Barco 808 problems
Goto page 1, 2, 3, 4  Next
Decibel
Posted: Fri Jan 03, 2014 3:32 pm    Post subject: Barco 808 problems
I believed until yesterday to have enough knowledge to solve small problems on my 808's.
I have to sell one and I started to assemble the various pieces .
After the installation the projector turn on, but no light from the tubes.
No red led on the EHT
No red leds somewhere.
I noticed that two green LED on the board g2 remain off.
Are the last in the row (next to the red led) and other towards the center of the board.
Ok ... no problem I thought ... I have another projector.
I take another and I mounted the various pieces .
At the end start the projector and the tubes light up regularly. OK!
This morning I go to turn on the projector and it show the same problem as the first.
No red red on EHT
I swapped ..
2 focus boards
3 horizontal deflection boards*
2 vertical deflection boards
2 pair of input and video driver boards
3 smps boards
2 g2 boards
2 eht boards
2 quads
The connections with the tubes (HV leads, yokes, neckboards ) are correct 'cause yesterday the tubes light up.
If I remove the convergence tray does not happen anything different.
* with a one horizontal boards of three, I noticed that the two green LEDs on the G2 finally come on but the projector goes into loop and several red leds light up.
Any suggestions?
Domenico (Barco fan!)
Posted: Fri Jan 03, 2014 3:38 pm    Post subject:
It may be as simple as the master width adjustment on the SMPS. that's on the daughter board. Try rotating it a bit either way, powering the set off and on to reset the CPU, and see if it comes on.
Decibel
Posted: Fri Jan 03, 2014 3:53 pm    Post subject:
I thought at master widht and I tried.
I will try again now and I'll post the results
Thank you for now Wink
Posted: Fri Jan 03, 2014 3:54 pm    Post subject:
Whatever you do, stick with the boards that gave you a picture! I've tried 'making up' a set in the past, and while it does work, it can throw additional problems into the set, as I've found out many times. Smile
BTW, losing two LEDs on the G2 board usually means that the HTHD has shut down, which is why you're getting no picture.
Also pull the convergence tray and see if the picture comes back.
Decibel
Posted: Fri Jan 03, 2014 5:15 pm    Post subject:
Ok but I don't remember if the boards are the same, the projector's serial number help me.
Should be the same. Perhaps the paired of input and driver video boards not are the same ... uhm.
Yes I know
Rotating the trimmer P2 on smps daughter board, the red led on the G2 board "light on and light off" depending the trimmer positions.
Same results for the green led towards the center of the board.
The last green led next the red don't light never. I know that this green led must be light on.
The convergence tray is pulled.
I'm going to swap video boards (input and driver).
Posted: Fri Jan 03, 2014 6:05 pm    Post subject:
Can you swap all your spare boards into a working 808, to make absolutely sure that all your boards work? That would be the first thing I'd do.
Decibel
Posted: Fri Jan 03, 2014 6:33 pm    Post subject:
They were two projectors fully functioning. One board can break but it's very improbable that two identical boards to break at the same time.
Posted: Sat Jan 04, 2014 4:44 am    Post subject:
What Quad and EHT are you using? The frame may be set up for either the new or older quad and EHT. If you put the wrong ones in there is no HV and of course no picture. There is a jumper on the frame that needs to be either in place removed depending on the combination of EHT and Quad.
Decibel
Posted: Sat Jan 04, 2014 6:23 am    Post subject:
Older frames and older quads/EHT.
Posted: Sat Jan 04, 2014 6:48 am    Post subject:
Did you check to see if the jumper is in place?
Decibel
Posted: Sat Jan 04, 2014 7:09 am    Post subject:
I'm sure that the older frames and older eht boards are unmodified.
I'm sure that this isn't the problem.
Posted: Sun Jan 05, 2014 6:03 am    Post subject:
Are the heater glowing on the tubes?
Sounds like no or low G2 if tubes heaters are on.
Decibel
Posted: Sun Jan 05, 2014 10:04 am    Post subject:
Yes there are heater on the tubes and I tried to rotate the trimmers of G2.
Today I'll try to check deflection yokes.
opv
Posted: Sun Jan 05, 2014 10:36 am    Post subject:
Decibel,
I had a similar 808s issue. when I moved to a new house, I moved the PJ from the floor to the ceiling and had to change the scan polarity.
When I activated the PJ, it turned on, but I saw no picture on the screen.
I disconnected the PJs power cord and waited several hours. when I plugged it back everything went back to normal. give it a try.
Decibel
Posted: Sun Jan 05, 2014 10:59 am    Post subject:
Very strange thing!
However the pj is disconnected by two days.
Decibel
Posted: Sun Jan 05, 2014 10:38 pm    Post subject:
Swap deflection yokes, focus yokes, power module and another splitter.
No fix!
Posted: Mon Jan 06, 2014 1:26 am    Post subject:
No fix!
Do you have spare H shift and focus boards.
Decibel
Posted: Mon Jan 06, 2014 7:38 am    Post subject:
Yes, I have, one focus and two horizontal.
But now I am not sure that they are working.
Posted: Mon Jan 06, 2014 7:55 am    Post subject:
I mean R7625035. I had to try more than one to get it right.
Decibel
Posted: Wed Jan 08, 2014 10:27 am    Post subject:
I tried to swap also the controller.
I just bought focus, vertical, horizontal and g2 boards.
Page 1 of 4
