New (to me) Runco DTV-1100 / BD 1209s!!
gnnash
Posted: Fri Sep 06, 2013 2:34 pm    Post subject: New (to me) Runco DTV-1100 / BD 1209s!!
Well, I was all ready to set up my minty 1271 this Saturday, when I saw an interesting ad on Criagslist... a Runco DTV-1100, for FREE!
Went down right after work and snapped it up, had wayy too small of a car, but when there's a will, there's a way! Made for an interesting picture anyway!
I haven't fired it up myself yet, will do that tomorrow, but I'm told that it works, though it has some 4:3 wear on the green, which is in an unfortunately smallish area... I'll try to live with it, and maybe level it out later if I get the ambition, and re-tube it if cheap tubes show up.
This is my first Barco, and really the first CRT that I'll actually get around to setting up, so I just had a few questions:
-I probably won't be using the "Eye Q" (Barco Iris) camera, does it make sense to remove it and its controller to save the power supply a bit, or doesn't it really matter?
-Will pulling the Port 3 board make an appreciable difference in power supply longevity? I probably won't use it either.
-Anybody have any DTV-1100 hinges for the top cover laying around? I would assume that the 1209s hinges are also the same, just a different color. Both of mine are broken.
So... do I suck?
 Filesize:  178.42 KB
 Viewed:  11561 Time(s)
Posted: Fri Sep 06, 2013 3:16 pm    Post subject:
Good score.
Did you have the lenses covered while the projector was in the sun pointing up? Check your celements and make sure you didn't melt them with sunlight coming through the lenses.
Fingers crossed...
gnnash
Posted: Fri Sep 06, 2013 3:28 pm    Post subject:
CIR Engineering wrote:
Good score.
Fingers crossed...
Hmm... That's not something I would have ever thought of.
There were no caps, so the lenses were not covered. Sun was at a pretty low angle by then though, and I only spent any appreciable time parked with the lenses pointed north, so hopefully all is well.
Looked through the lenses as best as I could, and everything looks clear, so I think I'm fine, but tomorrow will tell when I pull the lenses off.
If I had melted them, wouldn't I have glycol all over?
Posted: Fri Sep 06, 2013 4:27 pm    Post subject:
Nope, the lenses are quite thick, and it just burns small pits and bubbles in the surface of the lens.
Hopefully, if you weren't parked for any length of time, and if the sun was low enough that it never went directly into the lens (or if it was, you were moving), you'll be OK.
A DTV-1100 is a great machine... Free is unbelievable. Total score!
Crossing my fingers for you.
benareeno
Posted: Fri Sep 06, 2013 6:33 pm    Post subject:
that picture is freaking hilarious!
Huge score!
ElTopo
Posted: Fri Sep 06, 2013 6:54 pm    Post subject:
Congrats Thumbs Up
Awesome projector !
Barco Cine 9 the one and only
Posted: Fri Sep 06, 2013 7:51 pm    Post subject:
Agreed. Oh, it's a turbo Dodge, too... ronholm would be so proud. Wink
gnnash
Posted: Fri Sep 06, 2013 7:57 pm    Post subject:
Haha I've got two more, too! In retrospect, one of the Daytonas would have probably been better at holding it, but it would have been a lot harder to get in and out!
Decibel
Posted: Fri Sep 06, 2013 9:18 pm    Post subject:
congrats!
Thumbs Up
Domenico (Barco fan!)
Posted: Fri Sep 06, 2013 9:29 pm    Post subject:
The camera wont save you a damn thing on power, so i wouldnt bother removing it!!
Im not sure how the IRIS goes on a 1209, but on my Cine 9 it sure does save alot of time, if you have the camera set up properly it will get it very close to perfect. I set the geometry up on the green first and get it perfect, then run the IRIS, then after that i will pull up a test pattern from my PC and evaluate whether to use coarse or fine to get it perfect ( or as close to as you can get with a Barco )
I use port 3 for the MOOME V3 box, i tried both it and 4/5, both identical on my Cine 9, so it may be worth a shot to try it so youve got 2 inputs there. Run a HDMI up to the converter then RGB to port 3, then RGB-HV to port 4/5 for a PC. ( or the other way round if youd rather! )
Last edited by CasetheCorvetteman on Fri Sep 06, 2013 9:39 pm; edited 1 time in total
Posted: Fri Sep 06, 2013 9:33 pm    Post subject:
And f*** i almost forgot...
YOU SUCK!!! Very Happy
Its certainly a damn fine machine you got there Wink
VideoGrabber
Posted: Sat Sep 07, 2013 11:48 am    Post subject:
Cool. A mobile HT! Gives a new meaning to 'drive-in movies'. All you need now is a big sheet, or a blank wall on a building.
(Oh, but that keystoning will be a killer. Smile Drop it down by driving the front of the car up a small ramp.)
- Tim
Posted: Sat Sep 07, 2013 12:17 pm    Post subject:
You have to attach a mirror on the roof so it will project in the right rirection Very Happy
BTW nice pj for the money Wink
gnnash
Posted: Sat Sep 07, 2013 12:21 pm    Post subject:
Hehe I've been waiting for the day I could be told that around here!
Lenses come off in a couple hours, keep those fingers crossed!
RayN999
TV/Projector: Sony VPL-VW60 and Toshiba 65H84 CRT RPTV
Posted: Sat Sep 07, 2013 4:35 pm    Post subject:
That's what I get for not trolling Minneapolis CL for a few days. Nice grab, congrats!!
Ray Nelson
N9QBV
gnnash
Posted: Sat Sep 07, 2013 7:04 pm    Post subject:
Hey, I think there's still a free am pro with new green tube on there, grab it!
RayN999
Posted: Sat Sep 07, 2013 7:48 pm    Post subject:
Thanks for the info, but I have a bad back. And for that reason, house rules are such that if I can't lift it, I can't own it (for projectors). Limiting me to a digital (blech!) that's around 30 lbs or less.
That being said, I do have a line on a Sony VPL-VW40 for a reasonable price. Just need to get funds scraped up for it & then go collect it from Jeremy in WI.
But, you STILL SUCK!!
Ray
Ray Nelson
N9QBV
Posted: Sat Sep 07, 2013 8:45 pm    Post subject:
Nice LeBaron with the CS wheels too! ......and the back seat accessory isn't too bad either!
jeffslife
Posted: Sat Sep 07, 2013 8:48 pm    Post subject:
Great Pic !!!! One of us One of us One of us...............................................................
We are ALL job creators !
gnnash
Posted: Sun Sep 08, 2013 12:19 am    Post subject:
Well, thankfully I don't have any melted c-elements! I've got her all set up on the floor for now, though I'm sure I'll be tweaking things for a loooonng time!
I've got an issue with 1080p though, starting a new thread with that!
