Squealing and buzzing Cine 9
Goto page 1, 2, 3  Next
Posted: Sat Oct 26, 2013 2:02 pm    Post subject: Squealing and buzzing Cine 9
Id really like to find out what board is causing this issue so I can fix this thing.
Firstly the buzzing and squealing. I don't care what anyone says, ITS NOT NORMAL.
The sounds come and go depending partly on what is on the screen. Certain brightness levels of images will cause it, and it is usually accompanied by some noisy lines top and bottom of the screen. Its not exactly quiet, and resolution or scanrate has nothing to do with it. Its like as if there is some serious ripple current going around in there somewhere.
Jittering sections of the image. Seems to follow zones, the centre is generally fine and stable, top and bottom usually are also. I noticed today while adjusting digital focus that it has an effect on the distorted lines and to a minor degree the amount of jittering in that zone. I have been made aware that there were revised focus boards, I will post pics below of what is in mine.
None of these issues follow temperature. Doesn't make any difference if the machine is stone cold at 18*C or been running all day and sitting on 32-33*C, nothing changes.
There is no way known they could've possibly come out of the box new like this, no one in their right mind would have accepted that "they just do that".
barclay66
Posted: Sat Oct 26, 2013 2:50 pm    Post subject:
Maybe one of the old tricks may help You with this one:
When I had to repair a TV set which produced buzzing and crackling noises I used a small rubber hose (about 1cm in diameter and about 30cm long). I would put one end to my ear and use the other one in order to find out the exact location of the noise's source. By this I found quickly that there was a small transformer and a weak solder Joint that needed some care...
Regards,
barclay66
Posted: Sat Oct 26, 2013 7:41 pm    Post subject:
"Squealing and buzzing Cine 9"
Stop housing pigs and bees in there. Very Happy
Posted: Sat Oct 26, 2013 7:42 pm    Post subject:
Piezoelectric effect.
Have fun Wink
Posted: Sat Oct 26, 2013 10:09 pm    Post subject:
Regards,
barclay66
Thanks Barclay, i will have a dig around and see what hoses i have. Its making it very difficult to get a good image.
Posted: Sun Oct 27, 2013 3:13 am    Post subject:
Well I opened the back cover, the twitching is almost gone...
Buzzing is still there, but seems a lot less with the cover open. A couple pics shortly
Posted: Sun Oct 27, 2013 3:17 am    Post subject:
I can't see any squeal or buzzing as normal. If it changes with Image changes I am wondering if its a cap. Barclays idea sounds like a way to narrow it down. I think I mentioned before now that Curt and others do replace a bunch of caps on those sets before they sell them.
Posted: Sun Oct 27, 2013 3:18 am    Post subject:
Buzzing and squealing seems to be coming from that big brown block there under the little black cover. It has a small red wire that comes out ( as well as the larger one that goes to the splitter ) and that small red wire seems to go nowhere....
All the green lights are on:
Posted: Sun Oct 27, 2013 3:19 am    Post subject:
km987654 wrote:
I can't see any squeel or buzzing as normal. If it changes with I.age changes I am wondering if its a cap. Barclays idea sounds like a way to narrow. I think I mention before now that Curt and others do replace a bunch of caps on those sets before they sell them.
Yeah its not normal, it CANT be, cause its louder than the fans. Although the fans are really quiet, that isn't the point is it Laughing
Posted: Sun Oct 27, 2013 3:20 am    Post subject:
That's the EHT.
Posted: Sun Oct 27, 2013 3:21 am    Post subject:
Sorry the quadrupler the black cover is the EHT.
Posted: Sun Oct 27, 2013 3:25 am    Post subject:
Hv issue, SMPS or g2 board is my guess.
Posted: Sun Oct 27, 2013 3:26 am    Post subject:
As you know that's where your 35kv comes from and the insulation on those does break down. That would certainly cause the sound you are hearing and it would vary with the image.
Posted: Sun Oct 27, 2013 3:27 am    Post subject:
As in the power supply in my pic or is there another board that pulls out? There seems to be no info on which board does what.
Voltage diagnostics on the screen are pretty stable from cold to hot, and pretty close to what their name is.
Posted: Sun Oct 27, 2013 3:30 am    Post subject:
What does seem REALLY strange is that the jittering has almost gone completely just by opening the back cover. It is there right from stone cold start up, so I very much doubt it would be heat soak...
There are just 2 or 3 very little jitters there.
Posted: Sun Oct 27, 2013 4:03 am    Post subject:
Will pulling the LIMOPRO board out improve anything? I don't use it and am led to believe it was optional....
Posted: Sun Oct 27, 2013 4:29 am    Post subject:
Here are the voltages at cold start:
ElTopo
Posted: Sun Oct 27, 2013 7:01 am    Post subject:
I cannot remember but i haven't seen a small red on mine.
Barco Cine 9 the one and only
Posted: Sun Oct 27, 2013 8:08 am    Post subject:
Small red what? Light? None of those are on with mine either, there is 2 or 3 red ones on a couple boards, and an orange one. Only green LEDs are on.
What colour is your case on your Cine 9?
Posted: Sun Oct 27, 2013 8:28 am    Post subject:
What is this all about?
Page 1 of 3
