stridsvognen Guest
| Posted: Fri Jul 04, 2014 11:41 pm Post subject: HDFury4 performance.? |
I have for a long time wanted to test the Hdfury4, but whenever i ask Hdfury about specs or performance i have a hard time get any useful answers.
Anyone here who have and use it, and have tested the claimed 72/96hz 230Mhz bandwidth, HDMI and analog output.?
Maybe someone here had a scope on it.? Ill hate to spend 400$ to buy one if its no better then the HDFury3.
HDFurys tech support wrote this to me....
""I cannot help any further so you can post or not it doesnt matter to me. As I have said you can either try or not. I cannot help with questions I cannot answer.
You are most likely the only person on earth who cares as most people use digital which all accept 24 hz."""
I sound more or less to me as they dont care to make and sell products for analog displays.
wildchild22
| Posted: Wed Jul 09, 2014 5:24 pm Post subject: |
Hey there thanks for taking the post in a pm out of context.
The post as it is written does not spell out what transpired in the multitude of pm's.
Of course they care about analog displays what use would the hdfury series to be to a person with a digital display?
The hdfury 4 will do what you want.
Anyway to get back on track.
He was offered a 30 day return but do not want to deal with shipping it back if it doesnt work. Hdfury does not give out loaners as no other company does either. They accept returns if it doesnt work out. Seeing he is the only person on earth with the equipment to test it properly he needs to test it for himself.
stridsvognen Guest
| Posted: Wed Jul 09, 2014 5:53 pm Post subject: |
| wildchild22 wrote: | Hey there thanks for taking the post in a pm out of context.
He was offered a 30 day return but do not want to deal with shipping it back if it doesnt work. Hdfury does not give out loaners as no other company does either. They accept returns if it doesnt work out. Seeing he is the only person on earth with the equipment to test it properly he needs to test it for himself. |
Im for sure not the only one with a CRT like this, maybe many dont care, or wont be able to notice a difference, as many in here already have a preference for some moome products over the Hdfury.
As most scalers/ all i know off have some shortcommings of some kind, i would have loved some information about what the fury do good and wont do so good.
You also know i just made arangements to order a Hdfury4, and ill post in details my findings in here.
It would be great if you can post some tests and explain a bit about the product and its performance in here.
How it was measured/ tested, bandwidth noise and so on.
Also please explain how Hdfury.com and .co.uk and .eu is conected, and why they dont seem to offer the same conditions and return service.
If you cant comment or know about the specifik testing and performance of the product, your welcome to ask someone else from the Hdfury team to assist you.
wildchild22
| Posted: Thu Jul 17, 2014 2:37 am Post subject: |
The hdfury .eu and .co.uk are resellers.
only .com are the manufacturers. Please post your review of the tests. I have no way to get the info you want. So we will leave it up to you for the tests.
| Posted: Fri Jul 18, 2014 3:25 am Post subject: |
So no one from tech support has any idea at all? Why are they in tech support?
stridsvognen Guest
| Posted: Fri Jul 18, 2014 6:00 pm Post subject: |
Just got the Hdfury 4, and i can already say that the analog bandwidth is not anything to brag about, it wont resolve 148Mhz signal.
So it looks more or less like the Hdfury 3 as a DA converter.
HDMI in HDMI out passing 1080P 60hz looks to be ok, great luma and croma bandwidth, but as others the Croma gets cut down when it has to do any scaling/ frame tripling.
Ill look some movie on it feeding it 1080P 24hz, output 1080P 72hz tonight, see how it compares to the Radiance.
Looking testpatterns it looks much better than the Radiance, i mostly focused on the croma test patterns.
So tonight ill see if i get some of the lost dynamics back i have using the Radiance as a frame tripler.
thewolfman
| Posted: Fri Jul 18, 2014 8:08 pm Post subject: |
Deleted. Off topic.
stridsvognen Guest
| Posted: Fri Jul 18, 2014 8:37 pm Post subject: |
Deleted. Off topic.
stridsvognen Guest
| Posted: Sat Jul 19, 2014 6:43 pm Post subject: |
Just tested 720P 60hz running RGBHV out, and it wont resolve it, quite limited analog bandwidth, guessing its the analog filters who need to be modified.
Im trying to make the scaler GUI work, did not have any luck so far, its not just a download and run thing.
It should be able to run 200Mhz so with the scaler GUI i should be able to change timings to push raster ringing out at 1080P 72hz.
I dont know where the 230Mhz bandwidth come from. So that must be a sales trick, cant see anyone would be able to get 230Mhz pixel clock true this device analog or digital out.
Looked a few movies and some Netflix on it last night running 1080P 72hz, and was quite pleased with the result, nice dept and dynamic range, and the frame tripler from 24-72hz did run smooth all night.
stridsvognen Guest
| Posted: Tue Jul 22, 2014 8:55 pm Post subject: |
OPPO 103D 1080P 24hz -> Hdfury4 1080 72hz HDMI out -> Moome VIM.
178Mhz
stridsvognen Guest
| Posted: Tue Jul 22, 2014 8:58 pm Post subject: |
OPPO 103D 1080P 24hz -> Hdfury4 1080 72hz RGBHV out.
178Mhz
stridsvognen Guest
| Posted: Tue Jul 22, 2014 9:14 pm Post subject: |
OPPO 103D 1080P 24hz -> Hdfury4 800P 96hz HDMI out -> Moome VIM.
187Mhz
thewolfman
| Posted: Wed Jul 23, 2014 12:28 am Post subject: |
Easier to see with side by side comparison.
| Description: |
| Filesize: |
247.27 KB |
| Viewed: |
17627 Time(s) |
stridsvognen Guest
| Posted: Wed Jul 23, 2014 5:02 am Post subject: |
The problem is that you cant use my Pictures for sharpness evaluation.
Its ment as a bandwidth evaluation.
Every time you change resolution, the convergence focus and geometry changes, and i dont do a full blown setup to shoot these bandwidth tests.
Also the camera autofocus can be off, and its more and less a free shot, no fancy camera setup.
stridsvognen Guest
| Posted: Wed Jul 23, 2014 1:34 pm Post subject: |
After running some time. 30min + the analog output starts to make some noise, distortion, must be heat related, its only on the analog out.
And its not hot, its hanging free with plenty of air around.
thewolfman
| Posted: Wed Jul 23, 2014 6:19 pm Post subject: |
Deleted. Off topic.
stridsvognen Guest
| Posted: Wed Jul 23, 2014 6:35 pm Post subject: |
Deleted. Off topic.
thewolfman
| Posted: Wed Jul 23, 2014 7:07 pm Post subject: |
Off topic. Deleted.
stridsvognen Guest
| Posted: Wed Jul 23, 2014 7:44 pm Post subject: |
Right now im testing the croma output on the Hdfury4 and how it converts color spaces while scaling/ passing the processor.
Ill try shoot a picture, but the noise on the analog output is teasing me, so i need to let it cool down before i can move on.
thewolfman
| Posted: Thu Jul 24, 2014 9:09 pm Post subject: |
Deleted. Off topic.
