ESR too low? (Cap replacement for dummies)
mc86
Posted: Mon Jul 22, 2013 1:23 am    Post subject: ESR too low? (Cap replacement for dummies)
Guys -
So I read-up a tiny bit on electrolytic caps and testing thereof. I bought the Atlas ESR+ (model ESR70) as per Jask's recommendation.
Please understand I intend on doing no mods or upgrades -- I only want to ID and replace any bad caps on my 2nd ECP 4500 with identically spec'd caps before I start tinkering with my own blend. While I believe both of my PJs are very-low hour machines and I know it is heat, not time that does them in...it easy enough to go through them in two hours or so.
Anyway, my hope was to the table given in the tester manual, which is basically is a lookup for Capacitance Value, the designed voltage rating, and a corresponding typical or "good" ESR value one might expect. IF less than 2x that ESR, probably OK.
After testing my first dozen or so caps, I have three Qs:
1) Most of the tested caps have ESRs WAY under what the table suggests is typical. Should I be using some more appropriate table OR just be thrilled none of the first dozen caps I've looked at so far are above the typical "good values"? Mac didn't go into ESR value high-low on the awesome cap thread, unfortunately.
2) What if a cap has a "good" (low) ESR AND ALSO reads a capacitance higher than rated? I have a 100uF cap reading 178uF...strange. Seems off-spec and worthy of replacement. Is this an oddball failure mode or 3 sigma quality outlier?
3) Presuming I find a few bad ones (like ones near hot parts of the LVPS, transistors, etc), any recommendation for a brand/type to replace them with / specific supplier?
Any input appreciated!
Thanks!
Matt
Posted: Mon Jul 22, 2013 2:35 am    Post subject:
Have these PJ been shut off for a long time?
If so then Id plug them in and run them a bit before testing the caps.
I know that tested caps sitting on a shelf for a few years read differently after I use them for a few hours then re test them.
Posted: Mon Jul 22, 2013 8:02 am    Post subject:
That is incorrect about time not being an issue, a lot of Nichicon and Rubycon capacitors fail over time even with little or no use.
Testing a capacitor in a circuit can give totally incorrect readings, such as you see with the one measuring almost double it's rating. Removal and restesting will probably show a different story. Same goes for the ESR reading, if there was a number of them in parallel the ESR reading will be inaccurate.
Posted: Mon Jul 22, 2013 2:22 pm    Post subject:
It is more correct than incorrect. Time in itself is not a issue for a capacitor. I'm sure your referring to NEC caps, but this is a failure based on a poor quality cap, and more so probably a bad component at their time of manufacturer. Their issue is seal failure, meaning the seal breaking down over a period of time and the fluid leaking out or drying up. If the seal did not have this issue the caps would probably last a life time. Also, this poor seal quality is NOT a common issue. Somehow, NEC received these caps through what ever supplier they used. Could have even been knockoffs, even though they weren't real common at that time.
Anyways, you can't use NEC projectors as a basis to state that caps fail from time. It it generally incorrect.
Of course the crap they use in more modern electronics is a different story. They have all kinds of problems.
A good quality cap has NO issue with time.
Posted: Mon Jul 22, 2013 8:31 pm    Post subject:
ESR......What's that? Employer sucks rump Laughing
Posted: Tue Jul 23, 2013 12:19 am    Post subject:
Just to clarify here, I dont mean NEC, and although that was something i saw there, i have seen it elsewhere, especially in computer components. Soltek and Leadtek were notorious for it, used or not. I saw alot more there than in NECs.
So while it may be more correct than incorrect, it is not completely correct, poor quality capacitors seem to turn up everywhere.
Posted: Tue Jul 23, 2013 12:25 am    Post subject:
Poor quality, yes. They can have all sorts of problems. Good quality, no, time is not a factor. That was the point. Time.
Posted: Tue Jul 23, 2013 1:00 am    Post subject: Re: ESR too low? (Cap replacement for dummies)
mc86 wrote:
Guys -
Thanks!
Matt
Yeah, I never did continue that thread. There didn't seem to be much interest after a while. Here's the skinny on your questions. Cap value should always be checked on a remove cap. They will rarely ever test right for value in circuit.
ESR in circuit test is a nice way to get an initial idea of the condition of a cap. However, the true ESR is also out of circuit. But, whats nice about ESR is you should only have to pull it out if you get a higher then normal ESR. If it's higher then normal then you can pull it out and recheck to be sure your not pulling resistance for surrounding circuit components. If your testing lower reading then the chart then they are fine. I would not call the chart "normal readings". They would be the highest acceptable readings. And generally, if your ESR is good then the Value should be fine. A cap won't usually change value unless something is going on in there which would almost surely affect ESR. SO. I think I answered your questions but if not just post again and I'll see if I can explain it differently.
the big E
Posted: Tue Jul 23, 2013 4:39 am    Post subject:
I can vouch for you on the computer end of bad caps
I had a hp pc act up due to this(even though it was new)only to have the mother board die weeks later(yes I sent it to hp yet they didn't fix it so I no longer buy machines from them nor refer them to anybody)
crt king of black
mc86
Posted: Tue Jul 23, 2013 4:47 am    Post subject:
Thanks Mac! If I've got it straight, the attached flowchart PDF and text at bottom should be helpful to folks like me. Three related Qs, tho', if I may.
Q1: Is it rare for a resistor to be in parallel with a cap, thereby making the cap's reported in-circuit ESR value read lower than its true ESR value? (I hope I've got kirchkoff's law right on this.) Your implicit acceptance that surrounding circuits will raise measured ESR and not lower the measured ESR makes me wonder if such a layout is just not done/makes no sense.
Q2: Out of curiosity, I'm guessing the lowest ESR available is not always best...there must be tradeoffs with other characteristics. Can any guideline apply when selecting a replacement cap (once capacitance, voltage, and temp are checked) that balances a "low" ESR with the other performance specifications (ripple current, leak voltage, etc)? Seems unlikely, but hard to know sometimes when I am wrong.
Q3: Suggested brand(s) that are of quality?
The procedure should be as follows:
1) Check ESR while in-circuit. Don't trust in-circuit capacitance value reading.
+ If ESR is sufficiently low (lower than the supplied chart, interpreting esr value to be max allowable), cap is probably OK.
+ If ESR is too high, remove cap and proceed to step 2.
2) Re-check ESR value out-of-circuit to confirm high reading (ESR in-circuit value may have been erroneous)
+ If ESR is above nominal chart value, replace cap.
+ If ESR is below nominal chart value, it is generally useable. Proceed to step 3. A lower ESR value may/may not have been originally spec'd.
3) Measure capacitance out-of-circuit
+ If capacitance is within tolerance range, cap is OK.
+ If capacitance is outside of tolerance range, replace cap.
Thanks all,
matt
capacitor flowchart.pdf
A little flowchart I made based on mac's (and others) comments
 Filename:  capacitor flowchart.pdf
 Filesize:  41.41 KB
 Downloaded:  297 Time(s)
Posted: Tue Jul 23, 2013 4:25 pm    Post subject:
Alright, I guess your going to make me explain this in more detail. Laughing You can probably copy and paste this into that cap thread that wasn't continued, LOL.
First to your Q1. It's is by no means rare to have a parallel resistor with a cap, however this generally will not affect ESR. ESR means Equivalent series resistance. Some call it "effective series resistance" which would possibly be more accurate. Anyways, if you break down these words you have "Equivalent" or equal to, then "series" which means wired as in series, and resistance which means resistance. Now a cap cannot be tested for resistance with a regular ohm meter because there is no actual internal through connection. Yet the fluid will allow flow. So with your ESR meter your not testing true resistance. Your ESR meter actually sends a frequency through the cap and monitors it as it comes out the other side. It then calculates the variation in the signal and determines how much effort was introduced in the process. This induced effort is your ESR resistance reading. This induced resistance would be like: If you have a perfect cap with zero induced resistance and then wired in series a 5 ohm resistor and then tested across both the cap and resistor at the same time with your ESR meter you would get an ESR of 5 ohm. So a cap, by itself that has an ESR of 5 ohm is "like or equal to or equivalent to" a good cap with a 5 ohm "resistor" wired in "series". GOT IT !!!! LOL.
So what causes a higher then acceptable ESR. Well you have the contact points in the cap where the legs attach to the plates and you have the fluid which allows good flow. If a contact point becomes weak it can create some resistance and/or a "LOSS" of fluid can cause a lesser ability for the signal to transfer. So most of the time, when your getting a higher then acceptable ESR it's probably that the cap has lost some fluid either by leakage or evaporation. Plate issues are also a possibility.
Now As to your resistor in parallel effecting ESR, not likely since your testing with a frequency through the cap. It's not the same as testing with an ohm meter where a parallel resistor will affect a reading. I suggested rechecking after removal because there are external things that could affect your reading. If you test at the caps solder points and there is a poor solder joint it can give you a false ESR reading, where your reading is actually showing the poor solder connection resistance and not the caps actual ESR. Also, your test leeds if they don't have good contact with the caps legs could show a poor ESR reading and after removal you would usually end up testing on a clean area of the leg. The surrounding circuit won't "generally" affect ESR reading but there can always be a exception to the rule.
As to Q2: although low ESR is strived for, there are some circuits where this could have a negative affect. But that's a whole other conversation. Some are only happy using a low ESR cap but I believe that's more of an opinion thing. I never insist on a super low ESR cap but mostly because I don't think it's needed at the extra expense.
As to Q3: Many people have their cap brands of choice but 1 thing I always insist on is to buy them from a reputable supplier, 1 that you would hope are very particular as to who they get their stock from so as to avoid getting knock offs. I would never buy caps off Ebay. And don't forget to test that new cap before install, lol.
Nice chart by the way.
Very Happy
Are you guys happy now? Laughing
Posted: Tue Jul 23, 2013 7:17 pm    Post subject:
One thing I want to add: the need of the formation of the capacitor. Either the cap is old but wasn't used for a long time or it is new, newer used, the capacitor should be formatted before any measurement. This is important because the electrolyte builds up an oxidation layer on the aluminium foil if voltage applied on it, this oxidation layer is crucial for proper working, so an unformatted capacitor may seem to have low capacitance and high ESR value, though after formation it is ok.
The formation consist of a few charge/discharge cycles on about the 1/10 of the maximal ripple current rating of the actual capacitor.
Posted: Tue Jul 23, 2013 9:16 pm    Post subject:
Macgyver, what effect on the reading will multiple capacitors in parallel have?
Posted: Tue Jul 23, 2013 9:20 pm    Post subject:
lower ESR, biger capacitance, if the traces are fine.
Posted: Wed Jul 24, 2013 2:28 am    Post subject:
Inaccurate reading.
Posted: Wed Jul 24, 2013 9:15 pm    Post subject:
I no longer try to test caps in circuit. The only in circuit test they get from me is the eye-ball check. However, if I recall correctly, when I was testing a row of parallel caps on a mother board, I was reading the ESR of the worst cap in the row no matter where I was checking. If I suspect them, I pull them. Rarely do I ever put the old one back in service though unless I don't have a replacement handy. I always test the ones I pull for confirmation AND always test the replacements before they go in.
Here'a a little trick if you have a PC or something that won't power up because of high ESR caps. Grab a hair dryer and heat up the suspected caps. This will lower the ESR enough for the device to start up. If you want to see first hand what heat will do to a failed cap, hook up a high ESR cap to your meter and heat it up while you watch the meter. The ESR will drop like a rock.
Failing caps MUST cause increased power consumption Laughing Here's me slapping my knee Thumbs Up
Posted: Wed Jul 24, 2013 11:37 pm    Post subject:
Ive done it all before Wink
mc86
Posted: Fri Jul 26, 2013 6:47 pm    Post subject:
Thanks for all the great replies. A few more Qs while I'm gearing up for this:
1) Nashou also mentioned the Gjaky's "formation" process (he suggested powering the unit if it'd been off a long time). Anyway, is there a "good" (ie, easy-enough) way to do this? That is, I have a gigantic variable DC power supply that can deliver up to 120VDC at several amps (for a huge magnet). Can I apply +/- leads to the cap and just slowly bring the cap up to the rated voltage, then turn voltage down, and then discharge the cap? The discharge would be via resistor to ground or with the ESR meter if the cap is "small".
2) Can you folks expand on the "pulling out the caps" as recommended in this thread? I gather the technique should be like in this youtube video, right?
3) Do you guys recommend a desoldering iron (presumably with built-in manual vacuum) OR should I just not worry about sucking up any melting solder/use wick/etc? I am a bit persnickety about things being done nicely if a little extra effort is involved. I have access to a hakko fx-888 solder station if I need it, but I planned to use a butane powered solder pencil at work. I can get really fine tips for that.
Thanks again,
Matt
Posted: Fri Jul 26, 2013 7:20 pm    Post subject:
For desoldering I tried everything and the best is to just use soldering wick. I dip it in flux then slop it on the solder I want to remove. then just clean the board with de natured alcohol when done.
Drags has a brand of wick he likes but for convenience I just use radio shack stuff.
Posted: Sat Jul 27, 2013 12:09 am    Post subject:
The rat shack stuff is pre-fluxed. You should be able to use it right off the roll. I do with no problems.
