ccaddaddy
Joined: 18 Apr 2010 Posts: 113 Location: Corpus Christi, Tx
| Posted: Sun Feb 02, 2014 3:46 am Post subject: barco 1208s blue! |
I can't get the blue to come on! I've downloaded all the manuals and did everything but no joy. Im using my htpc as my source vga-5bnc breakout cable. What am I doing wrong?!?!?!
_________________ "To forgive is divine but never pay full price for late pizza." Michaelangelo
| Posted: Sun Feb 02, 2014 10:41 am Post subject: |
Try swapping the blue and red cables where they enter the projector and see if that is the issue. If blue now works, everything that should be red will be blue, and youll have no red....
Do you get blue on the test screens?
| Posted: Sun Feb 02, 2014 2:54 pm Post subject: |
Does the test pattern show up on the blue?
digitalayon
| Posted: Sun Feb 02, 2014 7:03 pm Post subject: |
I have a 18-205 blue if you need.
ccaddaddy
| Posted: Sun Feb 02, 2014 7:33 pm Post subject: |
I can't even get the test patterns on blue. It was working the last time I had turned it on but the blue test patterns were very dim.
| Posted: Sun Feb 02, 2014 8:47 pm Post subject: |
Swap the red and blue neck boards ( if theyre the same )
| Posted: Sun Feb 02, 2014 9:28 pm Post subject: |
Does this set use Panasonic or Sony tubes? The Sony tubes have a round brass cap on the top (glycol expansion chamber) that you can see over each tube, under the top cover of the projector. there's usually a mesh screen covering them. If so, most likely your blue tube is dead. I've seen this before with Sony tubes, not the Panasonics.
ccaddaddy
| Posted: Mon Feb 03, 2014 12:22 am Post subject: |
So I guess I need to retube the whole set. It has the Sony tubes.
| Posted: Mon Feb 03, 2014 1:59 am Post subject: |
You need to confirm thats the issue first!!
ccaddaddy
| Posted: Tue Feb 11, 2014 2:25 am Post subject: |
great, now the thing doesnt want to turn on! it worked just last weekend. im pointing the remote directly in front or the ir sensor and the blue led is flashing on my remote.
| Posted: Wed Feb 12, 2014 2:22 pm Post subject: |
On the projector keypad, press the recessed 'addr' button, then press 0,0,0. That will reset the CPU board to the remote. If not, then it's possible your power supply is bad, and won't turn on.
I do have ONE brand new set of tubes here for that set. You may not need to retube the whole unit, but I don't think you'll find a good blue tube, and I've got two guys ahead of you looking for one as well. I won't break this set up though.
ccaddaddy
| Posted: Fri Feb 14, 2014 3:55 am Post subject: |
what are the part #'s for the tubes? why is the green shorter than the others? | Curt Palme wrote: | On the projector keypad, press the recessed 'addr' button, then press 0,0,0. That will reset the CPU board to the remote. If not, then it's possible your power supply is bad, and won't turn on.
I do have ONE brand new set of tubes here for that set. You may not need to retube the whole unit, but I don't think you'll find a good blue tube, and I've got two guys ahead of you looking for one as well. I won't break this set up though. |
| Posted: Fri Feb 14, 2014 2:51 pm Post subject: |
I've never noticed that the green is shorter! Should be the same length?
I can't remember the Sony part numbers off the top of my head, the BArco part numbers should be stamped on the sides of the tubes, a 762XXX part number on each one.
ccaddaddy
| Posted: Fri Feb 21, 2014 4:04 am Post subject: |
i tried doing the remote reset. Nothing. how can i know for sure if it is dead? isnt there a way to turn it on with out the remote?
ccaddaddy
| Posted: Fri Feb 21, 2014 2:59 pm Post subject: |
Also third red led is flashing.(processor cycles)
| Posted: Fri Feb 21, 2014 3:55 pm Post subject: |
The power supply may be toasted. Check the processor lights when you press the remote, do the lights on the controller change? The processor will stop flashing rapidly, and chances are at some point, the error light will flash. if so, chances are the SMPS died. If the indicator lights don't change at all when you press the buttons on the remote, then the remote may be bad, as that means the Barco isn't receiving the IR commands.
Does the flip out panel on the back of the Barco turn the set on and off?
I have had the IR receiver on the front of the set die in a couple of sets, and that also causes the one on the back of the set to not respond. Happened in a 909 the other day...
ccaddaddy
| Posted: Sat Feb 22, 2014 2:45 am Post subject: |
i have not noticed a flip out panel in the back. lol
ccaddaddy
ccaddaddy
| Posted: Sun Feb 23, 2014 3:59 am Post subject: |
rcu and error light up when I mess with the remote.
| Posted: Sun Feb 23, 2014 4:13 pm Post subject: |
What if you try powering up with the built in keypad?
