Convering 1209 to 1209SE (continous scheimpflug)
Goto page Previous  1, 2, 3
winny
Posted: Thu Feb 13, 2014 10:19 am    Post subject:
Does it apply to 1209?
If it does, I'll rather switch the affected complete board to rule out/narrow down the problem. In my case, would this be the scan board?
Melifluonze wrote:
Posted: Fri Feb 14, 2014 3:44 am    Post subject:
Have you switched out any boards? I can recall a similar issue with switcher board causing a spot when the PJ was shutdown when I changed the board it went away. This was a barco 801 but the principles of operation of the various projectors seems to be the same so you might try swapping the switcher or even the RGB driver board.
Page 3 of 3
