are crushed, are so new!!! Going to upgrade my others with the parts.
One question now is, are these neck boards good for the older tubes (non LUG)? I have new ones I picked up from Curt and Tim. Suppose I will have to keep the VIM and neck boards together from one of these machines...
-M
Posted: Sat Aug 23, 2014 6:38 pm    Post subject:
-M
The new neckboards are designed for LUGs, so for other tubes you might need some modification. I'm not sure but there might be jumpers on the neckboard for LCPs (the schematic shows it).
Posted: Sat Aug 23, 2014 6:47 pm    Post subject:
Dont know about those new neckboards, but if you want a realy sharp noise free Marquee, you need to ask Mike if he can make you a VIM and a set of neckboards, and mod a Moome card for you.
Posted: Sat Aug 23, 2014 6:49 pm    Post subject:
Leave the Vim alone. its fine as is.
If you need help I can help you out when your ready to mount it.
Melifluonze
Posted: Sat Aug 23, 2014 7:24 pm    Post subject:
Thanks a Ton, Nash...
You're the one I need to talk to about Blending too...
Would a TV-One CI-7100 do the trick?? I saw a few threads but no real meat on how to do it...
Hey!!! The most crushed of these still works and has only 77 hours on it!!!!
6.1 SW... lemme seeee... Maybe I have my 9500 ' s for a Blend or Stack!!!
