SONY G90 modifications / improvements ???
Posted: Fri Jun 27, 2014 3:35 am    Post subject:
David,
Your best bet is to call Craig directly and discuss what you would like him to do. He has a kid on the way or it might already have arrived, so he might be a little tied up. Wink
Posted: Fri Jun 27, 2014 11:20 am    Post subject:
CIR Engineering wrote:
stridsvognen wrote:
Craig, can you please post a picture of your G90 showing the croma multiburst on screen, and the green tube face of that pattern.
If possible both the 3D moome card, and the one before it.
What chroma burst are you using? Can you send me the pattern via email?
I don't think I have a chroma burst in any of my patter generators Shocked Strange that I don't have one.
I saw where you found an issue with chroma bandwidth in the Radiance. Did Lumagen get that addressed in the last FW update?
Also, I am beyond busy right now so I am going to be slow to help. The next couple months are going to be interesting...
Im using the Spears & Munsil blu ray disc, the one OPPO sell.
It also have a Croma alignment pattern.
Lumagen is on the Croma bandwidth, they changed something in the last FW, but nothing very usefull, now there is just a better balance in the vertical and horizontal croma.
And the last response i got also indicate its a problem in all the radiance models.
I just wonder why no one have noticed this before, as it seems to have been there for years, i cant revers my firmware to anything that makes it better, maybe its conected to the 3D models, as Nash posted a old croma burst from 2009, that looked perfect.
It has been quite fun playing with the croma multiburst, its hard to find any gear who get it right, the OPPO 83 is perfect, my new 103D have some issues in some settings, the Radiance have some serious issues, and my Marquee moome card seems to have a bit to, so if not carefull its easy to end up with a seriously bad Croma performance.
1st thing that needs atention is the new SONY moome card, its has a totally messed up bandwidth performance, kind of look like a Barco 909, and who want a bandwidth like that. Wink
Posted: Fri Jun 27, 2014 11:28 am    Post subject:
David1 wrote:
I thought the bandwith looked vg - It looks like I might have some loss in the luma and thinking that might be levels ??
But if the full 1080p is there in the chroma I think i'm 90% there. At 60 hz at least - would love to see what 72hz looks like
Craig - The chroma and luma multi patterns came from the Spears and Munsil HD disk - except for the resolution one that came from DVE.
and Yes MPLS is Minneapolis ...
How does my gamma look to you guys can you tell from the DVE resolution chart?
Lastly any insights in the gamma menu question ??
Thanks guys - We are the last of a dieing bred - Give Me CRT or Or Give Me Eyestrain -
The only way you might get a better level on you vertical 1:1 is douing your focus.
What color space do you send to the moome card. ill guess 4:4:4 or RGB, if so, try 4:2:2
I think the gama menu info you need is in this thread somewhere, i forgot the password sorry.
Think its something like..( Enter left right enter), or, ( enter up down enter), and you get into expert mode.
For sure its described in the manual.
David1
Posted: Fri Jun 27, 2014 6:46 pm    Post subject:
I tweaked the focus and got the rest of the vertical resolution so its super tight now.
The biggest flaw I am seeing in the picture is streaking anybody have any input on that ?
Does a G90 have a streaking problem?
I do have a drablet which I had off for all my tests but turned on does that streak .
David
Posted: Fri Jun 27, 2014 7:11 pm    Post subject:
David
The G90 does have streaking, but in most cases it should not be visible. If you are seeing a lot of streaking this is most likely due to black level, white level, gamma, and grayscale. A well tuned G90 does not readily impose streaking on the image.
I am not a big supporter of using screen shots because you have results that are distorted by the camera and the display that then shows the screen shots. However, your screen shots of Game of Thrones are really awful (not trying to be cruel, just making a point). You certainly have issues with all of the above.
Posted: Fri Jun 27, 2014 7:25 pm    Post subject:
Kurt, I think you may not understand the results you are seeing with the chroma burst pattern.
BD is compressed into 4:2:0 color space. BD players can only output in RGB 4:4:4, YCbCr 4:4:4, and YCbCr 4:2:2. Because of this, all BD players must upsample the 4:2:0 to one of the above color spaces. Because of this, it is simply not possible to get a correct response from a chroma burst pattern even if you are running with 1:1 pixel mapping. In all cases with 1080p the chroma is going to be upsampled before it leaves the BD player via HDMI.
When the Lumagen receives the already upsampled chroma information, the Lumagen then converts everything to high bit rate RGB. This will of course compound the chrom errors in the burst pattern further. There is simply nothing Lumagen can do to make the chroma burst pattern look correct from a BD. In fact, this will be the case on all 1080p displays. The only way to have a properly rendered test pattern would be to use a pattern generator sending a chroma burst in NATIVE YCbCr 4:2:2, YCbCr 4:4:4, or RGB 4:4:4.
With the new 4k standards HDMI 2.0 now supports YCbCr 4:2:0 directly. In these cases with HDMI 2.0 we will finally see correctly reproduced chroma burst patterns on displays. But this will only be for HDMI that supports YCbCr 4:2:0 on the output of the BD player or other HD source.
Moome is going to work on an HDMI 2.0 input card once the chips become available to him. They are still quite hard to get at this point in time.
Fortunately, chroma bandwidth is not really very important to the final image quality. Humans don't really see resolution well in chroma space. This is why luma response is so much more important and why luma data is not compressed as it is with the chroma data.
Just for testing in all my free time, I could draw up a chroma burst pattern and load it onto my QD780 and output it natively. That would show how the Moome, Lumagen, and G90 are truly doing because it would not be upsampled.
Posted: Fri Jun 27, 2014 7:58 pm    Post subject:
Kurt,
I just looked at the newest Moome IFB cards on my theater G90. I don't see any of the problems that I remember you talking about in this thread. I looked at the Lumagen cross-hatch test pattern and it looks normal to me. I looked at SMTPE 1:1 and it looks pretty decent to me there as well. There might be slightly more attenuation on the newest Moome cards compared to the v2's but it's not terribly attenuated.
Also keep in mind that on the G90 you will always see some attenuation. The attenuation has unusual characteristics though in that the amount of attenuation will not increase much as you go from 1080p 60Hz, 72Hz, and even 96Hz. The attenuation basically remains visibly about the same on the screen even as refresh rate is increased.
Let me know if there were other patterns that you wanted me to look at.
I'm going to try an experiment with the SM test patterns if I can figure it out...
You may also want to have a look at that pattern with your Oppo connected directly to the Moome board and with 12-bit color enabled. This upsampling may provide more data and make the burst look better (though it may not Wink.
Posted: Fri Jun 27, 2014 9:30 pm    Post subject:
Basically Kurt there is no industry standard way to upsample the 4:2:0 on the BD to output with HD HDMI. Because of this all results will be different.
I took eight photos of the chroma burst of the SM test disc. However, when I unloaded my camera, I only had seven shots so hopefully these are in the correct order. I think I forgot to shoot the chroma burst with the Oppo BDP-105D in YCbCr 4:2:2.
You can download full resolution copies of the photos in one zip file or look at the down sampled versions here.
Here is the zip file:
http://www.cir-engineering.com/bin/chroma/chroma_burst.zip
So here is what I think each photo is:
Moome IFB-FULLHD V3 & Oppo BDP105D YCbCr 422
Moome IFB-FULLHD V3 & Oppo BDP105D YCbCr 444
Moome IFB-FULLHD V3 & Oppo BDP105D RGB
Moome IFB-FULLHD V3 & DUNE Base 3.0 YCbCr 444
Moome IFB-FULLHD V2 & DUNE Base 3.0 YCbCr 444
Moome IFB-FULLHD V2 & Oppo BDP105D RGB
Moome IFB-FULLHD V2 & Oppo BDP105D YCbCr 444
Frankly, with the projector calibrated to either Moome board I can't tell a difference with real world video between the two Moome boards, except maybe in the rarest of images.
Last edited by CIR Engineering on Sat Jun 28, 2014 6:30 pm; edited 1 time in total
Posted: Sat Jun 28, 2014 12:53 am    Post subject:
There is a very nice manual to the Spears & Munsil disc, explaining how the croma multiburst have to look like.
And i expect the Radiance to pass 4:2:2 if its set to 4:2:2 in and out, so i get the same croma result with and without the Radiance.
I sure dont agree that its not visible, sure it depends the display you use, but a good quality display i find it very important.
Can you try shoot a picture of the green tube face while running the croma multiburst, 422 direct out of the oppo, and using the very last moome card.
Posted: Sat Jun 28, 2014 2:19 pm    Post subject:
Kurt, what do you think you are supposed to see in the green tube with the S&M chroma burst pattern?
Posted: Sat Jun 28, 2014 3:22 pm    Post subject:
I think im surposed to see a low level output, where all lines have the same level, from high to low resolution.
Looks like the green is mixed with the blue channel.
Also looking all colors you need to be able to see all red lines with same level and all blue lines with same level. Not changing with resolution.
My JVC and my Sony flat screen can do the croma multiburst right, if using a player who do it right to. Like the OPPO 83, or the right settings on the OPPO 103D
Passing it true the Radiance shows high frequence problems.
The green seems to be hard to the CRT if it has limited bandwidth, and corrected with to much peaking. Then you will need to turn up the output on the green tube to display the high resolution part, so like my SONY V3 moome card, i cant see how the croma is handled, as the bandwidth limits the low level output.
Same if you look at the luma 1:1 pattern, and turn contrast down, you see that its not possible to hold the same output on the vertical if the bandwidth is based on peaking.
Quote Spears & Munsil
Chroma Multiburst
This is a multiburst pattern using the chroma channels.
Because the chroma channels are stored on disc at half the resolution of luma in both horizontal and vertical directions, the chroma bursts have twice the wavelength of the equivalent luma bursts. This pattern shows whether or not the full chroma resolution is making it all the way to the display. For example, if the highest-frequency vertical burst is a solid color or the lines are very dim, that suggests that some component in the signal chain is rolling off or downscaling vertically the chroma channel.
http://www.spearsandmunsil.com/portfolio/pattern-help-text/
Posted: Sat Jun 28, 2014 5:36 pm    Post subject:
Here is the full quote from Stacey's website:
Chroma Multiburst
This pattern is the equivalent to the Luma Multiburst pattern, but for chroma. Because chroma is upsampled when converting 4:2:0 YCbCr to RGB, in a sense every display scales this pattern, even a native 1080p display. In some cases the player scales the chroma vertically to produce 4:2:2 YCbCr, and then the display scales it horizontally while converting to RGB. Or the player may output RGB, in which case the player is doing the chroma scaling. For players that have different output options over HDMI, you can change them while viewing this pattern and see the differences in how the player and the display handle the chroma channel. The individual sine waves in the center of each burst should look even, with no color shifts or intensity shifts on either side of the peaks. The waves should look smooth and not posterized. If the display is a 720p display, it should be possible for it to show all of the bursts cleanly, though the thinnest lines may look somewhat uneven. If the last burst turns gray, it tells you that the display is scaling the image down in YCbCr, which produces a slightly lower quality image than converting the 1080p signal to RGB and then scaling it to the display resolution.
Posted: Sat Jun 28, 2014 6:20 pm    Post subject:
Kurt,
My analysis is below, but just so you know, this is the last time I am going to look at the SM chroma burst pattern for you. The pattern violates Nyquist and is not showing anything of value in terms of real world image quality. The only thing the SM chroma burst pattern is good for is evaluating switches, receivers, signal boosters, or other devices that are NOT supposed to be processing video in order to make sure that they are not processing the signal. Distortion in this pattern does not indicate an error in the Radiance processing nor does it signify any sort of peaking or bandwidth restrictions in the G90 or Moome cards. This also applies to the Moome boards as well because they are converting digital data to analog which will most likely distort the pattern.
The Radiance's job is to process video and as such will distort the pattern. Lumagen is capable of forcing the pattern to look correct with a firmware update, but this improvement in the test pattern will not translate to any improvement in real world video. Essentially, the pattern will be made to look correct as a special case, which will help the test pattern, but not actual image quality.
Looking at the SM chroma burst on my PC would suggest that there are only 18 parts green in the 1:1 part of the chroma burst (about 1 IRE above black). Furthermore, neither the red nor the blue are above even 50% stimulus in the 1:1 portion of the SM chroma pattern and are at higher stimulus in other parts of the test pattern. So in the lower bandwidth parts of the pattern the lines are brighter because they are at a higher stimulus.
On the Oppo 105D directly to the Moome v3 I see perfect resolution looking into the tube on all three tubes for RGB and YCbCr444. For YCbCr422 there is some vertical attenuation in green. This is on Oppo HDMI output 1, on output 2 there may be totally different results as the processing is much different. As some proof that the information is still present in the signal even though it doesn't show in the test pattern, when running through the Radiance with the same configuration I see restoration of the vertical and full attenuation in the horizontal.
Due to there only being three steps above black in the SM pattern for green 1:1, I would not be surprised if after passing through any processing there is no response in green 1:1 on the chroma burst. The Lumagen is there to alter the signal and make corrections so what you put in will not be what you get out. The Radiance is converting all incoming signals to RGB.
Also realize that when you look at the Oppo set to 1080p 60Hz, the Oppo is processing. When you look at the Oppo in source direct 24Hz, then most of the Oppo processing is disabled. So comparing an Oppo outputting 1080p 60Hz direct to the Moome is not the same comparison as looking at the Oppo in source direct going through the Radiance. This is not an apples to apples test.
Here is the Oppo BDP-105D on HDMI output 2 showing 1080p 60Hz on the G90 through the Moome newest v3 batch.
Here is the Oppo BDP-105D on HDMI output 2 showing 1080p 24Hz in source direct mode through the Moome newest v3 batch.
I would suggest spending time evaluating and tweaking areas of the image signal that will actually translate into real world performance improvements. But if you want to continue to harp on the SM chroma burst pattern then have fun on your journey down the rabbit hole.
Regards,
Posted: Sat Jun 28, 2014 7:13 pm    Post subject:
Your right about the 24hz out from an oppo. I forgot to mention in my screen shot the oppo is 1080p Source direct 24hz, and the radiance also is outputting 24hz the TV-one C2-2250 was set to 96hz in my screen shot.
nashou
Posted: Sat Jun 28, 2014 8:11 pm    Post subject:
Kurt,
Regards,
That is the way I interpreted their explanation. It has little to do with the display itself, but everything upstream.
Posted: Sat Jun 28, 2014 9:37 pm    Post subject:
I wonder.
We/ i like bandwidth to resolve the luma 1:1, and it for sure makes a huge difference.
When comes to the croma who already is ½ the resolution of whats in the luma channel, we dont care, or its not important to the image if we cant resolve the finest pattern, who must be a 2;2 resolution.
In other words, a format with full color resolution/ a disc with native 4:4:4 will look the same as a disc with 4:2:0.?
For the Radiance, why is it not a helthy goal to have perfect color space conversion, where nothing is lost.?
Im ok with that some dont see a difference no matter how the croma is handled around the chain, and think its a joke to test and find the most perfect path, i guess its a bit the same as when some have a CRT with lousy bandwidth, they also dont seems to share my enthusiasm about full bandwidth to resolve whatever you trow into the CRT.
For now im quite happy how my OPPO 103D HDMI2 out 4:2:2 1080P60hz looks on my Marquee, and i for sure see a difference on movie material changing to HDMI 1 out of the oppo, or putting the Radiance into the chain.
I have looked at different video processors, HDMI and RGBHV out, DVDO VP50 Crystalio 2 Lumagen HDQ Calibre Vantage, Radiance XS. Different players as the Oppo 83/ 103D Denon 4010 and A1UD. And i have 6 moome cards and a Hdfury3
I also use my JVC x7, Sony LCD screen, G90 and my Marquee to compare different kind of performance. That way ill be able to know what part of the chain do what.
And i agree that they dont perform the same, some are perfects, others close, and some far from.
Wonder how low we can put the color resolution before its visible to everyone.
Ill keep hunting for better performance wherever i can find it, and right now the croma is where i focus, and i cant use the G90 to evaluate that, as it will never be able to show any useful difference in movie material, it simply dont have the bandwidth, and it has way to much noise who washes out the image. Just as any other standard CRT i have seen.
Posted: Sat Jun 28, 2014 11:51 pm    Post subject:
nashou
I have not been able to find any connection between frame rate and croma performance, and for sure i have not seen any problems on the OPPO 83 no matter what color space or frame rate.
I also not been able to connect it to any adjustments or settings in the Radiance.
Posted: Sun Jun 29, 2014 10:10 am    Post subject:
Kurt in your eyes you have about 7 million receptors to percieve colors, and have about 75 to 150 million receptors to percieve brightness, as Craig already mentioned the human eye have much less resolution in color than in brightnes, as you can now see the difference is in the factor of 10!
Posted: Sun Jun 29, 2014 1:58 pm    Post subject:
I have no idea, ill have to trust what i feel and see. And i goes with what i like best, if you prefer less color resolution, and say you cant see a difference, ill trust thats how it works for you.
This all started the day i plugged my Denon DVD A1UD direct into the moome card, and was thinking.. WOW
After that i was trying to find a reason to the difference, and the only thing i can find that behaves different is the croma.
I have almost never run a blu ray player direct into my CRT, always used the Radiance, and from the first day i got the radiance i had a feeling it changed something, without anything activated in the CMS or any other adjustments.
I can read what you all say, but when it dont add up with what i see on my screen, i share it, and im aware as i also experienced that many displays wont display much difference at all, but i just have a hole different night and day experience with my moddet Marquee, it like cuts it out and slap me in the face.
If its not important, or visual, how far up the pattern can you mute the colors before its visible to everyone.
Im all in for make it right, and remove the doubt.
Posted: Sun Jun 29, 2014 2:06 pm    Post subject:
You hopelessly drifting towards the world of HTPCs... Smile
Page 8 of 9
