Review: Greg Eisemann Barco 909 modifications
Goto page Previous  1, 2, 3, 4 ... 17, 18, 19  Next
Posted: Sun Apr 06, 2014 6:46 am    Post subject:
Do any of these internals report to Windows what their name is?
As in do they show in available displays as a MOOME or a HDF3?
VideoGrabber
Posted: Sun Apr 06, 2014 8:33 am    Post subject:
Francisco wrote:
SMPTE pictures are taken with same camera/lens/settings etc.
Good. But not the same distance, or position.
- Tim
Posted: Sun Apr 06, 2014 9:56 am    Post subject:
CIR Engineering wrote:
stridsvognen wrote:
Nice review.
Is it possible you can try connect the Ext. Moome V2 and see how that looks now, and do some closeup pictures of the 1:1 patterns.
The HDMI board is 100% sure a HD Fury 3
That would be a good idea.
However, the thing about the Moome boxes is that on the v2 there are two sub-versions. One can resolve 1080p 60Hz with only about 5% attenuation and the other has about 70% attenuation. Obviously depending on which one you happen to have will result in a tremendous difference in the 1:1 pattern.
If you have a scope you can run 1080p 60Hz from the Moome EXT to the scope and look at a 1:1 pattern. If it is nearly fully resolved than it's the good one. If you have the bad one, you can change the filter caps and then it is fixed to full resolution.
I also think that a close up pic of the 1:1 with 1080P 60hz, vs 1080P 72 hz would be interesting to see.
I think anyone that have seen a CRT resolving a decent 1080P 72hz will say thats way better than 60hz, and there is no way back after that.
Francisco
Posted: Sun Apr 06, 2014 10:25 am    Post subject:
Patience guys, I will do test with fixed camera position and not taken by hand.
Will test 1080p 60hz and 817p 72hz
With: - Eisemann Hdmi solution
- Ext. Moome V2 on port5
- Int. Moome V3 port3
Posted: Sun Apr 06, 2014 10:41 am    Post subject:
It will make more meaning to test different bandwidth, 1080P 60hz and 817p 72 hz should be more or less the same result.
Try do the green tube 1:1 with different framerates, from 100Mhz and up to 200Mhz then you will see where it start to role off, if no peaking is addet, but also a closeup of the 1:1 will show if there is peaking or other wierd behaviours.
After that try all 3 tubes see if it holds the color balance at different bandwidth, and output levels.
Peaking sometimes makes it possible to adjust a nice 0-100% IRE 1:1 on off, but with a different output its way off.
Why im asking is im curious if Greg have made a true bandwidth improvement, or addet peaking to simulate a better bandwidth.
Also with the measurements of the HD Fury 3 and what i have seen it wont handle 1080P 60hz, unless he improved the bandwidth of that to.
redfox001
Posted: Sun Apr 06, 2014 11:11 am    Post subject:
Indead not to say anything negative but Francisco said that the pattern hardly improved but he did perceive a much sharper image. That made me think that the bandwidth had not improved very much but now I understand that even peaking should have improved the bandwidth so than peaking could not explain for the perception. Far beyond my knowledge this Very Happy I mean there is no digital processing added is there? Or does the fury...?
On the other hand one could conclude that the bandwith has improved a lot and that shows in the picture but only a little bit in the pattern Wink
Posted: Sun Apr 06, 2014 11:33 am    Post subject:
From what has been shown from 909 bandwidth before, i think that just a bit better bandwidth will make a huge improvement.
Ideal i might think the Barco would improve greatly running 817P 60hz. That might make the vertical resolving power fit the benefits of the LUG tubes thin horisontal lines.
Francisco
Posted: Sun Apr 06, 2014 9:23 pm    Post subject:
Okay will try but I don't have anything to measure from 100mhz up to 200mhz. I don't have a radiance which will show this. I'm working on my HTPC to get it ready for high resolution output, both digital and analog. Also pixel clock is something different than bandwidth I assume?
maybe you can give me some resolutions with refresh rates and front and back porches to try. I will put them in with HTPC and see what happens. Take pictures from same spot camera etc. etc. and post here. But it will take some time as I do have a life Very Happy
VideoGrabber
Posted: Mon Apr 07, 2014 12:09 am    Post subject:
They are related. If you remove the porches from the equation, they're directly proportional, if you keep the refresh rate constant.
That's a good plan.
- Tim
Posted: Mon Apr 07, 2014 1:34 am    Post subject:
At the risk of repeating myself ans since i see no response:
Posted: Mon Apr 07, 2014 8:57 am    Post subject:
Who built the internal Moome Port3 combination? Picture please.
Posted: Mon Apr 07, 2014 8:59 am    Post subject:
For me Case I don't use a HTPC rather I use a Lumagen a Moome MUX-HD and a Blu Ray Player but there must be someone here that has the required combination.
Posted: Mon Apr 07, 2014 10:17 am    Post subject:
Cheers mate yeah, have you got a spare laptop with a DVI output?
Posted: Mon Apr 07, 2014 1:21 pm    Post subject:
Case moomes EDID he uses is a NEC EDID. on my laptop the Moome internals and the Ext v2 all show up as a NEC display.
Posted: Mon Apr 07, 2014 3:40 pm    Post subject:
Well my idea would be to start with 1080P resolution. 2200x1125x50 = 123750000hz/ 123,75Mhz something like that, whatever porch settings you use for 1080P and then just find the pixel clock where the 1:1 looks perfect, and see how much you can rise the framerate before the vertical lines start to get darker, and notice if they are brighter with a low pixel clock/ Bandwidth.
If you need to go below 123Mhz try reduce H total as long you can get a good picture at the 1:1 area of the pattern dont worry to much about the rest.
Ill surgest to keep it digital if using a PC solution, like it will be imposible to trust or confirm the bandwidth performance of the analog output. Unless you have something to compare with.
Ohh and please post what pixel clock/ bandwidth you are running every time you post a screen shot of the 1:1 pattern so its possible to keep track.
geisemann
Posted: Mon Apr 07, 2014 7:16 pm    Post subject: Circurt Changes
To All:
I wanted to answer some questions:
We actually change all the opamps in the switcher and the RGB driver and when doing that it created a lot of oscillation and re-creation of noise in the video chain! It was headache to track down all the noise. We had to add filters to each chip on both the power rails and also the input and output legs. We had to also alter the circuit and add filters. So this work took a lot of time with a spectrum analyzer to find the 2-3 harmonic frequencies to eliminate. The result is the new gen OP-amps can really do there work to amp the video signal.
The higher the BW of the op amp the more risk of noise of oscillation. The good news is the higher the BW the better the picture and more video information is brought though and not muted or distorted.
The op amps we used are approx 2GHZ vs the old Barco 800MHZ so the increase is substantial. The results will be only as good as the condition of the tubes and focus of your tubes. We took the numbers off the chips so you cannot reverse engineer. In the past other people have tried to copy the mods with no success and we keep making changes as we get customer feedback to it be difficult to make a copy then in a month have a new version with a new chip. The mods we made 2 years ago are almost complete different than the ones we make today.
We grid the numbers off the of chips and we also change not one but many many resistors on the cards so you have to un-solder each resistor to check the values and caps etc.
The Fury product wile we use some of the same core modules to save cost we do heavy reworks of this card too. So its not same product and we have made our own custom firmware. There were several problems with the original design.
The internal solution bypasses 75 ohm connectors, motherboard, and connectors in the cards resulting in a much better, less noise and sharper image basically a more direct interface keyed to the video circuit. The old port 3 circuits were stripped off the switcher card as the BW was not acceptable and new transistors and interface capacitors were placed in to allow for the higher BW. The original port 3 card had very poor BW and should never be used in a projector.
I hope that helps some.
Greg
www.eisemann-theater.com
Posted: Mon Apr 07, 2014 7:54 pm    Post subject:
Greg.
What is the bandwidth of the 909 after instaling the complete mod set.?
How high will it go before visible roleoff on the 1:1 pattern, and is there any peaking built into your boards.?
Francisco
Posted: Mon Apr 07, 2014 10:40 pm    Post subject:
Moome shows as: Nec
Modified Fury as: Eisemann
Posted: Tue Apr 08, 2014 5:44 am    Post subject:
Moome shows as: Nec
Thanks mate Smile
geisemann
Posted: Tue Apr 08, 2014 12:43 pm    Post subject: BW
Hi
I don't add any peaking. Peaking is tricky and I leave that up to the customer they need to add more or less based on preference. All peaking has been turned off it looks like in these photos. You can add peaking in the Barco Menu. That being said these pictures look very soft. Not sure if its the tubes, split pack config, or the calibration of the pole magnetic's?
I suspect a split back has much longer cable feeds to the neck cards causing more PF of loss in the cables. This will make the image softer. I hope barco compensated by using large RGB cables but I suspect they didn't.
I recommend people with split packs to look at these cables and possibly upgrade the Video feed to the neck cards ..
Some MOD specs:
Original cables from Switcher to RGB driver 60PF of capacitance. 17 PF after new lower loss RGB cables used. Factor of 3.
BW of original switcher at a gain of 2 card was aprox 650 MHZ before the mod after the mod 2.2 GHZ Factor of 3.3
BW of original RGB driver card at a gain of 5 was aprox 400 MHZ before and after the mod 860 MHZ Factor of 2
We have a custom neck card mod we are going to give this customer to give him better resolution. He will also be installing simulation grade new P19lug tubes so that should give him a big boost in sharpness aprox 25- 35% The green is the most important and I believe its has a standard resolution Panasonic standard oem Barco tube. We custom order our tubes and pay extra for better glass and gun.
So we are not done yet with this unit.
Again I have not the sharpness difference between split pack / regular 909 and am slightly concerned by larger interconnect cables.
GREG
Page 3 of 19
