Change refresh rate in Marquee from 60hz to 120hz?
Posted: Fri Nov 22, 2013 7:33 pm    Post subject:
Looks nice.. Looks like there is some peaking involved, can you take a closeup of the marked area?
It actualy looks better than a standard marquee.. Unless it have a adjustet peaking fit for the resolution.
Posted: Fri Nov 22, 2013 7:48 pm    Post subject:
There 'ya go! A close up with all colors @1080P 85Hz:
just kidding! Very Happy
I have already switched off the system... But I don't think that's peaking, the vertical lines are on the left, AFAIK peaking is affecting the rise time, but in this case that would be the fall time, but more likely it is a simple pixel coincidence, see above, this is what I've used (Ecrabb's SMPTE pattern)
pattern zoomed
 Filesize:  23.61 KB
 Viewed:  3090 Time(s)
Posted: Fri Nov 22, 2013 7:57 pm    Post subject:
Here is a standard Marquee VIM with peaking, 1080P 72hz adjustet to high, but even at perfect level, it will display a bit of peak in the start of the horisontal line, and it will not be able to make a linear output whan changing output level.
And thats shows its not a real bandwidth, but faked with peaking.
Posted: Fri Nov 22, 2013 8:02 pm    Post subject:
Here you have a real clean bandwidth with no peaking, 1080P 72hz, 188Mhz
Posted: Fri Nov 22, 2013 8:06 pm    Post subject:
The peaking itself is not a problem, in fact it is good, as it helps to eliminate parasitic effects, the problem is the overshoot, but that isn't an issue if it is held in limits... Actually what I can see in your picture is that your vertical lines are brighter than the horizontal lines so that is over adjusted. If you watch my 1080P-75Hz pictures the vertical lines are nowhere near as bright as the horizontal lines, yet there is the brighter line at transition between the horizontal and vertical lines.
Posted: Fri Nov 22, 2013 8:08 pm    Post subject:
The difference is that you have dark line between horizontal and vertical lines, and I have a white line, that's why it looked brighter there, check it!
Posted: Fri Nov 22, 2013 8:28 pm    Post subject:
I know, but that should not elevate the output in that area.. look the pattern below, its built the same.
If you look the native pattern its still only 100% ire where the lines meet.. Not 110% Wink
So it is a error..
Posted: Fri Nov 22, 2013 8:34 pm    Post subject:
So it is a error..
I don't know... the pixels are so crowded there, they are heavily overlapped (thus giving more light output) due to the small tube size, it's hard to tell...
Posted: Fri Nov 22, 2013 8:38 pm    Post subject:
So it is a error..
Well no matter what its a damn nice resolving of 1080P 60Hz from a standard CRT.
Enough of this.. I think the thread starter now got a idea to see where his bandwidth limitations are, so he can push his performance to the max.
And not push the bandwidth of the machine where he will limit the dynamic range and ansi contrast on high resolution content in the movies.
