the big E
| Posted: Thu Jun 06, 2013 10:45 pm Post subject: Sony 07ms tubes |
Anybody got any for a elctrohome Ecp I want a minty set(if posible)as my set has a mix and match of 07ms and sd187 and I want to get a spare set(curt don't have none as I know of)
mc86
| Posted: Fri Jun 07, 2013 12:50 pm Post subject: |
Big E -
There are very little 7" tubes...and fortunately almost ZERO demand! That said, I think I may have you scooped on this front -- I've been trying to buy tubes for mine over last year and half. At this point, you'd be better off buying the remaining 9" tubes that are available and waiting another year for a nearly-free 9" chassis to fall in your lap that only needs new tubes.
In particular, I got a set of mint 07MS tubes from Dragan and a very, very good 4:3 wear-in set from CJ. LOTREE has a 4500 sitting in a closet in newfoundland with what I think should be very good tubes, but last I asked he couldn't be bothered to pull the tubes for the cost of shipping and a case of beer.
Next week I'm going to see Mr. Blonde (on here occasionally/rarely nowadays) to remove a set of tubes from an old/extra ECP he has. If those tubes are good, I would let go a set minty-looking set of the SD187s. They might have fungus and sat under my carport for the last year, tho'.
Note that the 07MS tubes from a Sony D50 are the same, but won't fit in your ECP. I'm hoping curt will give me a bad D50 tube with some stuff I'm ordering. I think I have found a chemical that will de-bond the metal-to-glass bondment...this might free up a few tubes, not sure.
cheers,
Matt
mc86
| Posted: Fri Jun 07, 2013 1:43 pm Post subject: |
FYI, looking at that red tube in the link above, it has high hours on it. How do I know? The level of the glycol. Those tubes don't have glycol evaporation issues (not that it can evaporate), but EVERY, and I mean EVERY tube that has a low glycol level had high hours on it, and the focus was compromised.
the big E
| Posted: Fri Jun 07, 2013 2:13 pm Post subject: |
| mc86 wrote: | Big E -
cheers,
Matt | curt has a red and green but they would need to be defungused(not that I mind doing that) I thought I would see about a spare set to have for the set also but last time I looked eBay for them they was close to 2grand for them(not sure if I would drop that kinda money on them or not only to possiblely have the set die on me not long after
I would like to keep the beast going as long as I can though since I have the service manual for it I may drop the cash for the set of tubes on eBay sometime as I can repair the chassis if anything fails
RaWsHaRk
| Posted: Fri Jun 07, 2013 8:05 pm Post subject: |
I dont think you have to worry about tubes, worry more about infamous sure-to-break parts of ecp like the power unit, finding those will be harder than finding new good tubes. I could probably pick a bunch of minty 07ms tubes here in europe from the crt´s that arent worth anything anymore but sending some over there would be ridiculous..
I have 4 sets of clean tubes for my 801s but I dont think I will get to install even the 1st spare one, other parts will fail much sooner or I will just pick a higher end projector for peanuts..
_________________ Electrohome Marquee 7500.
the big E
| Posted: Fri Jun 07, 2013 8:16 pm Post subject: |
| RaWsHaRk wrote: | I dont think you have to worry about tubes, worry more about infamous sure-to-break parts of ecp like the power unit, finding those will be harder than finding new good tubes. I could probably pick a bunch of minty 07ms tubes here in europe from the crt´s that arent worth anything anymore but sending some over there would be ridiculous..
I have 4 sets of clean tubes for my 801s but I dont think I will get to install even the 1st spare one, other parts will fail much sooner or I will just pick a higher end projector for peanuts.. |
If i could keep my younger cousins from leaving something on the screen and leaving it(without telling me) I wouldn't be tring to get a second set but I am getting a nec10pg soon so if the power supply craps out in my Ecp at least I won't be without my big screen(also have a crt projection tv just in case)its just teaching them not to leave stuff on the screen(they ruined my older cousins plasma tv that way because of burn in
Curt has a couple 07ms tubes(red and green) so I would just need a sd187 blue then I would have two sets of tubes(i know the sd187 tubes aren't as bright but it don't matter as long as I have a spare set(just need one set)
mc86
| Posted: Fri Jun 07, 2013 10:08 pm Post subject: |
Tell you what:
If I don't end-up doing the blend (this year), I'll give the SD187 blue to you for free since that backup wouldn't be needed. I only run the machine 500 hrs/year, so it will be 5 years before I even crack 3000hrs. Around then:
1) Other things *will* have failed as Rawshark says OR
2) Crabb/Kal will be upgrading to 4K and I'll buy one of their current machines!!!
Actually, you know what...IF I am able to get this other machine next week AND it has good tubes, you can have the blue SD187 right away! I need to pay-forward the kindness others on here have shown me, right?
Cheers,
Matt
the big E
| Posted: Fri Jun 07, 2013 10:20 pm Post subject: |
| mc86 wrote: | Tell you what:
Cheers,
Matt |
Thanks Matt that would be great
I only have the set plugged in when I am using it anyway so I doubt I will have to worry about the power supply giving issues or getting damaged from power surges
But I think I will use the 07ms tubes now then when it comes time to put the sd187 tubes in I will use the projector in a different setup with a smaller screen so I won't be driving the tubes hard(maybe in a old projection tv body since I have one that I gutted(not sure yet as I still have to get the 07ms tubes from curt)
I have thought of doing a blend setup myself sometime later on(just have to save up the money to do it)
| Posted: Sat Jun 08, 2013 4:36 am Post subject: |
Since when did a D50 have 07MS tubes??
Last i heard they are P14!!
the big E
| Posted: Sat Jun 08, 2013 4:45 am Post subject: |
| CasetheCorvetteman wrote: | Since when did a D50 have 07MS tubes??
Last i heard they are P14!!  |
Your right I just looked at the specs of the d50(it uses the p14 tubes not 07ms or sd187)
| Posted: Sat Jun 08, 2013 8:21 am Post subject: |
Yeah mate, the VPH 20H i think it was called was the last Sony to use those, and was essentially the same as a 1044 with component video and the remote receiver built into the unit instead of plugging in like it does on the 1044 and 1001 ( which are the same apart from the 1001 not having the RGB input, all the boards are the same, the 1001 has not got the components installed for the RGB input and the chip has it removed from the menus ) it still had the same analog master convergence with digital single point user convergence like the 1044 and 1001.
mc86
| Posted: Sat Jun 08, 2013 2:35 pm Post subject: |
The 07MTS came right after the 07MS (I think) and were used in the late model ECP4500s. Here is a link to a thread where Curt discussed this all a little (as well as softness issues). I actually bought the machine mentioned in that thread. Anyway, below is a picture of the tube in question and it shows that the 07MTS (late 07MS) tubes ARE P14 tubes.
Curt points out that getting the D50 tubes into a ECP can't be done b/c the metal housing bonded to the tube faces are different. Removing the metal rings are what I want to try to do chemically. Curt tried mechanically and came to the conclusion it was a futile effort.
cheers,
Matt
| Description: |
| Picture showing a P14 tube installed in an ECP - I believe at the factory. It is an 07MTS which was a late improvement to the 07MS and uses same form factor and pins. Perhaps a different phosphor mix or electrode material, etc. |
| Filesize: |
76.95 KB |
| Viewed: |
9643 Time(s) |
the big E
| Posted: Sat Jun 08, 2013 9:53 pm Post subject: |
| mc86 wrote: | The 07MTS came right after the 07MS (I think) and were used in the late model ECP4500s. Here is a link to a thread where Curt discussed this all a little (as well as softness issues). I actually bought the machine mentioned in that thread. Anyway, below is a picture of the tube in question and it shows that the 07MTS (late 07MS) tubes ARE P14 tubes.
cheers,
Matt |
I thought certain ecps was listed with that tube I wonder if it would work in mine(I would love the extra lumens)
| Posted: Sun Jun 09, 2013 1:26 am Post subject: |
The last of the little 15.7kHz Sony sets was 1998 and still have 07MS tubes though, so i wonder just how compatible they are.
the big E
| Posted: Sun Jun 09, 2013 1:28 am Post subject: |
| CasetheCorvetteman wrote: | | The last of the little 15.7kHz Sony sets was 1998 and still have 07MS tubes though, so i wonder just how compatible they are. |
Given that the scan rate is not dependent on the tube they may work(could be wrong)
| Posted: Mon Jun 10, 2013 2:05 am Post subject: |
Scan rate got nothing much to do with it
the big E
| Posted: Mon Jun 10, 2013 2:24 am Post subject: |
| CasetheCorvetteman wrote: | Scan rate got nothing much to do with it  |
I thought scan was only in the hardware and not the tubes
I am getting some 07ms and sd187 red and green tubes from curt I have a 07ms blue tube in my set
So I will have a set of 07ms
A partial set of sd187 tubes as I have a red and green and I am getting a extra red and green just need some blue tubes to go with them(given how much I have been using the set it may or may not take me long too go through the tubes(not sure YET )
But I do plan on making this Ecp last as long as I can because I am going to see into doing a blend setup(not sure on the projectors I will use yet but they will be crt for sure)
| Posted: Mon Jun 10, 2013 4:34 am Post subject: |
Yep, its all in the hardware.
I wouldn't worry too much about wearing 07MS tubes, in my experience they seem to last a very long time. Although my experience is with the two Sony 1001QMs I have here, I got some almost new zero wear tubes from Curt about 4 years ago and those are still showing no visible wear, probably put about 1000 hours on them, but in this case the rasters were almost filling the whole tube face with about 2 or 3mm at the closest point, which on the 1001 seemed to cause no issues at all. I also had the tubes almost perpendicular to the screen, so the rasters were all very close to zero keystone.
The original 07MS tubes in the first 1001QM I have here have done a hell of a lot of hours, although they are badly worn and VERY soft, then ran an average of 16 hrs a day, 7 days a week from 1996 til 2005 when the convergence board in the set failed and it was removed from service. ( replaced with a digital that lasted a whole 2,000 hrs )
Ill post a pic of them after their 9 years of dedicated service...
| Posted: Mon Jun 10, 2013 4:39 am Post subject: |
Here they are. The wear doesn't show in these pics near as bad as it really was.
Blue and green:
Blue:
Red:
Green:
P.S. Ive still got them somewhere, and they have never had a fungus problem either
