Elf Six
| Posted: Thu May 22, 2014 3:22 pm Post subject: Need a CRT reality check |
Hi all
I'll be moving to a new house soon, so me and the wife started to think about our
Marquee 8500 Ultra. It has served us very well for over ten years, without any problems
(except a blurry blue tube). We run 720p on it. So, my wife asks if I we should hang it
in the ceiling in the new place or on the table, like now. That's when I start to doubt if the
wisest choice would be to wrap it up and put it in the basement.
For the fun of it, I started to look a the digital pjs you can buy at normal warehouses. The wife
found this to be very strange, coming from the 'high-tower'. But time marches on I guess.
I then thought; has the tech moved so far that I would impressed even with a lower-end digital?
Like, if I were to put this one up next to the Marquee, what I would see? How would it compare?
Marquee 8500 Ultra vs. BenQ W1300 DLP(or the like). I would guess that I would get a sharper image(1080p vs 720p)
a brighter image, not-so-good blacks, maybe artifacts?
But in the real world, would it be better? Or how much would a digital pj cost if it were to be 'in the same
ballpark'/better than the 8500 ultra?
| Posted: Thu May 22, 2014 3:35 pm Post subject: |
Hello
Your blue tube may only need a magnetics alignment to regain focus
Elf Six
| Posted: Thu May 22, 2014 3:39 pm Post subject: |
Tim, I tried everything and it's just blurry.
However, even if it were good, we would still need to think about mounting etc in the new house.
ElTopo
| Posted: Thu May 22, 2014 3:43 pm Post subject: |
A Barco 909 will give you Reality
| Posted: Thu May 22, 2014 3:51 pm Post subject: |
Hello
Do have streaking on blue? Try swapping neckboards. I have never seen a 180DMB22 just go blurry on its own
| Posted: Thu May 22, 2014 4:17 pm Post subject: |
No matter what you read online, you need to go check a digital out in person. I still don't like any of the low end stuff I've seen. With the price of good 8" tubes being relatively cheap, you'll still be into a replacement blue tube for far less than a new decent digital.
As for hanging the thing, well frankly, my $.02 only, but I've never understood the 'big job' attitude of hanging a CRT projector. Granted, I've done pretty close to 100s of them, so I know what to do, but it really isn't a big deal.
| Posted: Thu May 22, 2014 4:46 pm Post subject: Re: Need a CRT reality check |
| Elf Six wrote: | Or how much would a digital pj cost if it were to be 'in the same
Thanks | Last years JVC DILA RS60-sumtin will run you about 3 grand. IMO The lower end crap is still crap, especially from BenQ. If your marquee is still an all-original turn of the century condition then there's more performance you can squeeze out of it , anything from better lenses, upgraded electronics, or even turning it into a full 9500LC by buying tubes from Curt, LC lenses, and getting a set of mounting plates.
The last option might start approaching the cost of of the JVC though.
Elf Six
| Posted: Thu May 22, 2014 4:55 pm Post subject: |
I'm just a little wary of buying another blue tube. This never really became a hobby for me, and I can see that the JVC's
at about 3K, as you mention draganm, are held to pretty high regards. One of those would probably walk over my Marquee.
I'm not going to install new lenses etc.
| Posted: Thu May 22, 2014 5:06 pm Post subject: |
Just remember to figure future lamps into the equation. And if there happens to be a failure after warranty the repair cost can be great.
jbmeyer13
| Posted: Thu May 22, 2014 6:21 pm Post subject: |
There's two parts to this equation; performance and time. From a performance stand point the low end digitals (like aforementioned BenQ) are not going to have decent black levels but they will be bright and sharp. The JVC's performance will surpass your stock 8500 Ultra but will be a significant investment. And as Mac said you may need a spare lamp which adds more to the cost. Your current projector is capable of 1080p.
Time is the other issue. With a little leg work you could replace the blue tube (40 minutes), add a Moome card to run 1080p straight into the PJ (5 minutes) and set up the Marquee at your new home. Setting up the PJ is dependent on your expertise, familiarity and where you want to place the projector. A good set up shouldn't take more than a day's effort. A digital PJ can be set up in a fraction of the time.
In summation:
a) For approx. $500 and a day's worth of work you can continue using your Marquee.
b) For approx. $1,000 and a couple of hours you can have a digital with lesser performance than your Marquee
c) For approx. $3,000 and a couple of hours you can have a digital with better performance than your Marquee
IMO, you go with either a or c depending on your preference for time/money.
| Posted: Thu May 22, 2014 7:15 pm Post subject: |
We're looking at a used CRT, and an 8-inch at that, so we don't need to compare to a brand new digital for a valid comparison.
For instance, an acquaintance of mine is selling his JVC RS45 on AVS Classifies for $1,495. I have the same projector, and it's truly an OUTSTANDING projector for $1500. It's 2.5 years old, has about 1500 hours total on it, and it's on its second lamp with 240 hours on it. Depending on how much you watch, that's probably good for at least a year or two before you have to put a lamp in it. Comes with a transferrable Mack warranty good until November. He's only selling it because he upgraded to a 2014 model.
I switched from a G70 to an RS45 two years ago, and I couldn't be happier. No, the black level isn't quite as good, and since I sit very close to my screen, if I strain and look very closely, sometimes I can just see pixels. But, other than that, it's far superior to the CRT in every other way. Super-quiet, very small for little impact on room or seating, very easy to hang, little to no setup, powered lens shift/zoom/focus, so much more flexible installation. It's much brighter so it can handle a bigger screen and even scope without a scaler. For me, at $2200 it was a no-brainer. At $1500, it's a downright steal. In fact, I would't even bother looking at a low-end BenQ or Epson.
Given that, I'd amend Justin's list like this:
1) For approx. $500 and a day's worth of work you can continue using your Marquee.
2) For approx. $1,500 and a couple of hours you can have a digital with better performance than your Marquee
The CRT is nice because it won't ever need a lamp. OTOH, this situation (and so many others on this very forum) makes it clear they certainly aren't free to own (as some would have you believe). If you have one for some length of time, it's highly likely you'll have to put some money in it. Yes, they're generally inexpensive to repair, while the digital is not - as long as you're not talking about replacing tubes.
I'd also add that a JVC that's even a year or two older than my RS45 is similarly competitive with an 8-inch machine, but at a used prices closer to a grand.
So, it just comes down to budget, time, aesthetics, performance, and which of those things you value most.
Cheers,
| Posted: Thu May 22, 2014 8:18 pm Post subject: |
| ecrabb wrote: | | For instance, an acquaintance of mine is selling his JVC RS45 on AVS Classifies for $1,495. It's 2.5 years old, has about 1500 hours total on it,SC | wow, 1500 hours on the chassis, I had no idea they could run for that long!
Is your buddy switching back to CRT?
tschaeikaei
Joined: 08 Apr 2013 Posts: 490 Location: Germany/Saarland
| Posted: Thu May 22, 2014 9:02 pm Post subject: |
If i were you, i would first care about a screen.
You will use a projector, that's clear.
If you're not shure about the Marquee, place it on a table and do a setup.
You recently moved to a new house? Well, there may be more things to care about than home cinema, i gues.
So don't play with your money, use the marquee, maybe test another projector (CRT or digital) from a friend on your screen
and see how it goes.
I personally would keep the marquee. But as i don't know your preferences, chill out and enjoy movies.
If you can grab a cheap blue tube, grab it and maybe resell it if you should decide against the Marquee.
The question is not, what would be better (which would call thousands of post here and on other forums) but what you like best.
You know that projector, how to do a proper setup and thats a good start.
Digital is too easy Just hang it and turn the lens to focus. Where is the challenge?
Remember lamp life and cost if you should tend to digital again.
Regards, Julian
_________________ Marquee 9500U edgeblend P43 | NEC 9PG
| Posted: Thu May 22, 2014 9:25 pm Post subject: |
Personally, I'd go with a newish JVC over any 8" CRT. I'd only consider keeping the Marquee if you decided to upgrade the tubes from Curt to 9". Curt has had some really really really low prices on Marquee 9" tubes so it might be worth considering.
If it were me, I would look at NOS JVC projectors from last year for economic reasons. A lot of people do it, but I wouldn't consider buying a used digital projector unless it were a really high end model or less than two years old (but that's me). The digital projectors have gotten more reliable for the past several years which is one of the reasons I say look at the newer ones. The other reason is that image quality has marched forward incrementally every year.
This year and last black level on the JVC and Sony projectors has really improved too. If you are thinking about professional calibration at all than there is more to the story, but for a stock projector both the JVC and Sony models are relatively nice looking out of box. IMO either one would surpass all but the very best 8500's out there.
| Posted: Thu May 22, 2014 10:34 pm Post subject: |
I'd look at it one more way regarding pricing. As Mac says, do factor in ONE new bulb into the equation. I'm not sure about the JVCs, but most of the lower end digitals will last 2-3 bulbs before the chassis blows up. After the second bulb is close to the end of its life, I wouldn't bother buying another bulb (third into the set),as almost guaranteed that there will be chassis issues shortly thereafter.
too bad you won't consider dropping in 9" tubes. For $1500 you could turn that projector into a 9500 Ultra. Where are you located?
Bucketfoot
Joined: 17 Mar 2006 Posts: 698 Location: Centennial, CO
| Posted: Thu May 22, 2014 11:39 pm Post subject: |
I always think the bulb comments are way overstated. I'm closing in on 5 years with my RS2 and I've replaced the bulb once. I don't watch it daily, but it's on a several nights a week and pretty much all day every weekend.
I certainly agree that if you are going digital, JVC is the way to go.
| Posted: Thu May 22, 2014 11:51 pm Post subject: |
Using a term of years or months for bulb life has no relevance. A 15 year old lamp could still work fine depending on its hours.
| Posted: Fri May 23, 2014 12:56 am Post subject: |
| Bucketfoot wrote: | | I always think the bulb comments are way overstated... |
They do tend to be...
| macgyver655 wrote: | | Using a term of years or months for bulb life has no relevance. A 15 year old lamp could still work fine depending on its hours. |
More so its usage pattern and how well the machine is maintained than its running time, actual hours of operation mean very little. If you turn on a "5,000 hour bulb" and never ever turn it off, provided the filters are kept clean enough it will probably go for well over 20,000 hours.
Ive currently got 3 little NECs going here at work that are WAY beyond their hours, one of them by almost 2,000 hours now. The rated life of 3,000 hours went by about 1,900 hours ago, its still bright and even. That particular projector runs around 12-16 hours a day every single day.
There is four Sonys that get poorly treated from dickheads turning them on and off alot in short periods of time, one failed 200 hours short, the other was almost 800 hours short.
| Posted: Fri May 23, 2014 2:29 am Post subject: |
| CIR Engineering wrote: | Personally, I'd go with a newish JVC over any 8" CRT.
craigr |
craigr |
craigr |
craigr |
The first thing you have to determine is your budget. You mentioned lower end digital. What is the ceiling on that price?
Next, what do you like about owning a pj? Is the screen size, video image, etc?
If you just want a large screen, then any old cheap digital will do. If you are looking for video quality, then you have to determine what attributes are important to you. From there, you can decide where to proceed.
If you don't want a used digital, then call Mike Garrett over at AVS. They have some good prices on Sony b-stocks. JVC usually has b-stocks coming out around this time of year as well.
While I have a G90 and will run it for the forseeable future, I wouldn't have a problem going with the new JVC 4910. Based on Kris Deering's review, I doubt there is any difference between a CRTs on/off cr and the JVC.
Elf Six
| Posted: Fri May 23, 2014 9:31 am Post subject: |
Hi all
The wife said no to any low-end digital. She especially said no to ever having anything called Epson as a pj.
"Are we having a meeting in the company conference room?"
It seems we are going for a JVC DLA later on. At 2k to 3k (USD), it will be hard for me to use 500USD on a new
blue tube. That's too high a percentage of an JVC DLA. Then shipping comes into play, too. I'm located in Copenhagen,
Denmark.
I put some stuff up for sale here on the forum, because I am trying to downsize stuff in my depot. So maybe my mind
is set? I don't know. It's difficult after having used the Marquee for so many years without any problems. But maybe it's
wrong hanging on to 'being special'. Bite the apple and go to the warehouse and buy a digital pj in the same place you
buy your dishwasher.
At least I've decided against a cheap one
