winny
| Posted: Thu Feb 13, 2014 10:19 am Post subject: |
Does it apply to 1209?
If it does, I'll rather switch the affected complete board to rule out/narrow down the problem. In my case, would this be the scan board?
| Melifluonze wrote: | | Digital is easy. This is torture, but far more interesting... |
| Posted: Fri Feb 14, 2014 3:44 am Post subject: |
| winny wrote: | Does it apply to 1209?
If it does, I'll rather switch the affected complete board to rule out/narrow down the problem. In my case, would this be the scan board? |
Have you switched out any boards? I can recall a similar issue with switcher board causing a spot when the PJ was shutdown when I changed the board it went away. This was a barco 801 but the principles of operation of the various projectors seems to be the same so you might try swapping the switcher or even the RGB driver board.
