nec6pg everything only works if i press END
mookee
Posted: Thu May 08, 2014 1:36 pm    Post subject: nec6pg everything only works if i press END
hi.
after having big troubles with my nec at setting it up for my ps1 i didnt use it for a while:x . anyway, now, just the same behaviour as during my ps1 troubles, the picture only gets fine if i press "end" several times. but if i want to adjust it then, all menues are someanynotreadablething. i thought it was my bad ps1 cable (so i threw it to hell) but now its the same running through vga to rgb. that definitly worked fine in former times. i tried 1280x720 @60hz and 1440x720@60hz..all the same s**t. only stupid 1024x768@60hz works just fine with all menues working and so on..
whats going on there please, anyone experienced the same?
bw. christoph
Posted: Thu May 08, 2014 1:40 pm    Post subject:
Leaking capacitors on either the deflection board or the system board.
Posted: Thu May 08, 2014 1:41 pm    Post subject:
Actually, why am I saying 'or'?
the correct answer is:
Leaking capacitors on EVERY board! Smile
mookee
Posted: Thu May 08, 2014 1:51 pm    Post subject:
ähhh Sad i thought so... well, thanks so far.
thanks and bw.
christoph
Posted: Thu May 08, 2014 1:54 pm    Post subject:
I am clearing out a whole bunch of CRT parts, including NEC PG stuff. I know shipping will be $75 or so, but if you want other boards, let me know.
mookee
Posted: Thu May 08, 2014 3:19 pm    Post subject:
hey.
new ones? how much for them
btw. new caps where exactly please, if i want to do it myself. only the deflection board or which else. and about how many single caps are we talking of?
thanks lg c.
mookee
Posted: Thu May 08, 2014 6:27 pm    Post subject:
its so weird. after 5 houres on power and several diferent resolutions doing nothing reasonable i got a 1280x1024 @60hz picture now, stable enough for a signal entry (which all got lost during non-use btw.)
weird
may i SHOULD repair that fat f**k instead of seeling away as soon as possible Wink
no offence V
Posted: Thu May 08, 2014 9:13 pm    Post subject:
Stop using it before it becomes f***ed. you will need to replace the capacitors on almost every board if theyre original.
Posted: Thu May 08, 2014 10:00 pm    Post subject:
No, old as-is boards. For a few $$, I can test them to make sure you get working one, but otherwise I'll pull them off the shelf and just send them to you.
It doesn't really matter what hours the boards have on them, both low and high hour boards have leaking capacitors on them. Spend $50 on capacitors, and a few nights to replace a bunch. It's usually the 22 and 33 and 47uF ones that leak.
Oops, and 10uf! Smile and 100uF
Posted: Fri May 09, 2014 12:58 am    Post subject:
And almost everything else.
mookee
Posted: Fri May 09, 2014 11:32 am    Post subject:
hmm, ok thanks curt! i totally would, but the shipping cost, OMG...
is it hard to dissamble it to get the boards out. is there a manual for that procedure? and really, every board?
thanks
(aja, case;) it seems i might even got my ps1 cable right but couldnt do the trick out of the here mentioned reasons..haha;( annoyingly..well)
Posted: Fri May 09, 2014 1:42 pm    Post subject:
Shipping won't be bad, about $75 to get 5-6 boards to you. All you need is a Philips screwdriver. Check for leakage under all electrolytics. you'll see little puddles of clear/pink/green/blue goop under them, or if there's nothing on the board, look for discolored leads going to the PC board.
WE've discussed this here before, but I would clip off the capacitors at the top of the board, then solder in the new caps to the wires sticking out of the board. The electrolyte will smell strange as it is burned off, but you'll get used to it. Very Happy
mookee
Posted: Fri May 09, 2014 7:50 pm    Post subject:
why not the common soldering way downside up?
Posted: Fri May 09, 2014 8:26 pm    Post subject:
The traces are very fine on some of the boards, and the capacitor legs are bent, so when you pull them out the bent leg pulls out the via as well.
On the other hand I got a pretty good technique to pull them out without damage, I damaged probably 3 vias with ~400 changed capacitors. On system boards, however, I didn't want to risk pulling vias, so I clipped there too.
Posted: Sat May 10, 2014 2:16 am    Post subject:
The leaking caps damage and soften the boards, and if you choose to remove the capacitors rather than snip their legs and solder that that, youre going against some very good advice.
Posted: Sat May 10, 2014 7:49 am    Post subject:
By the way, how are the tubes looking? With burnt tubes I'm not sure I'd start in a recapping now...
mookee
Posted: Sun May 11, 2014 9:24 am    Post subject:
hey,
i did the step by step way installation and got a good look on the tubes there -i think they are okay..
i understand and will take the advice, thanks!
mookee
Posted: Mon May 12, 2014 12:36 pm    Post subject:
seems tricky to get to the cap pins from beyond, as the caps are soldered quite tight to the board! any tipps there?
lg
Posted: Mon May 12, 2014 1:34 pm    Post subject:
Use diagonal cutters, and cut off the capacitors
