mx83toy
| Posted: Thu Oct 03, 2013 11:13 pm Post subject: Just Picked up my XG75 - Toast anyone??? |
Picture tells a thousand swear words...
| Description: |
| Filesize: |
139.44 KB |
| Viewed: |
6738 Time(s) |
| Description: |
| Filesize: |
109.68 KB |
| Viewed: |
6738 Time(s) |
| Posted: Thu Oct 03, 2013 11:19 pm Post subject: |
Posted to the other post before I saw this one. Those really are pretty typical for NEC XG sets, and within the wear area, you'll still get a decent picture believe it or not. I've had many customers using far worse than that. Almost guaranteed that's the condition any NEC XG will be in that was used regularly. nothing new here I'm afraid.
| Posted: Thu Oct 03, 2013 11:21 pm Post subject: |
You will probably be surprised how decent an image it can still throw once you do a rough grayscale on it.
| Posted: Thu Oct 03, 2013 11:49 pm Post subject: |
There is nothing wrong with it, just use it. Mine were worse than that when i got my DTV991, i only swapped them out for better ones cause it was 16:9 wear and i used a 5:4 screen for retro gaming.
Ive got a better green than that here that came from another set but itll cost you alot more than the set did.
mx83toy
| Posted: Fri Oct 04, 2013 12:23 am Post subject: |
Three very reputable responses telling me to use it well she'll be setup tonight then !!! ( if i can figure out all the buttons on this huge remote that is)
mx83toy
| Posted: Fri Oct 04, 2013 12:24 am Post subject: |
Cas can we make it a straight swap for the 7???
| Posted: Fri Oct 04, 2013 12:31 am Post subject: |
| mx83toy wrote: | Three very reputable responses telling me to use it well she'll be setup tonight then !!! ( if i can figure out all the buttons on this huge remote that is)  |
Just be sure to keep your image inside the existing wear patterns.
mx83toy
| Posted: Fri Oct 04, 2013 12:38 am Post subject: |
I'll need to do my best to max it out best i can as my room is stupid small ive literally got its but up against the wall ive got a feeling i'll be struggling to push 60-70" room is only 2.8 meters long wall to wall and the xg takes up half of it (this thing is huge compared to the cine 7 !!!!! )
| Posted: Fri Oct 04, 2013 1:54 am Post subject: |
| mx83toy wrote: | | Cas can we make it a straight swap for the 7??? |
Are you out of your f***en mind?!?!?!? No chance!!
| Posted: Fri Oct 04, 2013 1:58 am Post subject: |
| mx83toy wrote: | I'll need to do my best to max it out best i can as my room is stupid small ive literally got its but up against the wall ive got a feeling i'll be struggling to push 60-70" room is only 2.8 meters long wall to wall and the xg takes up half of it (this thing is huge compared to the cine 7 !!!!! ) |
HD-144 lenses with that raster size and 2.5m or so center to screen should get you around 100" 4:3, probably 1.8-2m wide.
| Posted: Fri Oct 04, 2013 2:03 am Post subject: |
Bounce it off a mirror
mx83toy
| Posted: Fri Oct 04, 2013 2:04 am Post subject: |
| CasetheCorvetteman wrote: | | mx83toy wrote: | I'll need to do my best to max it out best i can as my room is stupid small ive literally got its but up against the wall ive got a feeling i'll be struggling to push 60-70" room is only 2.8 meters long wall to wall and the xg takes up half of it (this thing is huge compared to the cine 7 !!!!! ) |
HD-144 lenses with that raster size and 2.5m or so center to screen should get you around 100" 4:3, probably 1.8-2m wide. |
might just do the trick....
mx83toy
| Posted: Fri Oct 04, 2013 2:06 am Post subject: |
| AnalogRocks wrote: | | Bounce it off a mirror |
was thinking about this then realized what i was thinking about doing and slapped myself that would just get way too hard for me
| Posted: Fri Oct 04, 2013 2:10 am Post subject: |
Dont use a mirror, you wont need to.
| Posted: Fri Oct 04, 2013 11:27 pm Post subject: |
I propose some toast!
| Posted: Sat Oct 05, 2013 1:24 am Post subject: |
Those arent toast yet. Wouldve been alot better if they installed it square to the screen though.
Jeremy112
| Posted: Sat Oct 05, 2013 2:48 pm Post subject: |
And I thought my old tubes had wear. I still have my old tube set, nowhere near that bad. I only replaced mine because the green tube cracked so I bought a whole set that made its way on here from another XG'er. I guess I should consider myself very lucky to have the tubes I do in the XG, I could rate them all at a solid 7 out of 10, only a slight hint of wear when looking at the tube faces.
But as others say, you'll still get a nice sharp and pretty damn colorful image out of those tubes yet, just not AS colorful. Nice score!!
| Posted: Mon Oct 07, 2013 8:55 am Post subject: |
Don't forget to bleed the tubes.
| Posted: Mon Oct 07, 2013 8:57 am Post subject: |
Id love to know who set it up skew to the screen like that too, not exactly ideal!! Its not like as if its that hard to get it right....
ElTopo
| Posted: Mon Oct 07, 2013 9:17 am Post subject: |
Personally i would not use those tubes too toasty.
Any chance to get newer or minty ones ?
