New Cine max topic
Goto page Previous  1, 2, 3 ... 15, 16, 17 ... 22, 23, 24  Next
redfox001
Posted: Sat Jun 28, 2014 12:37 pm    Post subject:
The Mac has no vga output anymore. Perhaps there is some box for that?
The HDF2 does not work either power to low or sync needs T piece or both and I have neither. I am glad it was very cheap Very Happy
redfox001
Posted: Sat Jun 28, 2014 12:43 pm    Post subject:
I might only need this cable to get analogue output?
http://store.apple.com/nl/product/MB572Z/B/mini-displayport-naar-vga-adapter
redfox001
Posted: Sun Jun 29, 2014 2:00 pm    Post subject:
In the meantime I think I fixed the remote hatch. Very Happy Perhaps a nice tip to use velcro.
ElTopo
Posted: Sun Jun 29, 2014 5:33 pm    Post subject:
What ceiling bracket have you installed ?
Barco Cine 9 the one and only
redfox001
Posted: Sun Jun 29, 2014 6:50 pm    Post subject:
Flamco rail R4.
redfox001
Posted: Sun Jun 29, 2014 10:05 pm    Post subject:
I can't get the hdfury2 to work not even with negative sync so I guess I need the power adapter but instead I will try this apple VGA cable first because I read that even Soleboy had a Moome box so we can't rule Moome out yet.
I also wonder if this VGA cable might have better bandwith?
Posted: Mon Jun 30, 2014 3:50 am    Post subject:
Hard to say...
redfox001
Posted: Mon Jun 30, 2014 7:43 am    Post subject:
CasetheCorvetteman wrote:
Hard to say...
Generally apple does not do real bad implementations but they might nog have optimised the way moome did. But than again on port 5 might be an improvement. I think it should be possible to work with very short bnc cables. If I can find some displayport extension cable.
Posted: Mon Jun 30, 2014 8:36 am    Post subject:
The apple one probably wont be a converter as such but just an interface, but i dont know.
redfox001
Posted: Mon Jun 30, 2014 9:56 am    Post subject:
It really contains firmware and dacs. They made it very small.
Posted: Mon Jun 30, 2014 11:19 am    Post subject:
I don't know how Apple is doing nowadays, but this is looking quite similar (don't be foolded by the different input connector)
http://www.misco.co.uk/product/200981/LINDY-HDMI-to-VGA-Adapter
If so this should be in it:
No HDCP of course, and this fits right in Apple's policy.
redfox001
Posted: Mon Jun 30, 2014 12:27 pm    Post subject:
Why are we working with Moome or HDFury products? Very Happy
redfox001
Posted: Mon Jun 30, 2014 8:31 pm    Post subject:
I can not get the Barco to vertical sync. I tried several normal resolutions with positive and negative sync. In the barco menu I tried fast and slow sync and clamping options but it keeps vertical scrolling.
The only thing it syncs to is a windows pc.
Posted: Tue Jul 01, 2014 1:28 am    Post subject:
No idea there, mine syncs to most things, although not as much as my XG will.
Posted: Tue Jul 01, 2014 7:23 am    Post subject:
Maybe the mac forces sync on green, or composite sync which is not supported on that input of the barco?
Posted: Tue Jul 01, 2014 9:15 am    Post subject:
The CineMAX supports both as far as i know, mine works fine with composite sync.
redfox001
Posted: Tue Jul 01, 2014 11:24 am    Post subject:
I tried both pressing 4 and 5 on the remote. No sync.
I am going to try a T-piece to combine the sync because in a doc about the hdfury 2 they say to try that.
The image rolls, is unstable, or doesn't always lock on. What do I do?
Some displays such as early Electrohome ECP and Barco CRT projectors have fussy sync circuitry. You need to combine the H/V sync lines using a $2 BNC T-connector (see picture in last question). You could also use an Extron 109 or 202 box to combine the two sync lines.
http://www.hdfury.com/docs/HDfury2manual.pdf
I am also looking for a power adapter for the hdfury 2. Would this one be allright? Do I have to change polarity?
http://www.okaphone.com/artikel.asp?id=461987
What sort of power supply does the HDfury2 use?
The HDfury2 power supply adheres to these requirements:
- Provides REGULATED (+/- 5%) 5VDC power with 500mA min DC current
- Delivers the power through a small 0.65mm diameter center pin / 2.6mm outer diameter DC plug (like the one often used in cellular phone AC adaptor)
- Provides the correct polarity with 'plus' on the OUTER part of the plug and 'minus' (ground) on the small center pin of the DC jack.
Trying to use an AC/DC adaptor that doesn't adhere to these three requirements may destroy the HDfury2.
Posted: Tue Jul 01, 2014 12:33 pm    Post subject:
Use an iphone charger if you like, just get the right cable.
redfox001
Posted: Tue Jul 01, 2014 2:29 pm    Post subject:
Ok I have the right charger connected to the HDF2 and guess what it works!!!!
But the 'streaking' is also there with the HDF2. So it is not caused by the Moome implementation. I guess we can conclude that the different gamma setting for all these devices got us confused but it is most likely the SMPS or some other hardware like Soleboy said.
redfox001
Posted: Tue Jul 01, 2014 2:54 pm    Post subject:
But I also got a T-connector and the Apple VGA cable worked with that one.
I am surprised by the seemingly greater bandwidth! The first pictures show the apple vga. The last the RGB2 (internal moome v3). The first resolution was not optimised like the second one so convergence was off.
Apple VGA
RGB2
Page 16 of 24
