NMB fan specs from Barco 808/Cine8/Zenith 1200?
apple156
Posted: Tue Feb 06, 2007 2:14 pm    Post subject:
Ile wrote:
One option is to build laminar 120mm -> 80mm fan adapter (funnel shaped) outside of the convergence tray, but that ain't going to look very slick...
No that's very Shocked let alone the WAF
Try looking at the "noiseblocker" that is a real silent fan and 80mm.
I also looked at placing a bigger fan inside the convergence tray but there is hardly any room for this, even a thicker 80mm (25mm?) is not possible as the edge of the chassis doesnt let room for a thicker fan.
I have cut the raster open and this together with the new fan gave a lot more flow.
Peter
Ile
Posted: Tue Feb 06, 2007 3:02 pm    Post subject:
Peter
I'm just throwing some ideas for 808 owners. Very Happy
I don't have that 80mm front fan in any of my Barcos and I use hushbox (avatar) anyway, because any fan mod wouldn't help enough for me.
Even my hushbox isn't enough right now, I have to make air circulation totally sealed from theater room in next house. Now cooling air is coming from separated room through duct silencer, but exhaust air is coming to theater room after attenuation. System is inaudible with 576p75, but bigger resolutions can be heard occasionally and that sucks. Crying or Very sad
apple156
Posted: Tue Feb 06, 2007 4:06 pm    Post subject:
That is a cool looking hushbox, did you made it yourself?
Posted: Tue Feb 06, 2007 4:53 pm    Post subject:
apple156 wrote:
I measured the temerature as i have a "industrial contact temperaturemeter"
on the metal frame in the cabinet where al the prints are near i think port3 board, just right behind the tube neck board.
Interesting - that's exactly where I measure as well. Ceiling mounted, right below the green tube neck board on the metal frame of the cabinet. I have the probe taped there permanently.
My temp never rose over 28C with the NMB original fans. With the SilenX fans it's the same.
I'll still going through various spots in the projector and am again going to do before/after temp checks by swapping back in the NMB's. I'm doing the SilenX readings first since they're in there now. (I know, I'm doing this backwards and creating more work for me).
Ile
Posted: Tue Feb 06, 2007 5:30 pm    Post subject:
Originally I made it to BG500 and later I modified it for BD801s.
Here is more about it...
http://archive.avsforum.com/avs-vb/showthread.php?postid=2845303#post2845303
After those pictures I have made input air section sealed from room. Next step would be modding it for BG1200, I need to get it 300 mm wider and little longer. Rolling Eyes
Person99
Posted: Tue Feb 06, 2007 7:09 pm    Post subject:
I've actually been giving some thought to Ile's hushbox (the best looking one I've ever seen and the only one that works well in a dropped PJ set up). Ile used to have the hushbox open at the top. What if we just put a plate with side skirts on the back of the PJ that angled up at 33-45 degrees. Put some sound insulation in it. So basically, you have essentially the back of ile's hushbox attached to the back of the stock 808 case.
I may try some experiments to see how much that lowers the noise.
Alaric
Posted: Wed Feb 07, 2007 3:29 pm    Post subject:
Hi Guys,
Watching this thread and reading some of the links (avs) there seems so merit to swapping the NMB fans out when they get older and seeing that my BG808s has quite a few hrs on the chasis, i started searching.
I came across an ebay add :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AL%3ARTQ%3AUK%3A1&viewitem=&item=130076999667&rd=1
Which is for the faster model, however the PDF's have some useful data.
and so I asked about the B30's and here is the response :
Only B10 B30 B50 are in production in E00 (Reference). Reference is fully sealed, closed, shielded. Similarly B10 B30 are only in production in V00 (Valueline). Valueline has "balls whizzing" as open ball, unshielded.
What I can suggest is use the B50 fan with a simple fan controller, then reduce the speed to about 9-9.5V.
The B50 at 7V is almost exactly a B10.
So a B50 at 9-9.5V would be a good equivalent of a B30.
Usefully you could vary it either-side-of-that so achieving exactly the airflow & noise you require.
What do you recon ???
I guess you'd have to put some form of extra resistor in thier to bring down the speed to the B30 spec, then it should perform better having better & quieter bearings ???
Cya,
Lee
Ile
Posted: Wed Feb 07, 2007 4:58 pm    Post subject:
With dropping resistors you get only about 4V to B50's in startup and those probably won't start with that low voltage.
picree
Posted: Wed Feb 07, 2007 10:31 pm    Post subject:
I did just that. I can't measure the sound levels that low but if you're sitting right under the projector it really does reduce the directionality of the sound and in my opinion makes it less noticeable. It also helps hide the cabling from view. On the downside, it hides the little red light on the back of the proj that tells you it's in stby........
Curt
Person99
Posted: Wed Feb 07, 2007 10:55 pm    Post subject:
Curt
Cool, what did you use, thin metal with some sound insulation?
So you did notice a difference when sitting under it? If you tried to quantify it, what would you say?
WTS
Posted: Thu Feb 08, 2007 12:09 am    Post subject:
I pretty much did the same thing on the back of my 1200x and it does deflect the sound away. I sit right under it too and I do notice a difference.
Also I put furniture stuffing material(it's sort like rock wool) in the lid and that helps alot, I can notice the difference when it's not in there thats for sure. When is it not in there, when I'm in between board tests because it's a bit of a hassle putting it back in everytime I close the lid(cealing mounted pj).
Walter
Person99
Posted: Thu Feb 08, 2007 12:13 am    Post subject:
What materials did you use?
Any pictures?
Very cool, I'll have to try that too.
WTS
Posted: Thu Feb 08, 2007 12:23 am    Post subject:
For the back piece I just used a heavy piece of cardboard (maybe 20" or solong and about the same width as the pj) with an old pillow cover, one of the ones with padding in it and a zipper style. Then I used a solid copper wire about 20awg and tied it to the pj and then to the far edge of the cardboard. Hi-tech don't you know, course it's not permanent, well at least until I can come up with something better.
The pillow cover sits on top of the cardboard and absorbs some of the noise but doesn't interfere with the air flow.
No pics but it's not too hard to imagine
Walter
picree
Posted: Thu Feb 08, 2007 12:47 am    Post subject:
I would say it cut down on the directional-ness by about 1/2. Noticeable. I mean the noise is still there but it more diffused...especially if you sit right under it.
I used some pre-painted aluminum flashing material that came in brown. 14" width I think. I then lined it with some fiberglass board. Since the board isn't rated to go on the inside of a duct and is friable I sprayed the surface of it liberally with 3M contact adhesive until it created a skin on it (you can't see it in the photo but it's there). I also tapered the insulating board down on the edges so as to not obstruct the airflow.
REMEMBER: If you do this, make sure you spray the insulation with some sort of glue to keep it from frying. You don't want to be breathing fiberglass!
Curt
Open vents........
 Filesize:  74.63 KB
 Viewed:  12446 Time(s)
close-up of the interior
 Filesize:  51.36 KB
looking up
 Filesize:  41.75 KB
Person99
Posted: Thu Feb 08, 2007 1:00 am    Post subject:
Very cool picree. So, are the fans working harder, or is the airflow enough? I would have thought it might need a more open area around the fans.
picree
Posted: Thu Feb 08, 2007 1:58 am    Post subject:
I haven't noticed a difference in fan speed. The vents aren't as blocked as much as it looks in the pictures. I don't have a thermostat or anything. If I can judge by the amount of convergence drift I see over an afternoon of football, I would have to say it's running pretty cool. After having the proj on for even six hours I check the dot-hatch and there isn't any drift. FWIW...
Curt
BTW-the projector cover is off because I'm continuing my quest to mount HD144s! Soon, very soon......we have a prototype! I hope to post photos of yet ANOTHER way to mount HD144's on an 808.............a lot of lathe work. It is tricky to do it right!
MAIN THEATER: (JVC RS2000; Yamaha UDP-LX500; Yamaha RX-V2400; Lumagen Radiance Pro, Vertex)
SECOND WII-ATER: (BG808; WII; Oppo 971H; Moome external box; BG-DVI transcoder; tse gamma box; Extron)
WTS
Posted: Mon Feb 12, 2007 2:25 pm    Post subject:
Hi Kal,
I remember reading somewhere that you were having heat problems after you changed the fans to the silenx. I ran my 1200x yesterday for about a total of 7hrs and at the end of the evening I opened up the case and checked all the heat sinks with my finger tips. The neck boards weren't even warm really, actually there was only one heatsink which I could only hold my finger tips on for about 10secs(offhand I don't recall what the board is). All the heatsinks were no were near what I would consider hot by any means and if you can hold your finger tips on them then they're not hot in the electronics world.
I run my pj at 1080i. I would say I'm happy with the cooling my pj gets and the noise is alot better than with stock fans. I should mention that I didn't replace the angled fan in the rear.
Walter
Posted: Mon Feb 12, 2007 3:46 pm    Post subject:
Hi Walter,
Good timing! Below are my findings after a week of testing with a couple of temp probes.
I measured the temperature directly on a variety of the heat sinks at the same scanrate each time. This took me all week because (a) it somtimes takes up to 2 hours for each temp to stabilize, (b) I did 2 whole sets of tests from start to finish to make sure that temp probe placement didn't change too much based on positioning (it didn't), and (c) I had to put the all 3 old NMB stock fans back into the projector and redo all temp tests.
H-Shift/Focus board (middle): 46.0C (NMB) -> 54.5C (SilenX)
H-Shift/Focus board (bottom): 46.2C (NMB) -> 53.3C (SilenX)
Horiz board (on top): 28.0C (NMB) -> 42.5C (SilenX)
Vertical board (on top): 39.6C (NMB) -> 50.2C (SilenX)
SMPS (underneath): 36.8C (NMB) -> 41.1C (SilenX)
All tests done with a 1080i/60Hz signal as input.
Remember that I replaced the fans as follows:
Angled 80CFM NMB fan -> 72CFM SilenX fan (this one only cools the H-Shift/Focus board)
2 other NMB 80CFM fans -> 90 CFM SilenX fans (these cool everything else)
Some of these temp jumps are huge! For example, the horiz board which is basically cooled by one of the 80CFM NMB or 90CFM SilenX fans jumps 14.5C even though the new fan is 'supposed' to be 10CFM larger!
Same with the SMPS. The "Larger" 90CFM SilenX fan cools worse than the 80CFM NMB fan.
The NMB fans are staying in place. Anyone want to buy $120CAD worth of SilenX fans?
Posted: Mon Feb 12, 2007 4:54 pm    Post subject:
Damn. Guess their CFM ratings are overly optomistic after all.
Alaric
Posted: Mon Feb 12, 2007 5:08 pm    Post subject:
Hi Kal,
Interesting Info.
However did you take any external temp measurement at the same time, ie the general air arround the PJ, as this may affect the internal results ???
So where do we find some better fans now Sad
cya,
Lee
Page 4 of 6
