| Posted: Fri Apr 04, 2014 9:45 pm Post subject: |
I havent had any issues with mine apart from the quad. Twice. Although this one is working perfectly well.
Ive got abit over 6,500 hours from July 2001. Tubes look really nice til you turn the set on... Green and blue have static burn in of a Katy Appleton DVD menu, that wouldve had to be there a very long time to get like it is. Ive got a new set of tubes i will get to installing sometime soon.
ElTopo
| Posted: Sat Apr 05, 2014 11:53 am Post subject: |
How many CineMax/Cine9 have been sold worldwide ?
redfox001
| Posted: Sat Apr 05, 2014 11:56 am Post subject: |
I am still trying to get a clear picture of what is improved in the Cine 9 with respect to the 1209/809. I see that the electromagnetic focus is a clear improvement with 6 poles to get a smaller spotsize.
Also there are more convergence zones in the software?
But the astig is the same 6 pole magnet as the 809.
Also the video out board has much higher bandwith.
Did I forget something? Seems to me that if you mod the video out board (Eisemann) the differences might not be so big?
| Posted: Sat Apr 05, 2014 3:53 pm Post subject: |
| ElTopo wrote: | | How many CineMax/Cine9 have been sold worldwide ? |
Does it matter?
Hulio
| Posted: Sat Apr 05, 2014 4:29 pm Post subject: |
A lot of things has changed with the design of BR909 chassis (CineMax/Cine 9).
To spare myself a lot of typo, here two technical documents from Barco about the "digitalization" of the chassis.
| Description: |
 Download |
| Filename: |
BR909 Technical Notes_SMPS (R763142).doc |
| Filesize: |
119 KB |
| Downloaded: |
531 Time(s) |
| Description: |
 Download |
| Filename: |
BR909 Technical Notes_RGB Socket (R763027) and RGB OUTPUT (R763027S).doc |
| Filesize: |
28.5 KB |
| Downloaded: |
305 Time(s) |
redfox001
| Posted: Sat Apr 05, 2014 5:35 pm Post subject: |
Ok, a lot has changed. Among others the waveforms are generated digital much more precise. Hmmmm.
Ok she gets more and more beautiful but I have a stupid setup question. The green line is lower than red and blue. Does this mean that she is not hanging under 10,5 degrees (I mean frame horizontal)? I checked with a leveler tool (waterpas) and that seemed ok. All convergence are on 50 and I can't correct with max convergence.
| Posted: Sat Apr 05, 2014 5:58 pm Post subject: |
It looks like your skew is not well matched with the green, blue, and red. You should set your skew to zero and then rotate the deflection magnetics until green is plumb to the horizon. Then match red and blue to green by rotating their deflection magnets. After that, use the skew adjustments to touch up red and blue. Then use the skew adjustments to match and straighten the vertical.
Also, is it possible that your scheimpflug on any or all of the tubes is way out of adjustment. Scheimpflug will move the image up, down, left, and right. If it's too far out than you may not be able to correct it with electronic controls.
ps I haven't read your thread so sorry if I mentioned something that was already covered.
| Posted: Sat Apr 05, 2014 6:00 pm Post subject: |
You have to center the rasters on tubeface on all three tubes., if you find a perfectly centered raster projecting to the wrong part of the screen then you have to accomodate the projector alignment (or move the screen )
redfox001
| Posted: Sat Apr 05, 2014 6:35 pm Post subject: |
| CIR Engineering wrote: | It looks like your skew is not well matched with the green, blue, and red. You should set your skew to zero and then rotate the deflection magnetics until green is plumb to the horizon. Then match red and blue to green by rotating their deflection magnets. After that, use the skew adjustments to touch up red and blue. Then use the skew adjustments to match and straighten the vertical.
craigr |
Ok I checked the skew was all 50 so only the sheimpflug seems to be left as the lenses and tubes are tightly fitted.
By the way I am starting to see some of the sharpness this projector is producing and this does not seem less than my sony vw100 or the jvc hd350 that I had before. Not much in the centre at this moment.
redfox001
| Posted: Sat Apr 05, 2014 8:14 pm Post subject: |
When I set all controls on 50 I see blue and red making a symmetric curve but green is going from top left to lower right getting more and more lower than the other two.
I noticed that the focus coil, the astig magnet and the deflection coil does not change that and because red and blue are symmetric it seems that the projector is hanging right with respect to the screen.
Looking into the tubes green might be a little higher as raster but perfectly centered. Hard to tell. I can shift the raster relative but that is not more than I can shift with the convergence and max is not enough.
Have to check sheimpflug tomorrow raster shift could not explain that green is not level with red and blue I guess?
Francisco
Joined: 05 Apr 2007 Posts: 305 Location: The Netherlands
| Posted: Sat Apr 05, 2014 8:43 pm Post subject: |
As Gjaky says, first while everything is on 49 align all rasters on tube face the same. They need to be on same place on tube face and size. Use trimpots to adjust this first. remember try to minimize electronically adjustments much as possible.
_________________ Philips vacuum cleaner | Trystar double toaster | Car radio with orange plastic memory arrows | Class A Fridge
redfox001
| Posted: Sat Apr 05, 2014 8:46 pm Post subject: |
| Francisco wrote: | | As Gjaky says, first while everything is on 49 align all rasters on tube face the same. They need to be on same place on tube face and size. Use trimpots to adjust this first. remember try to minimize electronically adjustments much as possible. |
Ok I guess I have to use the trimpot than a little. Thanks.
| Posted: Sat Apr 05, 2014 9:27 pm Post subject: |
To get red and blue images centered you first need to get them very close, do most of the setup, then they will need moving again with raster shift and you will need to reaim the tubes. As you adjust the red and blue to suit the green, you will be dragging their image towards one edge of the tube face.
Centering height wise on the tube face is a good place to start, but no reason you cant raster shift red and blue to line up with green.
ElTopo
| Posted: Sun Apr 06, 2014 7:23 am Post subject: |
Green looks good to me. Red and Blue need to be aligned vertically with the trimpots of the vertical board.
Had this on my Cine9 too.
Correct, keep electronic adjustments at minimum.
redfox001
| Posted: Sun Apr 06, 2014 9:40 am Post subject: |
| ElTopo wrote: | Green looks good to me. Red and Blue need to be aligned vertically with the trimpots of the vertical board.
Correct, keep electronic adjustments at minimum. |
Yes thanks I'll try that today.
I have had a strange thing happening again. When connecting a ps3 on the hdmi the machine powered up but powered down immediately again. This problem is solved and a known issue of the internal HDMI solution. Have to turn on the projector first than all is ok.
I post a picture of my voltages some of them seem off (210/191). How much is the tolerance for these voltages?
Some more information none of these restarts gave an entree in the diagnostic log. The last entree is from one hour run time before and says EHT fail = yes and SF = yes. So that one belongs to the misplaced connector.
This all gives me the feeling that the Cine MAX is performing ok now and that the troubles are caused by the internal HDMI.
redfox001
| Posted: Sun Apr 06, 2014 12:38 pm Post subject: |
Ok this one is confirmed. First turn on the projector and than the source. That makes sense.
On to the scheimpflug. The manual says to losen two screws on the top. The sticker says to losen screws on the front. How confusing Hope this will be my only problem today
Hulio
| Posted: Sun Apr 06, 2014 12:56 pm Post subject: |
Top screws are actualy the excentrics that will fine-tune the scheimpflug but they are locked with the front screws.
So first unlock ( don't take them out ) the front screws, get your scheimpflug as good as it gets with the top screws and secure back with front screws.
redfox001
| Posted: Sun Apr 06, 2014 5:29 pm Post subject: |
No where near perfect yet but I don't have to be she is very forgiving. My God this picture is alive and deep! Very much better then all the digital I ever had. So glad I made the switch. Optical is not sharp at the bottom yet, geometrie is rough, convergence too. But all these pictures are so beautiful. One shot from 'continuum' and I am behind with that series (noise comes from the iphone camera)
redfox001
| Posted: Sun Apr 06, 2014 5:50 pm Post subject: |
Ain't that a desktop
redfox001
| Posted: Sun Apr 06, 2014 10:10 pm Post subject: |
Looked at a part of Gravity and man that is a complete different movie. With no doubt this is the image I am looking for.
On the negative side I find the MAX noisy and I wonder if stretching the electronics to far made her more noisy? The temperature was 28 to 29 degrees. I did not correct the raster enough with the potmeters and had to do a lot of convergence correction (max).
Seems also that under the MAX there is more noise than in front.
I am considering my split pack mod again. I know there is a risk but if I can't get the noise down on other ways I might lengthen the cables and use the split pack front housing. After all I know what can go wrong now with these wires and connectors. Still I prefer not to of cause.
