programing a crestron
Posted: Tue Jan 29, 2008 6:42 am    Post subject:
Nice Avatar Jeff, is that your touchscreen?
jmayes
Posted: Tue Jan 29, 2008 3:26 pm    Post subject:
Yep, my home page Razz
JM
Posted: Tue Jan 29, 2008 7:31 pm    Post subject:
Jeff I made the ST-1500 touchpanel cable but need to test it. Any ideas ?
Posted: Tue Feb 05, 2008 6:24 pm    Post subject:
To both Chip and Jeff. What model touch screen are you currently using and why ? Would like to do an upgrade at some point 8)
Posted: Tue Feb 19, 2008 3:35 am    Post subject: Re: programing a crestron
mack1 wrote:
Does anyone know how to program a crestron remote model st 1500c and st-cp
Mack I hope your following the programming thread ! Wink Wink Wink
You kinda got me into this.... Shocked
az_max
Posted: Tue Feb 19, 2008 9:47 pm    Post subject:
jmayes wrote:
......I built a widget called the IP-Commander,..... it has a serial port and an X10 port and can serve a mini website (only 45k of space).
I'm actually interested in learning about the ip-commander. It's the one item I've been needing to complete lighting control over to Crestron. I have a CNMSX-AV system I've programmed myself to control the home theatre, but could not find a way to integrate x10 lighting into it.
I'm a self taught Crestron programmer. Starting with CNMS, moving to ST-CP and then to CNMSX-AV as the system complexity grew (all within 2 years). I currently have 3 serial controlled devices and 4 IR controlled devices. I've written modules for x10 and in-program power control (never implemented the x10, as I needed an older x10 serial device to do it). I started with x10, worked in HomeSeer for a while, have played with a half dozen HTPC apps. Settled on Showshifter. I'm here to learn and help others learn in HT control.
John
Posted: Tue Mar 25, 2008 2:07 am    Post subject:
Where are all the Crestron programmers and users out there. Any recommendations on upgrades ?
jmayes
Posted: Tue Mar 25, 2008 3:33 am    Post subject:
Hey az_max sorry for the late reply, missed the notice and have been stuck over in the other thread (part 2), you should have pm'd me. I am attaching the cut sheet for the IP-Commander, I still have a good piece of the last run around here so if your interested let me know.
JM
John
IPC_Sales1.pdf
 Filename:  IPC_Sales1.pdf
 Filesize:  146.4 KB
 Downloaded:  1069 Time(s)
jmayes
Posted: Tue Mar 25, 2008 3:37 am    Post subject:
Tom;
What were you interested in, A color screen? Wired or wireless? Larger? As far as controllers, Your ST-CP is already a CNX style controller so that only upgrade from there is more ports or the series II which is still pretty good bucks. Ports are easily added to the ST-CP via Cresnet modules so you will good there for some time.
JM
Kent Berry
Posted: Thu Jun 12, 2008 11:02 pm    Post subject:
Hey folks,
The two Crestron threads seem to have gone cold. I hope everyone is OK! Very Happy
My story is pretty much the same as the others here. I bought a CNMSX-AV and an ST-1550C a few years ago from a Crestron dealer who was upgrading his personal system. One of my neighbors installs Control 4 stuff for a living and since I'm on the steep part of the learning curve for waaaay too many things right now I had pretty well decided to let him do the automation for my HT. Until I came across this thread.......
Now I think I've been bitten by the bug again, but here's the thing: while the guy who sold me the gear set me up pretty well, I seem to have lost one of the CD ROMs he sent me. I still have a copy of SIMPL, but I can't find my copies of DEAL, VT ProE, or the Crestron database. Where are you guys finding the software? I haven't tried creating an account on the Crestron website, because they make it pretty clear that you have to be a dealer to get the good stuff. Can anybody out there help a fellow DIY'er?
Thanks.
az_max
Posted: Fri Jun 13, 2008 1:15 am    Post subject:
Thanks.
Hi, and welcome. Easiest way to get the new software is to install the version you have, go to help and click live update. It will prompt you to download newer versions of all the software. Very Happy
Kent Berry
Posted: Fri Jun 13, 2008 3:06 am    Post subject:
Well dayum! That was easy. The keys to the kingdom! Thanks man.
More questions to follow, I'm sure. 8)
Kent Berry
Posted: Fri Jun 13, 2008 12:42 pm    Post subject:
I realize you're using X10, but this could be a pretty painless way to add lighting control to Crestron, IF it works the way it should. Even in the world of Crestron, the Crestron lighting stuff has a reputation as being insanely expensive and is a hardwired system IIRC. Not retrofit friendly.
Looking ahead, has anybody figured out how to browse media? Obviously, a 2 way panel would be required but what else? MP3s I can live without, but I'm probably not going to get too serious about building a Crestron system if I can't figure out how to browse DVD cover art.
az_max
Posted: Sat Jun 14, 2008 1:03 am    Post subject:
Yeah, but it's $700 Shocked
If you have a series 2 processor with ethernet, you can use an IP Client to connect to a web server to get images like that. Or you may be able to save some of them to the flash either with/without ethernet.
Kent Berry
Posted: Sat Jun 14, 2008 1:46 am    Post subject:
Yowzaa!! I didn't see that part. I wonder how much of that is Crestron licensing fees? Rolling Eyes
I was thinking of something along those lines. There's probably a way to get the controller to talk to another server or PC running DVD Profiler or something similar. Importing the right image into the right field would be the tricky part.
Hell_Hound
Posted: Thu Jun 19, 2008 7:26 am    Post subject:
Hi i have a crestron CNMS and a touchpannel however i have no clue how to config it AND i don't have the software, i don't really think have much to worry about with the config its just the software i can't get.
can ANYONE please help me?
Hell_Hound
Kent Berry
Posted: Thu Jul 03, 2008 4:29 am    Post subject:
Awright, I got my little system programmed and up and running. It works great but I have a problem. My panel (ST-1550C) refuses to consistently power up to the last page after powering down. Most of the time, it reboots to Page 1 even though I have gone into the panel setup menu and set it to power up to the last page. Right now, I have it set to never power down (it just turns the screen off) and that fixes the problem but it eats through the battery charge pretty fast.
Anybody have any ideas? The unit sat in a powered off state for several years and I'm guessing that something is corrupted. Upgrading the firmware or reloading the present version would likely fix the problem but I can't figure out how to get a copy.
Kent
jkv
Posted: Fri Oct 03, 2008 8:13 pm    Post subject:
I'm here..just a little late to the party!
Posted: Mon Oct 06, 2008 2:12 am    Post subject:
I would like to learn more about creating new templates if your up to it. I have an ST-CP and an ST-1500 touch screen for the HT plus the needed program for programming Crestron's. You might want to start a new thread though...
jkv
Posted: Tue Oct 07, 2008 1:16 am    Post subject:
to be honest with you, I have never used VT-Pro templates; all of my clients always have different equipment to control, different touch panels and they all want to impart their own "personalities" on the UI. After I get an idea on how the client wishes the UI to "flow", I'll layout the UI with simple buttons and text. Once the client is happy with the flow, we then proceed to make it "pretty", adding color schemes, icons, etc.
Over the years, I have collected/created quite a few graphic images for things like lights, CDs, DVDs, cameras, etc which I always try to use.
For graphics editing, I use FireWorks, but most folks use PhotoShop. I always create a .png file and then export that in the best format that a target touch panel will support.
You are somewhat limited in the things you can display on a ST-1500; you may want to think about picking up a ST-1550C or even a ST-1700C.
The ST-CP is also limited depending on what you want to do down the road (it does not support SIMPL+). You could pick up a MC2W and really expand what your system can do. I use a MC2W in my theater and a CP2E for the house; they are connected with a serial cable so they share resources; for example, the touch panels in my kitchen and master suite have a button to "warm up" the theater, which allows me to start the theater remotely. Also, the Lutron lighting processors are connected to the CP2E so when the MC2W has to control the lights in the theater, it simply "tells" the CP2E what theater lighting scene it needs and the CP2E then informs the Lutron system.
Page 3 of 4
