| Posted: Sun Feb 09, 2014 4:22 am Post subject: |
| winny wrote: | | No 7.4 or 7.41 ROM or ROM-file yet. |
Did you get your software?
winny
| Posted: Sun Feb 09, 2014 8:22 am Post subject: |
Still nothing.
| Melifluonze wrote: | | Digital is easy. This is torture, but far more interesting... |
winny
| Posted: Fri Mar 02, 2018 5:44 pm Post subject: |
Four years later and problem is fixed. Turns out you can swap in the Graphics logic board into the Data without any issues and with the 7.61 Graphics ROM and a loose connection found later, the LiMo was recognized. Hooray!
I fiddled around with a lot of settings but my composite NTSC laserdisc did not look good. The scandoubling worked fine and removed any visible lines but it looked kind of horrible. I realize I can’t compare it with 40+ Mbit/s HD source, but edges around hard color changes, say skin tone to blue sky had problems.
| Posted: Fri Mar 02, 2018 10:04 pm Post subject: |
| winny wrote: | Four years later and problem is fixed. Turns out you can swap in the Graphics logic board into the Data without any issues and with the 7.61 Graphics ROM and a loose connection found later, the LiMo was recognized. Hooray!
I fiddled around with a lot of settings but my composite NTSC laserdisc did not look good. The scandoubling worked fine and removed any visible lines but it looked kind of horrible. I realize I can’t compare it with 40+ Mbit/s HD source, but edges around hard color changes, say skin tone to blue sky had problems. |
Glad to hear you have this working. So was it worth the effort?
winny
| Posted: Sat Mar 03, 2018 8:36 am Post subject: |
Questionable. It does offer a one-remote solution to laserdisc. I’ll fiddle around some more with the settings before I give any final verdict.
The overall build however, was very much worth the effort and our new movie theater get to see so much use we need a second row of sofas. I’ll think I should create a build thread about it since it turned out so good.
One question about data versus graphics and non-s versus s projectors, I noticed several more menus for picture tuning compared to my 1209/2. Separate left and right picture tuning and corse convergence. This did break my normal calibration routine. Is there any guide or thread about the corse convergence in particular? I didn’t quite “get it” before the fine convergence was set and then it was too late.
