Proposal to Marquee owners
the big E
Posted: Sun Oct 27, 2013 2:30 am    Post subject:
CasetheCorvetteman wrote:
A TOP3000 will probably do what you need, theyre not expensive. Youll need a computer with 32 bit windows on it.
I link for that would be great
As far as the computer goes I got that covered Smile
I actually have a few desktops that I haven't sold so I may use one for this as it has windows 7 32bit ultimate (the only version of windows 7 I use in both 32 and 64 bit)
Never mind the link I found it pricey but will be worth it in the long run
Going to wait until the latest software is worked out till I take the plunge Smile
crt king of black
Posted: Sun Oct 27, 2013 3:15 am    Post subject:
Ill check Ebay in a minute
Posted: Sun Oct 27, 2013 3:24 am    Post subject:
Ok, this one will get you the lot, which is what I got, PLC adaptors and chip puller included:
http://www.ebay.com.au/itm/NEW-TOP-TOP3000-USB-Universal-Programmer-MCU-PIC-AVR-51-/300529563608?pt=AU_B_I_Electrical_Test_Equipment&hash=item45f8f537d8
This is the cheapest at my end, but looks as though you don't even get the power supply, I rarely use it, but that's not the point either.
http://www.ebay.com.au/itm/Brand-New-TOP3000-USB-Universal-Programmer-/181244930203?pt=AU_B_I_Electrical_Test_Equipment&hash=item2a330a289b
This one has the USB cable and PSU, but not the PLC adaptors or the chip puller. Has some specs there, Barclay might be able to tell you if itll do the job or not.
http://www.ebay.com.au/itm/New-TOP3000-USB-Universal-Programmer-MCU-PIC-AVR-51-/160772786492?pt=AU_B_I_Electrical_Test_Equipment&hash=item256ece093c
Posted: Mon Oct 28, 2013 12:05 am    Post subject:
the big E wrote:
I will be glad to hear the outcome of this as my marquee has version 4.2c and I want to update it if possible
Downside is I don't have a computer to use the loader program or a chip puller Sad
The Marquee Control/Loader program is just for controlling the marquee and saving its settings you know, it is not for
reading PLC chips as the things Case is linking to.
All you need is a computer, download the marquee control program 2.3 from Curts site in the marquee section and a RS 232 cable. Run the program select the com port that recognizes the Marquee connected to it and download and save the configuration file.
The program can also control all functions of the marquee.
Athansios
