| Posted: Tue Sep 10, 2013 2:24 am Post subject: |
Best thing you can do at this point I think is send me the RGB input board which also contains the microprocessor. Assuming you're within the US, it's $50 incl return shipping to test the board. No real other way to narrow it down at this point I'm afraid.
| Posted: Tue Sep 10, 2013 3:23 am Post subject: |
Did you by chance hit the picture "MUTE" button?
linuxfox00
| Posted: Tue Sep 10, 2013 3:25 am Post subject: |
no i tried that one im fearing that rgb doesn't not work is that even possible with component video working on the same board?
| Posted: Tue Sep 10, 2013 4:27 am Post subject: |
Curt, am I just remembering things, or haven't you said the factory reset isn't really a good idea on the Sony machines. I seem to remember returning all my controls to 127 manually to do a scratch setup because you said factory reset was risky for some reason.
Sorry, OP. Bummer you're having issues, but you'll get it sorted out.
| Posted: Tue Sep 10, 2013 6:17 am Post subject: |
Crabb, i kind of remember reading that somewhere too!!
| Posted: Tue Sep 10, 2013 1:11 pm Post subject: |
I just don't like doing hard resets or firmware updates unless it's REALLY necessary (as in a memory dump on an NEC XG chassis.
I keep seeing posts over the years where people have nothing but prob;ems after a hard reset, so I discourage it. Worst case in the case of a 909, the controller board locks up during a firmware upload, and now you're out $3500 (price of a new controller board from BArco !)
Just say no, don't do it!
| Posted: Tue Sep 10, 2013 4:06 pm Post subject: |
SO I should go reset my D50 then?
| Posted: Tue Sep 10, 2013 4:42 pm Post subject: |
Yeah would ya? Can't wait to spend a couple of hours on a tech support phone call.
| Posted: Tue Sep 10, 2013 5:05 pm Post subject: |
I fear the wrath of the Angy Hand ( Curt Palme )
linuxfox00
| Posted: Tue Sep 10, 2013 8:56 pm Post subject: |
on the input info menu the input signal reads INT OSC what does that mean? im looking at the list in the manual and it doesn't list that as a type.
| Posted: Tue Sep 10, 2013 11:33 pm Post subject: |
It means the projector is synced to the internal oscillator, or in other words, it doesn't see a signal on the selected input.
Cheers,
linuxfox00
| Posted: Wed Sep 11, 2013 12:52 am Post subject: |
i guess ill try a new cable and see what happens.
| Posted: Wed Sep 11, 2013 1:54 am Post subject: |
What does composite do?
linuxfox00
| Posted: Wed Sep 11, 2013 1:56 am Post subject: |
setting my input a VGA to composite does nothing. the composite input works just fine i ran my laser disc player just fine thought it.
| Posted: Wed Sep 11, 2013 4:15 am Post subject: |
Well that will be twice this month that I've seen that in a D50. Problem is, the other one is in Germany, so I sold the RGB input board outright, he didn't send in his for repair. If you want to send me yours, I'd be curious to see what the issue is.
linuxfox00
| Posted: Wed Sep 11, 2013 4:17 am Post subject: |
| Curt Palme wrote: | | Well that will be twice this month that I've seen that in a D50. Problem is, the other one is in Germany, so I sold the RGB input board outright, he didn't send in his for repair. If you want to send me yours, I'd be curious to see what the issue is. |
Thanks Curt i will probably ship it out to you once i get these cables im guessing they will come next week then we'll see.
linuxfox00
| Posted: Tue Sep 17, 2013 12:49 am Post subject: |
Well it was the cable after all. Thanks for your support vga works fine.
next how do i save my settings in component video and in input A so i don't have to realign each time.
i read that you just press memory but it saves the setting but when i go back to component its over wrote it
