Marcel_D
| Posted: Sat Aug 24, 2013 6:16 am Post subject: |
Ah, excellent. So when the service manual says to start by "Turn VR5004 fully counter clockwise, set all other VRs to center" it's just messin with me? That's how the DEF board service part starts.
| Posted: Sat Aug 24, 2013 6:21 am Post subject: |
Wait a minute, try it turning back where it was, 'H out' pot is meant for the H-output protection, so it can give false alarm in end position, but it isn't really hard to test if the 2SC4288 is bad, just for sure.
Marcel_D
| Posted: Sat Aug 24, 2013 6:24 am Post subject: |
I tried. I found the adjustment procedure for it too. Says to try and get 2.0V between TP 6 and 7. It's stuck at like 3.4V regardless of the pot's position. Pot is still good, I checked.
Probably the transistor.
Edit:
Yeah it's the transistor.
Marcel_D
| Posted: Sat Aug 24, 2013 6:51 am Post subject: |
Gotchya. Any idea why it blew like that? Did I follow the service manual incorrectly?
| Posted: Sat Aug 24, 2013 12:29 pm Post subject: |
Why the F*** are you touching the H-OUT pot in the first place!!! There are two pots for raster size, neither one says H-OUT....
Marcel_D
| Posted: Sat Aug 24, 2013 7:04 pm Post subject: |
Because this:
I wanted to go through the whole board and tweak the adjustments.
| Posted: Sat Aug 24, 2013 11:21 pm Post subject: |
If it was working before i wouldnt have touched that.
Tinman
Joined: 09 Mar 2006 Posts: 1326 Location: Carson City Nevada
| Posted: Sun Aug 25, 2013 3:57 am Post subject: |
| gjaky wrote: | | Replace it only with the same toshiba type. |
I'll second that!! BEWARE of counterfeit transistors, and it MUST be an "A", nothing else.
If you buy the transistor on ebay and it keeps blowing up, it's a chinese fake. Beware, there are a LOT of them out there.
Even from reputable sources.
_________________ This space for rent.
