SONY G90 modifications / improvements ???
Posted: Tue May 20, 2014 4:38 pm    Post subject:
I need some help here.
Can someone put up a fine grid pattern, like the first one in the Radiance, turn the contrast all the way down, look into the tubes, and tell me what you see first when putting the contrast up slowly.
I just did this on both my standard marquee and my standard G90.. And there is a huge difference in how it behaves.
Posted: Tue May 20, 2014 5:16 pm    Post subject:
On the newest Moome card remove U68 to defeat the gamma circuit. You absolutely do not need Moome gamma correction on a G90 because the G90 runs a 2.2 gamma with the stock gamma settings. You can also adjust the gamma by entering "expert mode" and pressing the "bias" and "gain" buttons at the same time on the remote.
There is peaking on the G90 neck cards using two surface mount caps near the video amps. There is also a peaking circuit on the BA board (= VIM for Marquee).
The G90 internal test patterns are useless for convergence as you have discovered. You are correct to use the Lumagen.
My pattern generator has the overscan patterns that I suggest. You can make your own in Paintshop or any image editing software. Just make a BMP image that is 1080x1920 and draw some borderlines.
Posted: Tue May 20, 2014 5:24 pm    Post subject:
Craig, can you post a closeup of your 1:1 pattern running 817P 72 hz so i know how it can look like.
Posted: Tue May 20, 2014 6:05 pm    Post subject:
Yeah, I can get to it soon.
I did find a pick of an old Moome HDMI card on my oscope passing a multiburst test pattern. This is 1080i 72Hz and 1080p 72Hz respectively.
You can see the peaking with the up-shoot before the multiburst. You can also see the horrible attenuation. Now you know why your old Moome board was not producing 1:1 for you at 818p Wink
Posted: Tue May 20, 2014 6:10 pm    Post subject:
Just wonder why my old moome card looks to match quite well at 817P 72hz, it must match the peaking in the G90 video chain. And my new card dont.
Posted: Tue May 20, 2014 6:14 pm    Post subject:
Craig i found a old shot of your G90 from 2010 running 1080P 60hz. Dont pick on my convergence and sharpness.. Wink
https://www.curtpalme.com/forum_archived/viewtopic.php@t=23601.html
Posted: Tue May 20, 2014 6:16 pm    Post subject:
Kurt, you might like this too:
http://www.avsforum.com/t/959357/g90-mod-attn-chuchuf-craigr-mike-parker-scott-phil-etc
http://www.avsforum.com/t/696950/g90-running-1080p-72hz
Posted: Tue May 20, 2014 6:24 pm    Post subject:
Thanks.. Ill run true those.. Thumbs Up
thewolfman
Posted: Tue May 20, 2014 7:16 pm    Post subject:
Sell some pj:s for a Barco 909 instead and you could make the perfect shot out between 3 brands. 3 Marquee's? Really? Smile
Posted: Tue May 20, 2014 8:34 pm    Post subject:
Honestly, those threads are antiquated. For example Mike P really likes the gamma chip on the G90 now and we have proven it passes much higher BW than in its specs. I don't think there is much current info in those threads.
Posted: Tue May 20, 2014 8:52 pm    Post subject:
Here is the Moome card who do the nice 817P 72hz.
I removed the add on gamma board, and soldered jumpers instead.
817P 72hz is the only resolution i can make it look like it do on the shots, the peaking G90 peaking is teasing on the other resolutions, so that its have quite a lot of color shift in the vertical lines depending contrast setting.
Posted: Tue May 20, 2014 8:54 pm    Post subject:
Has the peaking been removed on the last mods, and been replaced with real bandwidth.?
Posted: Wed May 21, 2014 6:17 am    Post subject:
Kurt, your Marquee is also full with peaking, it is maybe just tuned better for your requirements. The main purpose of peaking is to cancel the effect of the stray capacitances introduced by cables, traces, connectors which would kill the HF response, regardless of what high frequency components you use.
Posted: Wed May 21, 2014 6:49 am    Post subject:
There is some, standard it has a bit on the neckboards that i know about, and sure there is some VIM boards where peaking can be adjusted, but on a standard marquee its minimal.
Ill say it might be 20 times less than the G90, its very clear to see how peaking messes with the vertical resolution from 0-100IRE, color shift, in bad cases there is no output of high resolution vertical lines at low level.
Try do what i asked. run a fine grid pattern, and turn contrast all Down when putting it slowly up, how do the grid start. do this on a G90 and a Marquee, and be surprised.
Im running a standard marquee with 03VIM these days. So no mods there.
Posted: Wed May 21, 2014 7:09 am    Post subject:
Ill say it might be 30-50 times less than the G90, its very clear to see how peaking messes with the vertical resolution from 0-100IRE, color shift, in bad cases there is no output of high resolution vertical lines at low level.
Peaking generally not dependent from aplitude nor the frequency, think of peaking like a scope probe compensation (as it really is), if you know what I mean, once you set the square wave look good on a scope screen you can measure everything and it will be accurate. How you combine different peaking blocks in a circuit is a different story.
Look, here is a typical charachteristic of an RGB preamp IC which has contrast and brightness control circuit, a similar ic is used in the sony, while in the Marquee this function is made from discrete components. As you see with varying output level (=contrast) the response charachteristics also varying.
RGB preamp ic response
 Filesize:  34.91 KB
 Viewed:  12821 Time(s)
Posted: Wed May 21, 2014 7:35 am    Post subject:
I hear you, but the experience seems quite different, i have never seen any peaking not effected of the output level.
It just seems like there is no substitude to real bandwidth, peaking wont replace that ever in my opinion.
That a bit of peaking is good, or improves the image i agree, but when you have lets say 100Mhz bandwidth, and try to pump it up to respond to a 150Mhz signal, it just makes a lot of mess all the way from Black to White and depending the resolution.
So it wont hold the same color or performance as soon as resolution or light is changed in any parts of the image.
Im not refering to different input resolutions, but different resolutions in the image itself.
Posted: Wed May 21, 2014 8:09 am    Post subject:
It's all matter of the proper tuning... This is what is properly done on your marquee.
What is real bandwidth? For the high frequency limit the rise and fall times give a good estimation, but that does not mean that the frequency response is flat to it (this is what you want for accurate 'in-scene-low-resolution') this could even mean that more (or broader) peaking is needed to add the missing freqs. to the response!
Without peaking, you wouldn't be able to reach smooth transitions no matter what components you use, as already said the main purpose of the peaking is to cancel the unwanted parasitic effects, without any peaking the parasitic effects would overwhelm all efforts which was taken in the design process, to much peaking of course can fool the response too. The key is to apply just the right ammount of peaking -which is a hard task.
Posted: Wed May 21, 2014 8:13 am    Post subject:
Oh, I looked at the Marquee VNB schematics, on the latest one designed by tse, it contains 7 (seven) different peaking circuits by a quick look.
Posted: Wed May 21, 2014 9:03 am    Post subject:
No one have the latest boards.. So the ones before that is more relevant.
Now im sure we agree, its all about the right amount of peaking, my point is that the G90 have much lower real bandwidth and much much more peaking, and thats not a good combination.
I hope it can be changed.
Posted: Wed May 21, 2014 5:23 pm    Post subject:
I think Nashou has a set of them Twisted Evil Just for the record I counted 9 (nine) peaking components on the older VNB schematics.
YES
Probably because the peaking isn't set properly.
On a side note: on some NEC XG models the peaking level on the neckboards are menu selectable, and for experimenting this isn't hard to do on other machines, though not menu selectable but it may help to select the perfect combination.[/quote]
Page 3 of 9
