matt697845
| Posted: Sat May 25, 2013 10:28 pm Post subject: About to get into CRT with 1 or 2 Sony G90. Need advice. |
Hi all,
I have the opportunity to buy 1 or 2 Sony G90. I went to check them out today, but neither myself or the guy selling knows much about them. Both of them do power on, and you can get into the menu and they do not appear to be showing any errors. I consider myself to have decent technical understanding, so I don't think learning the ins and outs of setup and maintenance will be difficult, just a huge learning curve. A couple of questions: How do you get to the part of the menu that shows the number of hours? And also, the picture on one of them appeared to be flickering or "jumping" back and fourth horizontally a couple times a second. This is the one that appeared to have a brighter, crisper image. Have any of you guys heard of this? Is this a fixable minor issue, or cause for major concern?. And finally, I'm aware of the "Dallas chip issue", how difficult, and more importantly, how costly is this replacement? Anyway, thanks in advance for your advice, can't wait to get into CRT More to come...
HaydnG90
| Posted: Sat May 25, 2013 11:19 pm Post subject: |
The jumping image could be indicative of the infamous IC421 chip failure. Do a search here and you'll find a long thread discussing this problem. Is the pj responsive to the brightness and contrast controls? If yes then maybe the clamp setting is wrong, which should not be in AUTO.
To get to the service menu to find the timer press enter, enter, up, down, enter and click yes when prompted. These key strokes are timed so go through the sequence fairly briskly.
| Posted: Sat May 25, 2013 11:28 pm Post subject: |
Are those the ones from Frank?
the big E
| Posted: Sun May 26, 2013 1:52 am Post subject: |
if the dallas chip needs replacing it is a plug and play deal but if the set isn't losing its settings then the chip isn't the cause
the dallas chip is reasonable priced just ask curt for the right one(the wrong chip can cause more problems)
also curt has a lot of info on most projectors have a look around on the site
also you may need a signal before the picture stabilizes (my eco 4101 is like that)
matt697845
| Posted: Tue May 28, 2013 4:29 am Post subject: |
Well I did it . I'm now the proud owner of 2 Sony G90, with HD-10f lenses, #250 & #555, and one ceiling bracket
I was told by the guy who sold them to me that they came out of California, other than that, I know noting of their history. According to searches for "421" in these forums, it does appear that #555 has faulty IC421 issue. Symptoms are shaking on screen menu (haven't got the chance to connect a source yet, due to my current living situation I'm just storing them) the shaking behavior is affected (speeds up) when certain buttons are pressed. Anything I can to to verify if it's indeed the IC421 issue or something else? Approximately how much would Curt or one of you other guys here charge for the YA board? Yes, I know it's gonna be alot. How about the Dallas chip (including copying?) both are fine, but from what I read I'm on borrowed time at this point. Both of them are responsive to brightness/contrast buttons. At the very least, I should be able to combine them into one nicely working unit, but ultimately, when finances and situations allow, Id' like to get them both going in a stack or blend setup.
P.S. How the hell does the remote come out of the compartment? Yeah, I have a lot to learn.
the big E
| Posted: Tue May 28, 2013 4:41 am Post subject: |
| matt697845 wrote: | Well I did it . I'm now the proud owner of 2 Sony G90, with HD-10f lenses, #250 & #555, and one ceiling bracket
P.S. How the hell does the remote come out of the compartment? Yeah, I have a lot to learn.  |
The Dallas chip is pretty cheap(try 30 something bucks) I would see into that only if the set loses the settings(I have a couple spares that curt sent on some spare boards that I haven't had the time to test yet)
Keep in mind the age of the sets also connections on boards may need cleaning(disconnect and reconnect to clean them)try this first before anything but be careful as there is dangerous voltage in the set even if its unplugged best to let it drain before working with the boards or even poking around in the set
Try connecting a source to it and see if it helps the shaking picture(it works for my Ecp and I had to have a signal during setup)
The g90 has video, s video, component video and rgb so inputs shouldn't be a issue
You will love the picture once you get them working(very smooth yet sharp)I had a Sony projection tv before and loved the picture(my Ecp has Sony tubes which I like because of that)
I am in the works of getting a nec10pg(over 1k lumens and 40000:1 contrast insanely bright)with 9inch tubes
Phoenixed
| Posted: Tue May 28, 2013 5:00 am Post subject: |
I would guess a YA board will cost roughly $1k and will prolly come with a new Dallas chip. The remote in the chassis is to remain in the chassis you should have a wireless one with one of the two you got. I would be very cautious not to turn the machine on until someone on here verifies you dont have a bad YA board.
| Posted: Tue May 28, 2013 1:08 pm Post subject: |
Have you ever owned a CRT before? Where are you located?
kal Forum Administrator
the big E
| Posted: Tue May 28, 2013 2:08 pm Post subject: |
| kal wrote: | Tubes are everything. How are the tubes?
For a unit to be worthwhile (IMHO) it shouldn't have any visible wear, or barely any wear. If it has any, it should be large and uniform.
Give this a read (all 4 pages - especially the last page with the tube rating charts):
http://www.curtpalme.com/TubeCondition.shtm
Good luck!
Kal |
I agree kal the tubes condition makes the value of any crt projector
dochlywd
Joined: 25 Apr 2006 Posts: 346 Location: Saint Louis, Missouri
| Posted: Wed May 29, 2013 1:51 am Post subject: |
Congrats on the purchase!
Contact Craig Rounds, CIR ENGINEERING, as he is the only one besides Curt that has the ability to repair the YA board!! He has done it successfully many times......EVEN WITH THE IC421 CHIP!
He is probably THE MOST knowledgeable tech on the G90.
Doc
matt697845
| Posted: Wed May 29, 2013 6:58 am Post subject: |
No, I've never had a CRT PJ before, but I've wanted one ever since I saw what they could do in a planetarium somewhere when I was young. Their motion resolution, zero lag, and the ability to do multiple resolutions and refresh rates is what makes them most desirable to me.
I've actually been passively checking eBay and Craigslist for several years, hoping something would pop up. When one popped up locally, somewhat reasonably priced ($1.5k) I just had to check it out. And when it turned out there were actually TWO of them sitting there I couldn't resist. Turns out someone had already put in an offer for one, but hadn't paid yet, so once I saw they both powered on, I couldn't resist, and offered the guy asking price for both. Now that I know about this place, and that they're still serviceable, I'm pretty confident in my purchase. They'll probably used about 50/50 for special occasion PC gaming and TV/movie watching. They won't be used all the time, I'd like them to last as long as possible.
As for tube condition, I tried peering through the lenses to the tube face, and couldn't see any wear at all except for the green on the higher hour one, #250. According to the chart on this site, it's anywhere from a 6 to 8, although I really can't tell till I find a screwdriver long enough to get the lenses off. I'll try snapping some pics, so you guys can judge.
Just to confirm, the control panel in the top compartment is not removable, even though it has the "IR" infrared symbol? There was a guy selling a remote right here on the forums dated April 30.
Finally, could the flickering issue be verified to be a YA board issue by simply swapping them between the two units, is there any risk in doing this?
the big E
| Posted: Wed May 29, 2013 7:41 am Post subject: |
| matt697845 wrote: | No, I've never had a CRT PJ before, but I've wanted one ever since I saw what they could do in a planetarium somewhere when I was young. Their motion resolution, zero lag, and the ability to do multiple resolutions and refresh rates is what makes them most desirable to me.
Finally, could the flickering issue be verified to be a YA board issue by simply swapping them between the two units, is there any risk in doing this? |
You forgot no motion blur which is common with digital projectors
I was the same way seen one in a movie and wanted one ever since
To check tube wear it is best to remove the lens(four screws) I would email curt on how to gain access to the lens unless a Sony owner posts on how to do it(I am a electrohome/nec owner(soon to be getting a nec 10pg)
I have seen many threads of Sony owners claiming they are hard on tubes(not sure since I don't have one)
HDTV on these beasts is anything short of amazing (that includes blu ray movies)
I don't know if you can or not but with a bright light you might be able to see the tube wear with the lens on(I can to a point)
To get the specs of what they can handle(for HD) check out the projector specs page
And no the control panel at the back of the set is not removable I thought the same thing when I got my ecp(remote looks like the control panel) and almost started to pry it out till I opened the top to see it bolted to the chassis of the projector
Don't leave static images on it long at high brightness and contrast setting as it can cause burn in after so long(so limit game play to short periods)
| Posted: Wed May 29, 2013 2:09 pm Post subject: |
Before you do anything, buy 2 new Dallas chips. They are on the YA board in a socket. Mandatory to do this before you spot burn the tubes. Rare, but possible.
It does really sound like the shaking set has a bad Ya board. Very typical of some of these sets. Send the board to Craig or myself to verify that, but if so, it's toast. Definitely swap the boards to confirm the rest of the chassis is OK.
I REALLY need to do a writeup on the G90 for the site. I'll cover stuff like changing the Dallas chip, as there's a tiny pushbutton switch on the Ya board that needs to be pressed to initialize the new Dallas chip, otherwise the set won't fire up.
Good score! YOU SUCK!
Almost guaranteed that both sets will have some tube wear, but probably not enough to warrant replacement. Use the best of the two sets, and keep/scrap the other one for spare parts.
the big E
| Posted: Wed May 29, 2013 3:58 pm Post subject: |
| Curt Palme wrote: | Before you do anything, buy 2 new Dallas chips. They are on the YA board in a socket. Mandatory to do this before you spot burn the tubes. Rare, but possible.
Almost guaranteed that both sets will have some tube wear, but probably not enough to warrant replacement. Use the best of the two sets, and keep/scrap the other one for spare parts. |
I agree on the Dallas chip
| Posted: Thu May 30, 2013 1:51 am Post subject: |
If you send me your Dallas chips I can copy them and retain the serial number, hour meter, factory setup, and service setup. If you just put a new Dallas chip in and initialize it you will lose all the mentioned info.
I have YA boards in stock now so they are available.
Really tired now after just getting back from a calibration tour. so for now...
Kind regards,
| Posted: Thu May 30, 2013 1:53 am Post subject: |
I also have wireless remotes at the moment...
| Posted: Thu May 30, 2013 3:57 am Post subject: |
Matt,
It sounds like you got a good score.
Since this is your first, you are in for a huge learning curve. You may want to hire a pro like Craig to set them up for you. That is one of the reasons I was curious were you are located. If you are in South Fl and don't want to go with Craig, then there is a calibrator located down here.
matt697845
| Posted: Thu May 30, 2013 5:52 am Post subject: |
I (will be) located somewhere off exit 111 of I-85, which is about 30 miles NE of downtown Atlanta, GA. I had contemplated having them set up by someone who knows what they're doing, but like I said in a previous post, due to my current living situation, they're just in storage (indoors of course). Once I'm moved into my own place, I'll defiantly give it consideration, depending on cost...
How much are the wireless remotes going for? No additional equipment are required, right? the little window on the front is the IR receiver? I find it silly that Sony didn't automatically include a wireless remote for something that sold for $38k in the late '90's. If I remember correctly, some $<100 portable CD players had wireless remotes back then.
@CIR Engineering, what do foresee as for future availability of the YA boards, and what's your price? I'd really like to hold off on that purchase for the time being, unless there about to disappear, or increase in price or something.
I'll get the Dallas chips sent out for copy and replace as soon as I get the time to manhandle them out where I can work on them, swap and verify the YA board issue. One of these weekends.
| Posted: Thu May 30, 2013 1:08 pm Post subject: |
They all did come with wireless remotes! Someone went and lost them, like the other 2 billion remotes that 'mysteriously' went missing. A replacement remote runs $50-100 usually.
