NEC 9PG+ Corrupt Menus and no Video
Posted: Thu Jul 18, 2013 8:49 pm    Post subject:
I think it all depends on tube condition. If your pj have great tubes, then jump in and do it, the outcome will well worth the effort, I think the job isn't that bad. I've done this with my boss' PG plain last winter and took about three afternoon (after work) to finish.
Marcel_D
Posted: Thu Jul 18, 2013 9:00 pm    Post subject:
I'll the pull the lenses, take some pics and let you guys decide.
Tinman
Posted: Thu Jul 18, 2013 9:48 pm    Post subject:
Recapping a PG isn't really that bad, just takes time. Do one board at a time and test. Is it worth it? I'd say on a PG10, yes. On a 9.... maybe with mint tubes. But I personally wouldn't, and didn't.
This space for rent.
Posted: Fri Jul 19, 2013 12:12 am    Post subject:
Depends on the intended use, if you do abit of 15.7kHz use, the machine is perfect for it.
Marcel_D
Posted: Fri Jul 19, 2013 1:47 am    Post subject:
Red and blue are mint, green not so much.
Red
Green
Blue
Posted: Fri Jul 19, 2013 2:07 am    Post subject:
Not too bad, but uneven on the green, and probably too small a raster size used. Still usable for some things, use the top portion above the static wear and do a 2.35:1 screen.
Marcel_D
Posted: Fri Jul 19, 2013 2:17 am    Post subject:
I haven't even put that many hours on the set since buying it. That green wear is about the same from when I bought it. And yeah you could tell it wasn't set up very well.
Posted: Fri Jul 19, 2013 2:37 am    Post subject:
How did it look on screen with that wear? Wouldve been abit of a pink haze there?
Marcel_D
Posted: Fri Jul 19, 2013 2:47 am    Post subject:
It is noticeable at times.
I'd fix it if you've been living with that bit of text wear on the green. That's a lightly worn tube, all things considered.
the big E
Posted: Fri Jul 19, 2013 3:22 am    Post subject:
Marcel_D wrote:
Thanks for the info Curt. I realize it's a pretty big job and I've debating whether or not it for a while now. I also do have an ESR meter which should speed things up if I choose to.
Like, the PG 9 is an alright set, nothing top tier. If I had paid $3k+ for it I'd be a lot more willing to just jump into this. At the moment I'm not sure.
So my options:
-Put a fair bit of money and time into an average projector (the 9PG)
-Buy a more recent, higher end CRT projector and be nmore willing to invest in it when things go wrong
-Go digital
Maybe I'll just start measuring and making a list of caps. Price it out on Digikey and see if it's worth it.
Get that last choice out of the list as you can put the money into the set you have (if it has low hour tubes) or another crt projector
crt king of black
Posted: Fri Jul 19, 2013 3:28 am    Post subject:
Sorry, thought this was the XG thread. Too much on the mind. Recap first. I do have a near minty set of PG tubes on eBay if you want a mint green. $50 for the set, $40 for just the green since it's sought after the most.
Make sure the set works before buying tubes...
Posted: Fri Jul 19, 2013 6:27 am    Post subject:
F*** thats cheap, id take them if i didnt have a perfect set in mine!!
If you went a 16:9 screen, but made sure to more the image up abit for 2.35:1 movies, you could avoid that wear at the bottom and with HD-145 lenses the focus should still be tight enough.
Marcel_D
Posted: Fri Jul 19, 2013 7:19 am    Post subject:
Yeah I'd be all over those tubes if I knew this was going to work after recapping.
Speaking of which, I've found about 40ish bad caps on the DEF board. And a few leakers. The leaky ones seem to be the nichicons, especially the 16V 47uF ones. I might pull the larger ones to see if there's something going on underneath them.
I pulled a large value nichicon and one of its legs had goo on it. I'm replacing all the nichicons regardless of ESR reading now.
Edit:
Oh also, the two red LEDs on the DEF board. Are they supposed to light up? Because they flash on for a second then turn off when the projector is running. I forget what they did before.
Posted: Fri Jul 19, 2013 8:31 am    Post subject:
The two LEDs are failure indicators on the DEF board, they might flash during startup or scan switching, but otherwise they should be off.
If you have the service manual you should check/readjust the test points on the DEF board, that should help with keeping good lock on every resolution you throw at it.
Posted: Fri Jul 19, 2013 9:19 am    Post subject:
Yes they only come on with a deflection failure. Do those caps and if it works, grab those tubes Wink
Marcel_D
Posted: Fri Jul 19, 2013 9:28 am    Post subject:
Caps are ordered, should be here tuesday.
Posted: Fri Jul 19, 2013 10:27 am    Post subject:
Brilliant Wink
Marcel_D
Posted: Wed Jul 24, 2013 9:16 am    Post subject:
http://i.imgur.com/5qD8JW0.jpg
Here's a pictured of it recapped. The ones marked with green I didn't touch. I replaced all the nichicons as they seemed to be leaky. The upside down cap in the back with the wires is the first one I removed earlier in the thread...I managed to take a solder pad when I removed it. Lesson learned. I'll put it in the projector tomorrow.
Posted: Wed Jul 24, 2013 9:48 am    Post subject:
No idea why its up that way. But yes, this is why it is commonly suggested by Curt and Macgyver here to pull or cut caps off and solder to the legs, being that they are both foremost experts, i would never see a need to question their judgement.
Page 2 of 5
