| Posted: Wed Apr 23, 2014 6:57 am Post subject: |
| shelleybear wrote: | | All but two of the boards that I can see are 1096339. |
Part Numbers look like R7622696. Which is the part number for the board on Curts site and the one Decibel has posted. There is another version that does not have the daughter board.
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Wed Apr 23, 2014 7:12 am Post subject: |
Yes exist an V-board without daughter board.
I have one. Today I'll post the p/n and pictures.
_________________ Domenico (Barco fan!)
Decibel
| Posted: Wed Apr 23, 2014 8:49 am Post subject: |
| Decibel wrote: | Yes exist an V-board without daughter board.
I have one. Today I'll post the p/n and pictures. |
R7628085
The little board in picture is a orbiting board.
Hulio
| Posted: Wed Apr 23, 2014 10:13 am Post subject: |
There you have the picture from Decibel. The pots for R and B vertical shift are on the lower left side.
Like Curt already said, i also think you turned by mistake the vert. amplitude pots instead. Use his advise to get that back right.
Domenico, i'm not hanging the smart xss here but seeing the shape of that small board, could be the HDTV module R762268T ?
| Posted: Wed Apr 23, 2014 11:06 am Post subject: |
| Hulio wrote: | There you have the picture from Decibel. The pots for R and B vertical shift are on the lower left side.
Domenico, i'm not hanging the smart xss here but seeing the shape of that small board, could be the HDTV module R762268T ? |
Most likely the Orbit board.
shelleybear
| Posted: Wed Apr 23, 2014 2:13 pm Post subject: |
Decibel, thanks for the help, but tis is the same board Curt sent me the last time, and we have already seen that the configuration is different.
What we are trying to determine is where on the board the V-shift pots are.
| Posted: Wed Apr 23, 2014 2:21 pm Post subject: |
Shelley, can you post a pic of your board? One glance at the pic, and I can tell you where they are.
shelleybear
| Posted: Thu Apr 24, 2014 3:59 pm Post subject: |
I'll get on it.
Decibel
| Posted: Thu Apr 24, 2014 9:23 pm Post subject: |
| Hulio wrote: |
I don't know.
I never owned HDTV board.
The picture that I've posted come from Curt's website into Zenith 1200 section.
http://www.curtpalme.com/Zenith1200_Layout5.shtm
I think that's orbiting board.
http://www.barco.com/tde/(2552531702302320)/R5975385/05/Barco_InstallationManual_R5975385_05__Orbiting-Kit.pdf
(copy and paste all row above in your browser for orbiting board manual)
Hulio
| Posted: Thu Apr 24, 2014 10:48 pm Post subject: |
I am sure that in not the orbiting module. I owned the HDTV module in the past ( AKA tri-level sync board ).
The orbiting module is rectangular and have only two wire connections.
On the HDTV board there are three connection jumpers and also the shape is a bit different. Here a pic of my former HDTV module.
| Description: |
| Filesize: |
199.95 KB |
| Viewed: |
3371 Time(s) |
Decibel
| Posted: Thu Apr 24, 2014 10:58 pm Post subject: |
ok
shelleybear
| Posted: Sat May 03, 2014 3:52 am Post subject: Vertical Update |
| Curt Palme wrote: | Ok, you're adjusting the wrong pots! One pair of pots adjusts the V size of the R and B tubes, the other set of pots that are longer in length with a little brass screw at the top end facing you are the V shift pots. Those are the ones you need to adjust.
Once you've got the center cross overlapped with the V shift pots, then go back into the main convergence test pattern, and adjust the V size controls so that the size of all three images are pretty close to equal top and bottom. That will minimize use of the convergence controls, which is a good thing. |
Curt, I found one pot with two metal screws side by side.
one has a red dot.
They are in the same general location as the ones in the diagram.
That is, to the right of V-size adjustment.
What threw me off, is the fact that there was only a single pot with two screws, rather then two pots with one each.
What sort of tool can I use to adjust these as the plastic screwdriver bits are way too large.
I was thinking standard Jewelers screwdrivers.
Either way, I will not touch them until I get your answer.
Shelley
Apfelmousse
| Posted: Sat May 03, 2014 4:12 am Post subject: |
Hi all,
the thread reminds me of my setup experience.
I was wondering: There is a pot-control of red and blue to align with green. Thats OK, in theory you do not need 3 pots to align 3 items with each other, 2 are sufficient.
But how do you align the green tube if it should be necessary, if the raster is not centered there? Is that only possible electronically, i.e. through the menus? If so, why do they have a pot alignment for red and blue anyway??
cheers
Martin
| Posted: Sat May 03, 2014 7:04 am Post subject: Re: Vertical Update |
| shelleybear wrote: | | Curt Palme wrote: | Ok, you're adjusting the wrong pots! One pair of pots adjusts the V size of the R and B tubes, the other set of pots that are longer in length with a little brass screw at the top end facing you are the V shift pots. Those are the ones you need to adjust.
one has a red dot.
Shelley |
You can use a normal screwdriver.
