Help to rotate image Vidikron Vision One
Machi
Posted: Sun Aug 18, 2013 9:23 pm    Post subject: Help to rotate image Vidikron Vision One
Hello everyone! I was able to buy a projector "Vidikron Vision One". But I failed to rotate the image 180 degrees. Was installed on a roof. Now I want to install it on a table. Anyone know how I can do? I'm pretty sure it can not be done from the setup menu. I think it should be done from inside the projector, with the hardware.
I searched the manual all over the net, but I have not found. Someone has it? I would be very grateful if someone helps me.
Sorry for my horrible English Mr. Green
Here some pics:
 Filesize:  92.47 KB
 Viewed:  11590 Time(s)
 Filesize:  109 KB
Posted: Sun Aug 18, 2013 9:43 pm    Post subject:
Hello
Unplug power, then take the top cover off. Locate three red/white/blue wire bundles on top of the tubes, these are the horizontal yoke harnesses. There is a coupler in each harness; unplug at the couplers one at a time and flip the plugs over so red faces red and blue faces blue, and reconnect.
On the rear heat sink locate three yellow/green harnesses for the vertical yokes (no coupler). Unplug these from the vertical board one at a time and flip them over, and reconnect carefully so they are square on the pins, not shifted sideways.
Power up and check your picture before putting the cover back on.
Machi
Posted: Mon Aug 19, 2013 12:12 am    Post subject:
Thanks Tim in Phoenix! Solved!
Posted: Mon Aug 19, 2013 1:42 am    Post subject: Re: Help to rotate image Vidikron Vision One
Here some pics:
Welcome to the forum and congrats on your new 9 Inch Marquee/Vision One!!
You deserve a YOU SUCK !!! Very Happy
(We say you suck when someone gets a 9 inch CRT projector)
Machi
Posted: Mon Aug 19, 2013 3:03 am    Post subject: Re: Help to rotate image Vidikron Vision One
Here some pics:
LOL Laughing
Thanks! Thumbs Up
I bought it by accident. Appeared the opportunity and was very cheap. Over a year ago buy a RCF, but with many years. But still works. When I saw it projected, I went crazy. And when I found the Vision One so cheap I bought it immediately.
Sorry again for my english. Google translate helps me Mr. Green
the big E
Posted: Mon Aug 19, 2013 7:38 pm    Post subject: Re: Help to rotate image Vidikron Vision One
Here some pics:
LOL Laughing
Thanks! Thumbs Up
I have a vison 3 and plan on converting it to a vision 1
Love that case and I wish I had one just to drop the inside of my vision 3 in
It is a electrohome marquee 9500LC in a sweet case so you can contact curt on here if you have issues
Ps YOU SUCK
crt king of black
Machi
Posted: Tue Aug 20, 2013 12:41 am    Post subject:
Now I have another problem that worries me more than the subject of this post.
When I turn on the projector displays the message: [No VSync]
I connected all the wires in the right place and you still receive this message: [VSync Out Of Range] or [HSync Out Of Range]
I tried connecting the composite sync and the same message appears.
I think maybe I should do another post.
 Filesize:  155.99 KB
 Viewed:  11478 Time(s)
 Filesize:  105.27 KB
Machi
Posted: Tue Aug 20, 2013 12:51 am    Post subject: Re: Help to rotate image Vidikron Vision One
Here some pics:
LOL Laughing
Thanks! Thumbs Up
Ps YOU SUCK
Thanks for the welcome. Good luck with your project!
the big E
The composite sync is done on the h sync which is the one closest to the blue plug
Now if swapping around the connectors and if you have a computer try it if that don't work then the vim(video Input module) is bad
crt king of black
the big E
Posted: Tue Aug 20, 2013 12:53 am    Post subject: Re: Help to rotate image Vidikron Vision One
Machi wrote:
Here some pics:
LOL Laughing
Thanks! Thumbs Up
Ps YOU SUCK
crt king of black
Posted: Tue Aug 20, 2013 1:09 am    Post subject:
Hello
For the sync problem we need to know what source device are you connecting
Machi
Posted: Tue Aug 20, 2013 1:41 am    Post subject:
I'm connecting the projector to the Faroudja VP 410 video processor, and in this, a DVD player.
the big E
Posted: Tue Aug 20, 2013 1:44 am    Post subject:
Is the processor on and working?
crt king of black
Machi
Posted: Tue Aug 20, 2013 2:07 am    Post subject:
Yes. In the function "Video". With the DVD player connected to the video input.
Also I connected the the composite sync, in the h sync, but it is the same.
 Filesize:  106.27 KB
 Viewed:  11448 Time(s)
 Filesize:  103 KB
 Viewed:  11449 Time(s)
Posted: Tue Aug 20, 2013 2:24 am    Post subject:
So from the VP are you running the RGBHV connectors to the same ones on the Projector's VIM( Video Input Module) ?
Here is the VP 401 manual I found online
http://www.biggerhammer.net/mediaroom/faroudja/VP401Man.pdf
the big E
Posted: Tue Aug 20, 2013 2:36 am    Post subject:
Try using a VGA to bnc cable and connect a pc to the set and see if it locks onto a signal if not then the vim(video input module) is bad
crt king of black
Machi
Posted: Tue Aug 20, 2013 2:47 am    Post subject:
I have reviewed each cable to its rightful place.
I tried with both cables Hsync and Vsync. and also with the compound attached to Hsync. And the result is almost the same.
Posted: Tue Aug 20, 2013 2:49 am    Post subject:
What is the frame rate for the DVD players output? Is it higher than 24hz? Also how are you connecting the DVD player to the VP? Composite? Component?
Machi
Posted: Tue Aug 20, 2013 3:10 am    Post subject:
I tried to connect the computer through an adapter, VGA to RCA AV, S-Video. (http://www.ebay.com/itm/PC-Laptop-VGA-To-RCA-AV-Video-Composite-S-video-Converter-Adapter-/190888006697?pt=AU_Television_Accessories&hash=item2c71cfd429 ) And the result is the same.
[No VSync] o [No HSync] cuando conecto los cables de sincronización vertical y horizontal.
Tambien [Sync Out Of Range] cuando conecto el cable de sincronización compuesto.
In all cases, the picture looks bad.
It's like the projector does not detect sync cables. Sad
the big E
Posted: Tue Aug 20, 2013 3:13 am    Post subject:
Most likely the vim(video input module) with the rgb plugs is bad and needs replaced contact curt for a replacement as he has a lot of marquee parts and they will work with your set since it is a marquee in disquse
crt king of black
