phillyguy83
| Posted: Thu Nov 21, 2013 2:01 am Post subject: Change refresh rate in Marquee from 60hz to 120hz? |
I just bought one of the 3D-Theatre boxes, and I want to run my Marquee 8500 at 60hz and then 120hz when playing 3D content to see if I notice a difference in quality. How do I change the PJ from 60hz to 120hz? I went through the menus but didn't see anywhere that listed options for the refresh rate.
digitalayon
| Posted: Thu Nov 21, 2013 6:12 am Post subject: |
Sorry man.....but I believe your source has to be the device to run at 120hz. But I would not go past 72.
stridsvognen Guest
| Posted: Thu Nov 21, 2013 6:34 am Post subject: |
You ned something that will scale to 720P 120hz You can not run full 1080P 120hz
digitalayon
| Posted: Thu Nov 21, 2013 8:32 am Post subject: |
| stridsvognen wrote: | | You ned something that will scale to 720P 120hz You can not run full 1080P 120hz |
Might be able to with unknown mods. Ha ha Eisermann claims this sh*t on his Barco mods.
stridsvognen Guest
| Posted: Thu Nov 21, 2013 8:34 am Post subject: |
| digitalayon wrote: | | stridsvognen wrote: | | You ned something that will scale to 720P 120hz You can not run full 1080P 120hz |
Might be able to with unknown mods. Ha ha Eisermann claims this sh*t on his Barco mods. |
Yeah well.. He just seems to have lost the proves, and no one can back him up lol
digitalayon
| Posted: Thu Nov 21, 2013 2:54 pm Post subject: |
| stridsvognen wrote: | | digitalayon wrote: | | stridsvognen wrote: | | You ned something that will scale to 720P 120hz You can not run full 1080P 120hz |
Yeah well.. He just seems to have lost the proves, and no one can back him up lol |
lol....are his pic really gone? Wondering what happened to them and his outrageous claims.
HK-Steve
| Posted: Thu Nov 21, 2013 4:38 pm Post subject: |
I ran some test a long time ago with my Marquee at 120Hz and my HTPC, was a thread.
So can be done.
HK-Steve
Flame suit ON.....
stridsvognen Guest
| Posted: Thu Nov 21, 2013 4:41 pm Post subject: |
| HK-Steve wrote: | | Flame suit ON..... |
LOL.. Sure it can be done.. But you cant resolve that framerate.. You need a bit more bandwidth.. it will role of much to early.
Unless you run a low resolution like 720P and it still wont resolve it fully
HK-Steve
| Posted: Thu Nov 21, 2013 4:50 pm Post subject: |
Looked pretty good on screen with movies, no not as sharp as 75Hz and 72Hz,
| Posted: Thu Nov 21, 2013 7:08 pm Post subject: |
Guys
96hz is widely used in computer-generated 3D; try that if the source can manage it. However, you may have lag issues on the green unless your green tube is P43
digitalayon
| Posted: Thu Nov 21, 2013 7:25 pm Post subject: |
ZAP ZAP POP POP!!!
| Posted: Thu Nov 21, 2013 9:42 pm Post subject: |
| digitalayon wrote: | | ZAP ZAP POP POP!!! |
720p at 96hz refresh actually uses less bandwidth than does 1080p at 60hz. About 70% of the bandwidth, actually. So, Tim makes a really good point... If your source and 3D processor can take a 3D film source and output 720p/96, that could be a pretty good option for CRT.
kal Forum Administrator
stridsvognen Guest
| Posted: Fri Nov 22, 2013 2:31 pm Post subject: |
I think the Marquee will do fine with 720P 120Hz, it will match the bandwidth of the machine.
720P 96 hz will maybe still be a bit high for the low bandwidth machines like Barco.
I dont know how 3D looks on a CRT, ill guess 96hz will flicker as crazy as 48hz 2D
60 hz is almost free of flicker.
| Posted: Fri Nov 22, 2013 6:50 pm Post subject: |
| stridsvognen wrote: | I think the Marquee will do fine with 720P 120Hz, it will match the bandwidth of the machine.
60 hz is almost free of flicker. |
You should have very badimpression on barcos...
I show you how my NEC (marketed bandwidth is 100MHz) have done 720P-120Hz.
| Description: |
| Filesize: |
114.55 KB |
| Viewed: |
12274 Time(s) |
stridsvognen Guest
| Posted: Fri Nov 22, 2013 6:58 pm Post subject: |
Its always nice when the bandwidth is better than promised..
But when the Barco 909 wont even resolve 1080P 60 Hz, around 150Mhz, i doubt it will do 720P 120Mhz, guess around 140Mhz
Try shoot a pic of the SMPTE pattern on HD Basic, with all 3 tubes in different resolutions and framerates, Would be fun to se how the NEC holds 1080P 60 hz.
| Posted: Fri Nov 22, 2013 7:01 pm Post subject: |
| stridsvognen wrote: | | Try shoot a pic of the SMPTE pattern on HD Basic, with all 3 tubes in different resolutions and framerates, Would be fun to se how the NEC holds 1080P 60 hz. |
What about a green shot with 1080P-60-75-85Hz?
stridsvognen Guest
| Posted: Fri Nov 22, 2013 7:04 pm Post subject: |
| gjaky wrote: | | stridsvognen wrote: | | Try shoot a pic of the SMPTE pattern on HD Basic, with all 3 tubes in different resolutions and framerates, Would be fun to se how the NEC holds 1080P 60 hz. |
What about a green shot with 1080P-60-75-85Hz?  |
Thats ok, but all colors shows better that it holds the bandwidth with no peaking or roleoff on all tubes, like they have different gain they will respond different if the bandwidth is not perfect.
| Posted: Fri Nov 22, 2013 7:27 pm Post subject: |
| stridsvognen wrote: | | gjaky wrote: | | stridsvognen wrote: | | Try shoot a pic of the SMPTE pattern on HD Basic, with all 3 tubes in different resolutions and framerates, Would be fun to se how the NEC holds 1080P 60 hz. |
Thats ok, but all colors shows better that it holds the bandwidth with no peaking or roleoff on all tubes, like they have different gain they will respond different if the bandwidth is not perfect. |
I understand you, but on a NEC it's a bit hard to take fun pictures like this because if you send a new signal to it, it will load the convergence data from a default area, and in my case it loads a sh!t color balance with sh!t convergence
pictures are actual 1:1 cutouts (except info page)
| Description: |
| fh=96kHz on a NEC PG xtra !!! OOOhhh the deflection board is just blowing up! :D |
| Filesize: |
52.69 KB |
| Viewed: |
11733 Time(s) |
| Description: |
| Filesize: |
28.67 KB |
| Viewed: |
11736 Time(s) |
| Description: |
| Filesize: |
27.79 KB |
| Viewed: |
11737 Time(s) |
| Description: |
| Filesize: |
24.1 KB |
| Viewed: |
11739 Time(s) |
