| Posted: Sat Dec 28, 2013 11:53 pm Post subject: |
That is the wrong cable, that is Component, not RGB, what you need is a SCART cable.
I will post links and pics abit later on
Its 9:52am here, but ive hurt my neck at work so ive had trouble sleeping lately.
| Posted: Sat Dec 28, 2013 11:58 pm Post subject: |
| AnalogRocks wrote: | | AnalogRocks wrote: | | CasetheCorvetteman wrote: | | Use it without the line doubler, it should be in 480i anyway on that game. |
Yeah, I realized that but the PS2 was a little hit or miss on the composite input of the D50. Hence the reason I ran it through the line doubler. Now with the Quad decoder I can run it 480i. |
Finally got to this annnnndddd. My Quad decoder crapped out. It just sits there and flashes the output causing the D50 to throw and error code 10 Grrrrr... |
Never mind bad batch or cable.
| Posted: Sun Dec 29, 2013 12:02 am Post subject: |
| mookee wrote: | not helpfull but interesting
any additional thoughts? |
As Case said. Wrong cable. You are confusing RGB with Component because of the color coding. Yes Component is Red Green and Blue but is a different signal type from RGB. As Case says you will need the SCART cable which will output RGB not Component.
What projector/monitor are you running again anyways?
mookee
| Posted: Sun Dec 29, 2013 12:36 am Post subject: |
f..ck that, lets just cut that stupid cable in pices and i will pic out the rgb signals. kind of tired of those stupid cables. mine is wrong, the original doesnt pin all ps1 outputs at all.. nerv..
so i will cut the crap and let you know what happens. anyway, what to do with the minus pole in case of an alternative power source please?)
lg christoph
mookee
| Posted: Sun Dec 29, 2013 12:37 am Post subject: |
| mookee wrote: | f..ck that, lets just cut that stupid cable in pices and i will pic out the rgb signals. kind of tired of those stupid cables. mine is wrong, the original doesnt pin all ps1 outputs at all.. nerv..
and case, please yeah, show me whichcable you mean..)
ps. its a nec 6pg plus without composite video board...
lg christoph |
| Posted: Sun Dec 29, 2013 4:26 am Post subject: |
You CANT cut that cable to get RGB, it is a PS2 component cable. PS1 has no component output, only composite, s-video, and RGB. You will get no image at all with that cable on a PS1, and itll be all green with a PS2.
Sorry I took so long, but here is a couple links of everything you need:
This is the exact SCART cable I have, its perfect:
http://www.ebay.com.au/itm/RGB-Scart-Video-AV-Cable-PS2-PS1-PS3-PlayStation-2-3-PSTwo-Slim-RCA-NEW-/141138763455?pt=UK_Video_Games_Cables_and_Adaptors&hash=item20dc869ebf
Then you plug it into this one, which connects straight to your NEC 6PG:
http://www.ebay.com.au/itm/Female-RGB-Euro-SCART-to-4x-BNC-Audio-Cable-Sony-PVM-Sega-Genesis-SNES-Neo-Geo-/201000357298?pt=US_Video_Game_Cables_Adapters&hash=item2ecc8e0db2
| Posted: Sun Dec 29, 2013 4:35 am Post subject: |
Just buy those exact items I linked you to and plug it all in.
| Posted: Sun Dec 29, 2013 8:05 am Post subject: |
Purchased! Thanks case! Now to see if I can get my guncon working...
| Posted: Sun Dec 29, 2013 11:53 am Post subject: |
No worries mate, id have posted those sooner but couldnt get enough time to get to the computer while ive got the internet connected to it.
Huge storm here at present, loads of lightning, very windy!!
mookee
| Posted: Sun Dec 29, 2013 2:23 pm Post subject: |
wow. our weather is okay here
i opened the plug to see the strings of my cable to resold them i found out that according to this http://gamesx.com/wiki/doku.php?id=av:playstationav my cable should be right okay, .. i dont get it?!
| Description: |
| Filesize: |
7.27 KB |
| Viewed: |
17282 Time(s) |
mookee
| Posted: Sun Dec 29, 2013 4:07 pm Post subject: |
now i f..kd up the chip..; as i destroied two importent pins.. -PAUSED-
| Posted: Sun Dec 29, 2013 11:06 pm Post subject: |
Just but the 2 items in my link ubove. Its much easier, itll work straight away when you plug it in.
Your cable you showed a pic of was a component cable. No matter what you do to it, its the wrong cable.
mookee
| Posted: Mon Dec 30, 2013 3:48 pm Post subject: |
sorry, but how it can be wrong if the right pins are attached.. wrong material or how do you mean wrong. the ps multiav got 12 pins and for example the 3 rgb pins go to (i logicaly assume) the 3 rgb component plus plug of my cable, how can this be wrong anyway? the same with all the other pins
your items look great, but quite expensiv. and is the lm1881 in those?
| Posted: Mon Dec 30, 2013 10:18 pm Post subject: |
The component cable has a bridge moulded in to enable component..
mookee
| Posted: Mon Dec 30, 2013 10:47 pm Post subject: |
funny when you put it that way...I just spent $80+ dollars to run my 10 year old PS2 (FREE) into a beamer I paid $200 for 5 years ago
See you think before you buy. I just buy.
| Posted: Mon Dec 30, 2013 10:50 pm Post subject: |
Purchased! Thanks case! Now to see if I can get my guncon working... |
Just got shipping confirmation on the 4 BNC cable !
| Posted: Tue Dec 31, 2013 12:34 am Post subject: |
Youre laughin
mookee
| Posted: Tue Dec 31, 2013 12:30 pm Post subject: |
haha
| Posted: Wed Jan 01, 2014 6:42 am Post subject: |
Case, in the case (pun intended) of the Guncon 2 would I inject the Guncons RCA line on the Green BNC input thusly:
GreenBNCcable--BNCtoRCAadaptor--RCAinputOfGuncon2---RCAouputGuncon2--RCAtoBNCadaptor--GreenInputonProjector
