kal Forum Administrator
| Posted: Tue Jul 07, 2015 2:50 pm Post subject: |
| TroubleShooter wrote: | Thanks for your insights !
Do you think it's worth a shot trying to recalibrate it with an i1 pro ? |
An i1pro is a spectroradiometer and not a colorimeter, so it does not drift in the same way, meaning that they remain accurate over time. So yes, it's worth it. However, given the nature of the technology, they are slow to read at low light levels so you may find it very slow to use when doing low level light readings as is typically done on a 2-point calibration.
For more info see our article "WHICH METER IS RIGHT FOR ME?" here: https://www.curtpalme.com/forum_archived/viewtopic.php@t=11436.html
| Quote: | | About the projector, as it doen't have RGB HighEnd/LowEnd functions and only has 6 levels of Degamma and 3 of Color Temperature and individual red-green-blue ajustement possibility, worth trying calibration ? |
Yes.
Though that's a bit of a catch-22 question: Until you measure and see how far off it is and see how close you can get it, you really won't know how much improvement you can make.
Good luck!
TroubleShooter
| Posted: Tue Jul 07, 2015 6:16 pm Post subject: |
Again many thanks !
I've read the "WHICH METER IS RIGHT FOR ME?" article and I understand now the differences and the point of having a colorimeter + a spectroradiometer.
I will therefore go for recalibration of the 2nd handed display2, unfortunately no i1 pro for rent around me but I can get a ColorMunki Display for few bucks a day and for what I've read, it can also do the job, right ?
My very last 2 questions:
Are the colorimeter only getting inacurate over time or are they also hardware-wise losing abilities ?
I've read also that after some time it could be impossible to recalbrate them. information or speculation ?
Bonus question:
Will you advice to get a decent projector screen (or pvc projection tissu) before calibration or could I just try getting the best out of my white wall ?
I'll keep you updated !
Thank you for everything.
| Posted: Tue Jul 07, 2015 7:26 pm Post subject: |
| TroubleShooter wrote: | Again many thanks !
I will therefore go for recalibration of the 2nd handed display2, unfortunately no i1 pro for rent around me but I can get a ColorMunki Display for few bucks a day and for what I've read, it can also do the job, right ? |
The ColorMunki Display is a low cost colorimeter, just like the Display 2. Normally you don't use one colorimeter to calibrate another unless the first one is known to be accurate or was recently calibrated as all colorimeters drift.
| Quote: | Are the colorimeter only getting inacurate over time or are they also hardware-wise losing abilities ?
I've read also that after some time it could be impossible to recalbrate them. information or speculation ? |
They drift and become less accurate. If they drift far enough they may get to the point that the offsets required in software to make them correct are large enough that they start to introduce other issues.
| Quote: | Bonus question:
Will you advice to get a decent projector screen (or pvc projection tissu) before calibration or could I just try getting the best out of my white wall ? |
Up to you. You may have issues getting proper calibration when projecting on a white wall. If you change your screen you should recalibrate.
TroubleShooter
| Posted: Wed Jul 08, 2015 4:10 am Post subject: |
Never mind, I thought that the ColorMunki Display was a spectroradiometer.
After a bit of research, I may have found a way to rent an i1 pro finally !
My very very very last question will be : (I hope :p)
A new ColorMunki Smile or a used i1 Display 2, that's my situation of now as I could get one or another for around 65 euros and I've been reading that the ColorMunki Smile was very near of the i1 Display 2, is that right ?
I'm also reading a lot about white walls, so definitely gonna get a projection screen that lower the light reverberation, might go for a grey one 0.8 !
I you have any question regarding classical music I'm your man, that's the only thing I could think of to repay the time you spent answering me
mlapd
| Posted: Sun Jul 19, 2015 2:23 pm Post subject: |
Hey guys,
Picked up a Panasonic 65AX800U yesterday for one of my rooms. For the price it couldn't pass it up. Had a question for you. For my Display3Pro II when I am selecting my mode should I select lcd generic or are any of the Samsung, Sony, LG LED modes close?
_________________ Lap
DeepIrex
| Posted: Fri Jul 31, 2015 3:01 am Post subject: H6400 Calibrations Setting |
Arcsaber, seems like you are really happy with how the white point calibration turned out. I know various factors attribute the outcome, but you mind sharing the complete settings of your TV, please? I have the same Samsung 55H6400 and have really been struggling to get it display the best picture!
| Posted: Fri Jul 31, 2015 3:07 am Post subject: Re: H6400 Calibrations Setting |
| DeepIrex wrote: | | Arcsaber, seems like you are really happy with how the white point calibration turned out. I know various factors attribute the outcome, but you mind sharing the complete settings of your TV, please? I have the same Samsung 55H6400 and have really been struggling to get it display the best picture! |
Keep in mind that what you're asking is a bit of a catch-22. One person's settings are meaningless to use on a different set (even if the exact same make/model). Components age/drift and have tolerances to begin with that vary. If they didn't, calibration wouldn't be required. You can't take one person's settings and use them on your own set. That would be illogical.
DeepIrex
| Posted: Mon Aug 03, 2015 7:15 am Post subject: |
Completely in sync with you on this Kal. I tried a few tweaks and yet I have been unable to work out the 2-Point and 10-Point white balance. There is too much grain on the HD sources that I watch ( downloaded MKVs(8,10GB), Blu-Rays and PS3 games etc.). If someone could guide on how to calibrate 2 and 10-point white balance, that could serve as a starting point without a meter!
| Posted: Mon Aug 03, 2015 12:52 pm Post subject: |
| DeepIrex wrote: | | Completely in sync with you on this Kal. I tried a few tweaks and yet I have been unable to work out the 2-Point and 10-Point white balance. There is too much grain on the HD sources that I watch ( downloaded MKVs(8,10GB), Blu-Rays and PS3 games etc.). |
Grain in sources doesn't affect calibration since you need to use a known set of test patterns to calibrate and the test patterns will not have any grain in them.
See here for such a calibration disc: http://www.curtpalme.com/ChromaPure_Calibration_Disc.shtm
Here's another one: http://www.avsforum.com/forum/139-display-calibration/948496-avs-hd-709-blu-ray-mp4-calibration.html
| Quote: | If someone could guide on how to calibrate 2 and 10-point white balance, that could serve as a starting point without a meter!  |
Calibrate without a meter is difficult / not really possible given how the human eye is very poor at seeing subtle differences in colours. You can certainly try it however. It would be no different than calibrating with a meter. With a meter you're trying to get the various levels to be devoid of any colour (only shades of grey) so you would try to do the same but only by eye.
signmastr
| Posted: Tue Aug 18, 2015 7:32 pm Post subject: Printing |
Why can't I print this? New Member?
Ahlgren4200
| Posted: Mon Oct 19, 2015 8:42 pm Post subject: a few questions |
first of all i want to thank you for this outstanding guide ! this is truly amazing !!
I have just a few questions i hope you will take the time to answer :
1. Meter placement on a LCD display ?
Should i just position the meter somewhere in the middle of the display ?
2. Grayscale calibration
When i try to do a pre calibration measurement on the grayscale, i start with the 0% black and click "Measure"
But i get no reading and it does not advance to the 10% black ?? i am using the built in pattern generation function in chromapure.
When i click the 0% black the display kinda turns off ??
can u tell me what i am doing wrong ?
Sorry for my bad English - i am from Denmark Smile
thank you again for an oustanding service !
| Posted: Mon Oct 19, 2015 9:04 pm Post subject: Re: a few questions |
| Ahlgren4200 wrote: | 1. Meter placement on a LCD display ?
Should i just position the meter somewhere in the middle of the display ? |
Yes. Assuming you're using a Display 3 / Display 3 PRO, place it against the screen in front of the pattern/window.
| Quote: | 2. Grayscale calibration
can u tell me what i am doing wrong ? |
I'm not sure. Probably best that you email ChromaPure support about this as they would be best positioned to assist and know what you're using based on your order. They're at support@chromapure.com
I erased your other thread that was a repetition of this post. No need to post more than once.
steve49730
| Posted: Thu Jan 14, 2016 9:51 pm Post subject: |
Hi Kal,
Chromapure v3 has very recently been released. To be honest I'm a total noob with calibration and wouldn't be able to get anywhere without your very useful guide, it was what swayed my purchase decision. I haven't used v3 but the blurb implies the interface has changed quite a bit (for the better apparently).
Would it be your intention at some point in the future to update your guide to take v3 into account? I don't think I could cope without it, I probably won't upgrade until somebody is there to hold my hand.
Thanks.
Goozoo
| Posted: Mon Feb 15, 2016 4:33 pm Post subject: Taking a temperature measurement |
Great insight into a very useful program. Maybe his has been covered elsewhere, but was just wondering if the software has a way to take a measurement of the temperature reading from the screen. What I mean is that if I set the output to 6500K on my projector, is there a way to actually verify what it really is like you can with Calman?
| Posted: Mon Feb 15, 2016 4:57 pm Post subject: Re: Taking a temperature measurement |
| Goozoo wrote: | | Great insight into a very useful program. Maybe his has been covered elsewhere, but was just wondering if the software has a way to take a measurement of the temperature reading from the screen. What I mean is that if I set the output to 6500K on my projector, is there a way to actually verify what it really is like you can with Calman? |
Yes and no.
Temperature readings are absolutely useless as there are many ways to get to 6500K. A reading of 6500K doesn't mean that you're calibrated properly. You need to go a level deeper.
I'm not actually sure if ChromaPure shows this sort of graph. If it doesn't that ok, as it's useless.
HCFR does however, here's an example from our previous greyscale guide:
Some magazines love to show this graph as it's easy for people to follow. They tell us that if the graph is perfectly flat with values of 6500K from black to white that the greyscale is therefore perfect. Not true.
What you need to understand is that many points on the CIE diagram actually add up to a colour temperature of 6500K, but only one is correct: The D65 point where x=0.313 and y=0.329. You can have a display that measures 6500K across the board but still look incorrect. An RGB Levels graph and a CIE graph give us a far more accurate picture of what's actually going on.
So the less you concern yourself with colour temperature graph the better. Just ignore it, it's truly useless.
Stick with what ChromaPure does show you: The graphs (or x, y, Y numbers) you need to get a truly flat greyscale.
Good luck!
mfractal
| Posted: Sun Mar 27, 2016 1:59 pm Post subject: |
| Quote: | It's also important to use the right test patterns for your display type. If you are calibrating a plasma or CRT display, always use window test patterns for grayscale, gamma, and color calibration. A window test pattern only fills the middle of the screen like this:
For display types that are not plasma or CRT, always use full field test patterns. A full field test pattern fills the entire screen like this:
Hi there. Planning to calibrate a Samsung JS8500 55" LED tv and not sure which patterns should i use. According to the instuctions full screen patterns should be used. The TV does however modify it's black levels in accordance to what is displayed on the screen. Ex. full black screen apprears extremely black, then say, subtitles appear - the whole black background gets brighter. Hope that makes sense
So should i use full screen or field?
