Learning to live with tube wear
winny
Posted: Sun Jan 26, 2014 7:38 pm    Post subject: Learning to live with tube wear
Parted the renaming two tubes from their housings today which I intended to use with new scheimpflug housings. So far so good, until I held up the tubes at an (un)favorable angle. There is wear on the blue tube and a hint on the green. Previous owner had low ceilings and hence the projector mounted flush at zero degrees with a characteristic wear pattern as a result. As always it's hard to capture. Let's just say they are more pronounced in real life than what shows up in the picture.
What are my options? Keeping within the wear area will just mean unfavorable mounting position and premature wear on the other tubes (red is like new, green has a hint of 16:9 wear which is only visible when it's out of it's housing and held at the correct angle against the light so I would say an 8) which to me is shooting myself in the foot since I will deliberately be raising running costs and decrease resolution.
Also, I'm that annoying person who writes letters of complaint to the managers of cinemas when the convergence is off, 3D polarization images don't match up to the millimeter, the masking is off and similar so I will for sure notice color differences in the image if there is a edge. There is a small difference though in that the cinema costs $10 an hour and the CRT is about $0.05-$0.5, depending on how long I let the tubes go, so I expect perfection at the movies.
If I run a full blue image and adjust the image to cover all of the surface area minus minimal safety area, will it blend out? Compensate by using a negative image in my HTPC/scaler?
Learn to live with it and it will blend out over time?
Tune a negative image on the blue tube and run it over a few days to wear the rest of the phosphor to the same level?
Suck it up and get a new tube?
Other option?
No flash.
 Filesize:  103.37 KB
 Viewed:  7751 Time(s)
Flash.
 Filesize:  83.24 KB
Melifluonze wrote:
Posted: Mon Jan 27, 2014 12:46 am    Post subject:
Nothing wrong with those tubes...
Posted: Mon Jan 27, 2014 12:47 am    Post subject:
Buy three tubes and get three housings free!!
Posted: Mon Jan 27, 2014 3:18 am    Post subject:
Those tubes are fine just keep the image in the wear zone and you won't notice it.
winny
Posted: Mon Jan 27, 2014 7:46 am    Post subject:
Should have thought of that much sooner, before spending even more money on new glycol, scheimpflug housings and colored C-elements than a complete set would have cost with all of the above included.
Staying within the wear area is like living with your car doing 10 mpg because you don't want to take the up front service cost of fixing the problem - it will cost you more in the long run in terms of money and performance.
I'm deadly afraid to end up with a picture like this:
At first I thought analog CRT will be great because I could throw whatever aspect ratio and non-square pixels at it and also not wasting any resolution for things like keystone correction. Although this holds true at first, switching between 4:3, 16:9 and 2.35 will dramatically lower the usable service life. Also, if you need to move at any point in life, chances are high you will end up with a bad compromise.
Melifluonze wrote:
Posted: Mon Jan 27, 2014 12:02 pm    Post subject:
From what i can see you wont have an issue, you cant use the whole face!!
winny
Posted: Mon Jan 27, 2014 3:03 pm    Post subject:
I was able to adjust the 808s mounting position to get much further to the edge than this, but perhaps it's within practical limits. The difference in available surface area between ideal and the 4:3 limit for this is about 44% (or 69 % area left).
Dedicating the 1209 for 16:9/2.35 use only does not help either since this helps maximizing the width with no round tube corners to worry about.
None here who successfully worn a tube into shape by using an inverted image? You all paid up instead?
 Filesize:  73.84 KB
 Viewed:  7629 Time(s)
 Filesize:  80.52 KB
Melifluonze wrote:
Posted: Mon Jan 27, 2014 3:09 pm    Post subject:
Just an FYI, the pix from the website above showing tube wear had significantly worn tubes, not the very light wear that you show in your tube pix.
Put the tubes in the set you're going to use them in, and max out the phosphor area to past the wear points. Set the projector up floor mounted first, and see if you can live with the slight wear. I have a feeling you can. If not, move the projector back so that you're within the wear area, and use it that way.
Unless you're putting 6-10 hours of use on the set per day, even running the set within the wear area should last you a good 5000-6000 hours (if not more, depending on your contrast setting), and chances are the set will fall apart before the tubes are toast.
digitalayon
Posted: Mon Jan 27, 2014 3:47 pm    Post subject:
Tubes look pretty good to me.....FYI.....my company makes the 3D polarizers for Real D. If they fail to calibrate correctly, yes you will have a headache.
winny
Posted: Mon Jan 27, 2014 4:05 pm    Post subject:
Oh, I will have a headache from the 3D alone. No matter how much they have spent on the 3D and production (Gravity), it's not worth it to me. I sweet-talked to the cashier lady which was about my age quite attractive too and got a second pair of glasses, cut it open and swapped left eye for right eye between the pairs to make 2D goggles. 3D was gone but the convergence problems where still visible since the right eye picture didn't hit the masking. Took out the other pair to verify and the convergence between right and left eye was off by perhaps 50 mm in the top part of the left hand side. Color convergence was off too. Freakin' multiplex crap!
Perhaps should mention that I'm an ex-cinema mechanist. You know, the old stuff with 70 kg 35 mm film loaded into huge things which didn't ask for DRM clearance, had no anthropomorphic paper clips to guide you or didn't allow you to screen the movie to spot problems before 600 people came into the auditorium. The good old days...
Melifluonze wrote:
Posted: Mon Jan 27, 2014 4:31 pm    Post subject:
That's a very slight level of wear. I'm guess it will probably only be noticeable in fairly solid backgrounds like clear blue skies or when you're watching something like Ice Age with lots of light, solid backgrounds.
I wouldn't mess with wear-matching; you probably have at least as much of a chance of making the problem worse as you do fixing it.
winny
Posted: Mon Jan 27, 2014 5:41 pm    Post subject:
Sounds like a ruined movie to me.
Perhaps there is a method to this madness.
Step 1, do the floor standing set-up and get an overview and feel of the problem. If ok to semi-ok, hoist it.
Step 2, if unbearable during laid back movie watching in pitch black move on to attempting to even out the wear. If it fails/make it worse, the tube would be useless to me anyway. 50 % chance is better than 0 %.
Step 3, get a new tube.
Melifluonze wrote:
Posted: Mon Jan 27, 2014 5:49 pm    Post subject:
You're amongst a pretty anal bunch, here. I know how you feel. Once I burned a damn ammo-counter into the corner of my G70, I saw it all the time. Drove me nuts, and even soured me on CRT to some extent. Partially my fault, but also a significant disadvantage to CRT.
Your 3-step approach sounds reasonable to me. Definitely try it and see how it looks before you get too worried about it.
Ile
Posted: Tue Jan 28, 2014 10:01 am    Post subject: Re: Learning to live with tube wear
Sounds like this is your best option. Wink
My BG808s had about similar looking tube faces and that was unwatchable for me.
Nasty edges and white in worn area looked like IRE5. Thumbs Down
 Filesize:  25.61 KB
 Viewed:  7557 Time(s)
winny
Posted: Tue Jan 28, 2014 10:26 am    Post subject:
Good heavens! That's nasty. Any pictures of the tubes that produced this? Any attempts to even out the wear?
Melifluonze wrote:
Ile
Posted: Tue Jan 28, 2014 12:33 pm    Post subject:
Might have pictures of tubes face at home computer, least I have those tubes laying around somewhere.
If I remember correct tube faces looked pretty much like yours, not so bad. But projected picture sucked.
Those was Sony tubes though, there might be little difference how Sony/MEC tubes compare to visible wear vs actual picture at screen. I had similar case with Sony tubed BG1200. Not so bad looking tube faces, but screen show different truth.
I didn't even thought evening wear out, because of lost light output and sifted primary color in blue and green. You can't fix sifted primary colors by color adjustment. White, blue and green looks dirty.
Sure uneven wear makes it even worse because edge is very visible most of time and then you also see all the time how much whiter and brighter unused phosphorus at sides is.
Posted: Tue Jan 28, 2014 3:06 pm    Post subject:
You're amongst a pretty anal bunch, here. I know how you feel. Once I tried using a digital, and it failed shortly thereafter. Drove me nuts, and even soured me on digital to some extent. Partially my fault, but also a significant disadvantage to digital.
There, buddy, I fixed your statement. Mr. Green
Posted: Tue Jan 28, 2014 3:57 pm    Post subject:
You're funny, Curt… However, I'll just point out that at some point not in the not-too-distant future, you'll be like the horse-and-buggy advocates. Yeah, the car did have some disadvantages, but overall they were worth the trouble compared to the alternative. Pretty sure we're already there for like... I don't know... 98% of the population. Wink
winny
Posted: Tue Jan 28, 2014 5:46 pm    Post subject:
Just when I thought my life could not suck any more.
I was in Hong Kong last week with a trip to our factory in China. "No worries, we have booked you to a five star hotel". Right... It was 14 degrees both inside and outside. I asked someone in charge and they said that they would only turn on the heater if the temperature dropped below 13. It was typical Chinese McMansion style too where everything looked impressive until you touched it and it came loose. Food sucked too except for Hong Kong.
So I caught a cold/avian flu and are coughing up my lungs at the moment. This would be ok if it weren't for the fact that one week of gym absence was bad enough and now it will be three. I only did cardio over my four week summer vacation and was set back five months when I got back so I just wasted the last three or so months due to this. First date stopped responding to emails and what I though was the second/new didn't turn out so. Oh, and my job sucks! I'm finding a printer to print my letter of resignation.
If I need to sink down $1000 more to get this project of the start line on top of above, I need to re-think my priorities. How much would an BG1209/2 with prestine red tube, all the hardware required to rebuild to continous scheimpflug including bellows and new glycol, colored C-elements, a VP50pro and set of standard lenses get me if I spend a lot of time negotiating prices, wrap stuff in boubble plastic and queuing at the post office? 1000 bucks? That should buy me a second hand Epson 3LCD full-HD projector. The blacklevel will suck ass but it will perhaps work for a few movies at least. Or perhaps just bother with the VP50 and make a bonfire of the entire set on the back lawn instead and spend the time that's now freed up on doing two workouts per day to get back in shape. It would free up a lot of space in my appartment as well.
Luckily I have enough Glühwein and beer tonight that I will soon not worry about it.
 Filesize:  75.65 KB
 Viewed:  7500 Time(s)
Melifluonze wrote:
Posted: Wed Jan 29, 2014 12:02 am    Post subject:
Lesson here is stop exploiting the Chinese and manufacture locally Laughing
Just use the tubes and stop moaning, they are fine. Use of a smaller area will help you get better corner focus, both optically and electronically. Your astig will also be better.
