Barco S of small Modification a qualitative change in focus
Posted: Sat Sep 28, 2013 9:13 pm    Post subject:
http://export.farnell.com/_/dp/1383726
Posted: Sat Sep 28, 2013 9:15 pm    Post subject:
Posted: Sat Sep 28, 2013 9:21 pm    Post subject:
Posted: Sat Sep 28, 2013 9:22 pm    Post subject:
Posted: Sun Sep 29, 2013 7:44 am    Post subject:
Posted: Sun Sep 29, 2013 7:46 am    Post subject:
Posted: Sun Sep 29, 2013 7:47 am    Post subject:
Posted: Sun Sep 29, 2013 7:48 am    Post subject:
What the hell happened there??
Posted: Sun Sep 29, 2013 9:37 pm    Post subject:
Try again eh?
http://it.farnell.com/nte-electronics/nte2501/rf-transistor-npn-600mv-70mhz/dp/1383726?Ntt=nte2501
Posted: Mon Sep 30, 2013 5:51 am    Post subject:
This is only good for up to 70MHz, the transistors in the the VPH06 probably already better than this.
Posted: Mon Sep 30, 2013 11:54 pm    Post subject:
Youre reading the data sheet wrong Gabór
Posted: Tue Oct 01, 2013 6:05 am    Post subject:
Why? The problem is with the VPH06 that the transistors inside are too slow, right? By changing the output transistors to faster could only mean performance improvement. I don't see what to do with this NTE2501 in this application, this transistor is worse in every key parameters than the 2SC3600 that the OP had originally suggested.
Decibel
Posted: Tue Oct 01, 2013 5:52 pm    Post subject:
It's very hard to open the vph's chip.
I had to heat the microchip to open it.
Now I would to know other components to do the mod.
Domenico (Barco fan!)
Posted: Tue Oct 01, 2013 5:54 pm    Post subject:
The transistors you want to substitute are under the brown shield...
zxh398
Posted: Tue Oct 08, 2013 1:57 am    Post subject:
The specific method of modifying IC
 Filesize:  212.73 KB
 Viewed:  11891 Time(s)
 Filesize:  215.43 KB
 Filesize:  236.77 KB
 Filesize:  241.37 KB
 Filesize:  260.99 KB
 Filesize:  221.28 KB
 Filesize:  226.47 KB
 Filesize:  208.02 KB
 Filesize:  158.83 KB
 Filesize:  229.18 KB
zxh1353@hotmail.com
zxh398
Posted: Tue Oct 08, 2013 2:10 am    Post subject:
Modified significantly enhance the focus, the subtitles are formed by the scan line
Enlarge the screenshot you can see a clear line
 Filesize:  58.73 KB
 Viewed:  11889 Time(s)
1080P
 Filesize:  102.33 KB
 Filename:  SDC10502.JPG
 Filesize:  383.43 KB
 Downloaded:  509 Time(s)
 Filename:  SDC10479.JPG
 Filesize:  299.32 KB
 Downloaded:  579 Time(s)
 Filename:  SDC10503.JPG
 Filesize:  362.78 KB
 Downloaded:  496 Time(s)
 Filename:  SDC10481.JPG
 Filesize:  197.47 KB
 Downloaded:  462 Time(s)
 Filename:  SDC10477.JPG
 Filesize:  315.25 KB
 Downloaded:  471 Time(s)
zxh1353@hotmail.com
gnnash
Posted: Mon Apr 07, 2014 5:42 pm    Post subject:
I'm very curious... has anyone other than zxh398 actually succeeded in this mod? The ICs seem to be quite easily available on ebay...
Posted: Mon Apr 07, 2014 6:07 pm    Post subject:
-These ICs are very fragile inside, easy to ruin while you want to disassemble, needs delicate skills.
-The suggested 2sa106/2sc3600 transistors are hard to find, while no one seems to have experience with the NTE replacement.
digitalayon
Posted: Mon Apr 07, 2014 6:21 pm    Post subject:
Man....wonderful....simply wonderful.
gnnash
Posted: Mon Apr 07, 2014 8:26 pm    Post subject:
Hmm... the transistors both seem to be available for purchase on eBay, in the US anyway.
I would be interested in buying a spare neckboard to try this on, if only the instructions were a bit clearer about what exactly was going on, or included schematics of the actual mod.
Page 2 of 3
