whats up with my bnc video line in on a nec 6pg plus
Posted: Mon Nov 25, 2013 7:22 am    Post subject:
CasetheCorvetteman wrote:
The 220uF caps in the RGB lines are there for AC coupling, not for safety!!
I know that, but I also know that the NEC's input are already AC coupled. Wink
mookee
Posted: Tue Nov 26, 2013 2:10 pm    Post subject:
"The quad decoder card is under the metal cover, closest to the back of the set, right in front of the rear panel. That metal cover covers 3 PC boards. If the slot closest to the back of the set, you do not have a quad decoder installed. It was optional with the 6PG sets, but did come with the 9PG sets. I do have a bunch here." ..
sorry, i dont get where you mean. you have a picture? . ah and by the way, how much do you think one of your card wouldcost inklusivly shipping to vienna. is there a name i can search for if it would cost unreasonable much geting it from you..?
bw and thanks christoph
mookee
Posted: Tue Nov 26, 2013 2:21 pm    Post subject:
all your wiring suggestions results in a 240p picture or better?. whats the original ps1 output, 680x something i guess, and so 240p doesnt sound much to me.. hmmm..?/
bw c
Posted: Tue Nov 26, 2013 7:10 pm    Post subject:
bw c
No, the PS1 output is really 240P!
And for the Decoder board see here: http://www.curtpalme.com/NECPG_Layout1.shtm
Posted: Tue Nov 26, 2013 7:13 pm    Post subject:
http://curtpalme.com/NECPG_Layout1.shtm\\
Second picture, the quad decoder board is under where the fan is.
$65 incl air shipping.
Posted: Wed Nov 27, 2013 12:01 am    Post subject:
gjaky wrote:
bw c
Not always, depends on the game, its always 15.7kHz, but can also be a higher resolution in an interlaced format.
mookee
Posted: Thu Nov 28, 2013 11:27 am    Post subject:
gjaky wrote:
5 min searching in the google gave the attached picture. Connect the red/green/blue signals to the projector with a proper 75 Ohm cable and you're ready for 240P at the lowest additional cost!
that looks easy, but this is for the ps2..,?
Posted: Thu Nov 28, 2013 11:30 am    Post subject:
Its for both PS1 and 2 yes.
Posted: Thu Nov 28, 2013 11:31 am    Post subject:
You will need the sync circuit as well, cause the NEC wont take the composite video as sync.
mookee
Posted: Thu Nov 28, 2013 11:46 am    Post subject:
hey.
whats the differenc between the LM1881M/NOPB and LM1881n/NOPB .. can i take all of them ?
thanks, bw c
Posted: Thu Nov 28, 2013 12:04 pm    Post subject:
Either one will work, just build the circuit as i posted it there.
Because the Playstation usually uses a CXA1645 but doesnt have the sync output connected to the AV socket, you will take the composite video as sync, which in my experience the NEC wont lock to when connected to the sync line. With that circuit, it should sync up fine.
Funnilly enough, the Sega Saturn and NEO-GEO CD also use the CXA1645, and the japan version of the saturn will work without the circuit added, ive never got the others to do so.
mookee
Posted: Thu Nov 28, 2013 2:06 pm    Post subject:
good things take time..) thanku!
Posted: Fri Nov 29, 2013 12:02 am    Post subject:
No worries mate Wink
Posted: Fri Nov 29, 2013 4:50 pm    Post subject:
Just throwing this one out there. I picked up The Walking Dead gun game. The signal wasn't hot enough for the Sony D50 I have here. It resulted in a dark streaky picture. When using the Sony's composite input.
I also picked up 4 Extron boxes recently. Two of which are Quad decoders. An Extron CD 900 ( about $35 bucks on eBay ) and an Extron QSD 204 ( about $40-50 on eBay ) The CD 900 is an older design. Not too bad and did fix the dark picture issue.
The QSD 204 really shines. It also has vertical shift which the CD900 does not. The '204 had a better over all picture.
The QSD 204 fixed the low signal problem and allowed me to move the picture vertically as well, within the raster, resulting in some good lookin' game play.
Too bad the new crop of gun games is no where near accurate.
EDIT: forgot to add, the QSD 204 will also output component YCbCr 480i/576i so this could come in handy for RPTV users. You would also be able to use any aspect ratio controls that the TV has in it.
Posted: Fri Nov 29, 2013 10:42 pm    Post subject:
What console is that on Jeremy?
Posted: Sat Nov 30, 2013 7:24 am    Post subject:
It's one of those stand alone plug into the TV games:
http://www.amazon.com/TV-Games-45188-Walking-Dead/dp/B0088AJQ9A/ref=sr_1_1?ie=UTF8&qid=1385796252&sr=8-1&keywords=walking+dead+game+video+game+shotgun
Posted: Sat Nov 30, 2013 7:30 am    Post subject:
Roger that, id never heard of it before. Did you ever end up getting those light guns working on a CRT projector there?
Posted: Sat Nov 30, 2013 2:55 pm    Post subject:
I'm going to have another stab at it now that I have the Quad decoder box. Last time I tried my PS2 with a line doubler into the D50. Time Crysis recognized that it was 480p but the guns didn't work that well.
Posted: Sat Nov 30, 2013 10:38 pm    Post subject:
Use it without the line doubler, it should be in 480i anyway on that game.
Posted: Sun Dec 01, 2013 12:23 am    Post subject:
Yeah, I realized that but the PS2 was a little hit or miss on the composite input of the D50. Hence the reason I ran it through the line doubler. Now with the Quad decoder I can run it 480i.
Page 2 of 8
