VDC Marquee 9502LC Ultra???
Morettii
Posted: Mon Jun 10, 2013 6:28 pm    Post subject: VDC Marquee 9502LC Ultra???
Could someone explain me the differences between a VDC Marquee 9500LC Ultra and a VDC Marquee 9502LC Ultra?
I bought this Marquee a month ago and I have no idea what kind of model this is. Sad
Posted: Mon Jun 10, 2013 6:37 pm    Post subject:
So you have both machines, why don't you find out by yourself? compare the menus, the version numbers, boards etc.; 1 ending usually meant that it came with ACON, don't know about ..2, but I don't think it would be any serious differnce between them
digitalayon
Posted: Mon Jun 10, 2013 7:04 pm    Post subject:
send it to me and I'll tell you what is "WAS"!!
Posted: Mon Jun 10, 2013 7:07 pm    Post subject:
PICTURES..!! Wink
Details..!!. Lenses? Tubes?
Posted: Mon Jun 10, 2013 11:13 pm    Post subject:
Hmmm
I am not finding 9502 anywhere on the VDC price sheets, but Ehome used to number some of their Euro export gear differently.
Posted: Mon Jun 10, 2013 11:15 pm    Post subject:
Mine was an 8502. Might be the 9 inch version of the LongBow.
nashou
Posted: Tue Jun 11, 2013 3:02 am    Post subject:
Guys
I think VDC used to make a lot of one offs. This might be one of them. I remember that one pj that Scott designed that had some serious geometry control.
ElTopo
Posted: Fri Jun 14, 2013 3:10 pm    Post subject:
This version has a P43 green inside for simulation/3D.
Barco Cine 9 the one and only
Posted: Fri Jun 14, 2013 3:51 pm    Post subject:
Ohh thats terrible.. Thumbs Down I got one of those.. Had to get a new green tube.
Posted: Fri Jun 14, 2013 5:43 pm    Post subject:
Guys
The P43 machines usually had -ST in the chassis version, as in 38P15295-ST or similar.
Posted: Mon Jun 17, 2013 8:46 am    Post subject:
just looked, mine is a 9553 Ultra.. So what kind of animal is that lol..
Morettii
Posted: Tue Jun 18, 2013 7:34 pm    Post subject:
I found -ST in my serial number, so does that mean that the pj has got the P43 Tube for 3D?[/img]
 Filesize:  49.2 KB
 Viewed:  9146 Time(s)
Posted: Tue Jun 18, 2013 7:38 pm    Post subject:
Probably
It would have shipped out of VDC with P43. You can take the top plastic cover off of the green tube and look for a label.
P43 is a bit more pastel than standard green, it will tend to flicker at lower vertical rates and it will output less light.
Morettii
Posted: Tue Jun 18, 2013 7:43 pm    Post subject:
Tim in Phoenix wrote:
Probably
Damn, that sounds not so good for me Sad
Posted: Tue Jun 18, 2013 7:58 pm    Post subject:
Well it wouldn't be a p43 as that is an 8 inch tube your would more likely be a P-22 of some sort.
Posted: Tue Jun 18, 2013 8:01 pm    Post subject:
But this is a 9500LC ultra, why would it have a 8" tube?
Posted: Tue Jun 18, 2013 8:56 pm    Post subject:
Guys
P43 is a Phosphor, PT22 is a tube version. Both eight and nine inch tubes can be P43 green.
Standard green is slower decay, that makes it seem brighter by duty cycle but standard green is too slow for 3D vertical rates, typically 96hz, where the left eye/right eye refresh will ghost unless P43 green is specified. Red and blue are deemed fast enough for 3D, so P43 is only found in green tubes.
Posted: Tue Jun 18, 2013 9:45 pm    Post subject:
Well Kurt said his P22 was the fast persistent Phosphor, I assumed it meant that all Green P22's were. My Bad, I should have know that as well since i know p43 is that phosphor type. I have the break down sheet for all CRT Phosphor types somewhere.
Posted: Tue Jun 18, 2013 9:58 pm    Post subject:
I just know that i dont like PT22 tube, and if i buy another marquee it have to be damn cheep if its with a PT22 tube, or it will just be for parts.
A new tube cost more than a mint low hour 9500LC ULTRA.
Posted: Tue Jun 18, 2013 10:02 pm    Post subject:
Guys
I believe PT22 can come with P43 phosphor, confusing huh? There is a green LUG43 tube, but LUGs I am told were never offered with P43 phosphor.
