Whining NEC PG xtra power supply
Posted: Mon Jun 17, 2013 11:27 am    Post subject: Whining NEC PG xtra power supply
Yesterday, and the day before yesterday my NEC's power supply gave some whining sound during the warm up, friday it went without problem. When I turned on it just started as it should (no problem) then after a minute of operation the power supply started screaming, but does not affected the picture (yesterday it wasn't dependent on projected image, but the day before that, the whining came mostly when all three tubes were on) after 2 munites or so of whining it faded away and watched the movie without any problem. The main purpose of this post is not to seek advices for this, as probably I would get "recap the power supply" and similar posts, and actually this is what I'll do, just curious if anyone ever had a similar problem with a NEC?
Posted: Mon Jun 17, 2013 12:01 pm    Post subject:
Never.
Posted: Mon Jun 17, 2013 12:02 pm    Post subject:
Never.
Posted: Mon Jun 17, 2013 12:03 pm    Post subject:
Never.
Posted: Mon Jun 17, 2013 12:04 pm    Post subject:
Wow... 3 times!!
Zolzar
Posted: Mon Jun 17, 2013 1:20 pm    Post subject:
I have that problem on occasion. Was much worse before I recapped. After warm up though it does go away.
the big E
Posted: Mon Jun 17, 2013 11:53 pm    Post subject:
Guys I mentioned this in another thread and was surprised nobody even thought to recap the power supply when recapping the rest of the boards in the set when they did the boards and it sounds like this is bad caps pull the power supply and take it apart and see if it has leaking caps if yes then it needs recapping
crt king of black
Posted: Tue Jun 18, 2013 12:19 am    Post subject:
Who says i didnt? Wink
Posted: Tue Jun 18, 2013 12:20 am    Post subject:
Tinman
Posted: Tue Jun 18, 2013 12:33 am    Post subject:
Oh yes.... I had to change quite a few caps in my pg10. Mostly the smaller one's, they were LEAKING already. Not always visible until I un-soldered them. Failing caps make a switching PS scream. Before it fails.
The really big caps tend to fare better, but eventually they too will need replacing. Note, you must use low ESR caps in a switcher.
As the caps heat up, they regain some of their capacitance, which is why it gets better. But it's just the calm before the PS will die. Better get to it now. Easier to swap caps than IC's. BTW, you can usually smell them if you put your nose at the front vents when you first turn on the projector. Bad caps have a unique fishy smell to them.
We used to give old gear the sniff test first. If it stank, re-cap.
This space for rent.
the big E
Posted: Tue Jun 18, 2013 12:49 am    Post subject:
I got that smell from the video board section before my video and convergence grids went black so I guess the caps on the board went(kinda surprised they lasted two days Very Happy if I can get someone to refurb the board without wording about them messing with the knobs on the board I will be happy as the rest of the caps have been replaced but I think one on the deflection board is a defective one as it still whines when I have the video input in use(and the lettering shakes on all three tubes)
crt king of black
the big E
So far my necs power supply hasn't started screaming yet but I do plan on recapping it before it starts doing that Very Happy as I wouldn't want the set to need more repair(or worse be unrepairable because of it)
crt king of black
Posted: Tue Jun 18, 2013 6:38 am    Post subject:
It is pretty normal that you hear the deflection board working when video input selected, because the line frequency is ~15kHz is in the audible range, though recapping the deflection board is a good idea also.
the big E
Posted: Tue Jun 18, 2013 6:44 am    Post subject:
Thanks for easing my worry I thought I had a defective cap(it was one of the boards he did recap when he did the set) never heard that noise from my Ecp using the composite input and wondered if he had got a bad (defective) cap for a replacement so the one thing I need to do now is figure out if my gain board is bad or needs recapping(he didn't do those boards no clue why)
crt king of black
Posted: Tue Jun 18, 2013 6:48 am    Post subject:
You should hear an XG when it switches sources, youd think it was pulling in a group of contactors.
the big E
Posted: Tue Jun 18, 2013 6:56 am    Post subject:
My nec 10pg has queiter relays the my ecp4101(you can hear it from across the room literally when I power it up(rapid fire like clicks) the nec just emits a slight click at power up)
crt king of black
Posted: Tue Jun 18, 2013 6:58 am    Post subject:
Slap it! Laughing
the big E
Posted: Tue Jun 18, 2013 7:00 am    Post subject:
Slap it! Laughing
Funny Razz Laughing Laughing
crt king of black
Tinman
Posted: Wed Jun 19, 2013 12:04 am    Post subject:
Yes, the deflection board makes all sorts of squealing noises as it changes scan frequencies, that's normal. As long as you do NOT replace the 2 big 33uf capacitors (biggest on the board) you'll be fine. The 33uf caps are a special type, you won't find a replacement today that will hold up and not explode. They are High current, high ripple rated to couple the deflection yokes. That's also why they are so big for their value, to dissipate heat.
the big E
Posted: Wed Jun 19, 2013 12:24 am    Post subject:
those he didn't replace so have you ever seen them fail?
I am getting some spare boards from curt so if one fails I can swap it out till I can repair the failed board
crt king of black
