Alaric
Joined: 17 Apr 2006 Posts: 127 Location: Huntingdon, Cambs, UK
| Posted: Mon Feb 19, 2007 3:13 pm Post subject: |
Hi There,
Just for ref Kal, It was (is?) posible to get Colour Filtered (as well as colour corrected) HD8's...A guy on the UK forums had a set, but they were hidiously expensive so are kinda rare.
Cya,
Lee
kal Forum Administrator
Barry
Joined: 01 Feb 2007 Posts: 186 Location: Los Gatos , Ca.
| Posted: Mon Feb 19, 2007 4:31 pm Post subject: |
Thanks guys, never a lack of help and great info here from you all.
As it turns out my other PJ that I have had for 2 years is a Runco 930 (PG6 XTRA) which I love. I wanted to get a higher BW chassis with a better contrast ratio, thus I got the Barco 1208. So I figured I would be joining the ranks of the lens converters. I won't use the lenses off my Runco though, love that machine too much. Of course here is where I will figure my strategy to do this project. Thanks.....
Barry
| Posted: Mon Feb 19, 2007 5:03 pm Post subject: |
Is there any advantage between HD-144 and HD-145 lenses?
_________________ Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
Joust
TV/Projector: Marquee 8501LC
| Posted: Mon Feb 19, 2007 5:28 pm Post subject: |
| Barry wrote: | | Is there any advantage between HD-144 and HD-145 lenses? |
I've heard some conjecture and speculation but nothing firm.
I just got a set of 145s and I'll do some tests and post the results as soon as i can.
busy busy.
Meet at Kals place. Mon
premiere of Ghost Rider with the guys on Tues.
Curling tournament Wed
Wife Maintenance Thurs and Fri
Sat.....play with PJ.
GEBrown
| Posted: Mon Feb 19, 2007 5:57 pm Post subject: |
www.3mprecisionoptics.com
HD145 DESIGN CHARACTERISTICS
f/number - f/1.03 ± 7% at infinity
Focal Length - 135 mm ± 2%
CRT Raster Diagonal - 140 mm (5.5”) maximum (3 x 4)
CRT Phosphor Surface - Flat
CRT Faceplate Thickness - Nominally designed for 16.5mm faceplate
thickness. If thinner faceplates are used, it may be possible to compensate the lens for reduced thickness.
Screen Type - Designed for flat screen
Magnification - Approximately 10X to 60X
Standard Coupling - The lens can be air-coupled to a liquid cooled CRT with the same mounting configurations as our DELTA® TAC4 lens.
Resolution - MTF over 50% at 10 line pairs/mm (approximately 20mHz)
throughout the field
Transmission - Nominal transmission at 550nm is better than 84%
Color Correction - Fully color corrected
Relative Illumination - Approximately 34% at 92% of 5” field
Distortion - Less than 2% (pin cushion)
HD-144
Focal length - 127.33mm
f/no at infinity : 1.125
Raster heigth : 60.11
Optical characteristics (All dimensions from phosphor surface)
Entrance pupil position : 73.9 Diameter 64.22
Exit pupil position : 155.2 Diameter 112.90
Principle points : PP1=128.83 PP2=251.77
This info from the Evil Twin site
_________________ Member of the Marquee Maniacs Club
Spotmatic
Joined: 29 Jun 2006 Posts: 531 Location: Gelderland, Netherlands
| Posted: Mon Feb 19, 2007 6:15 pm Post subject: |
| kal wrote: |
Throw in the fact that the 144/145's are also colour filtered
Not all of them
Barry
| Posted: Mon Feb 19, 2007 6:51 pm Post subject: |
"Not all of them Wink"
So I discovered looking on eBay for them. There is a set for sale that is all clear. In fact this is the only set on eBay right now.
Barry
| Posted: Tue Feb 20, 2007 8:03 pm Post subject: |
Ok, I am lazy, the prospect of pulling three perfectly good CRTs from my newly acquired Barco 1208s to change out the glycol is not that appealing. I plan to replace the lenses and if I color the glycol I can get the untinted versions.
Is it not possible to extract the glycol by using a turkey baster+ and coloring it then replacing it (or using new glycol to do the same thing), while either in place in the PJ or by only extracting the guns with all the electronics on the neck?
This would seem to be easier that the very lengthly process taken by others.
Clarence
| Posted: Tue Apr 14, 2009 4:27 pm Post subject: |
| Barry wrote: | Thanks guys, never a lack of help and great info here from you all.
As it turns out my other PJ that I have had for 2 years is a Runco 930 (PG6 XTRA) which I love. I wanted to get a higher BW chassis with a better contrast ratio, thus I got the Barco 1208. So I figured I would be joining the ranks of the lens converters. I won't use the lenses off my Runco though, love that machine too much. Of course here is where I will figure my strategy to do this project. Thanks.....  |
Barry, is there anything else noteworthy about the Runco 930 vs the standard NEC PG6 Xtra?
I've got a Runco 930 (PG6 XTRA) in my equipment closet with HD-144's. Pretty bad 16:9 wear.
The label on the bottom says "DTV-930" and the label on the inside says "DTV-933".
Are the HD-144 lenses the only thing of value? They are color corrected.
| Mr Postman wrote: | | Is the HD144 lens's better than HD145N (color filtered) lens |
| Gary Murrell wrote: | | Yep what you want are the 144's |
| kal wrote: | regardless of the type of HD8's we're talking about, the 144/145's are considerably sharper.
Throw in the fact that the 144/145's are also colour filtered (the main reason people want them) and it's a no brainer as to which is better.
There's a reason why many HD8 Barco/Marquee owners are replacing their lenses with HD144/145's!
Kal |
Aside from Don Wallace, I don't know of anybody that owns a PG Xtra or needs spares. I don't recall too many PG failure threads... I guess that's a good thing.
Wallace, do you already have a spare everything for your PG Xtra?
If not, walk down and grab this one.
Otherwise I'll just list the lenses F/S.
| Posted: Tue Apr 14, 2009 4:44 pm Post subject: |
Clarence the 933 designation meant it included a line doulbler installed.
Clarence
| Posted: Tue Apr 14, 2009 4:55 pm Post subject: |
| AnalogRocks wrote: | | Clarence the 933 designation meant it included a line doulbler installed. |
OK thanks. I found this "The Runco 933 is the same as the 930, but with an outboard line tripler/video processor." So it seems like it's not an internal card.
Mr Runco charged a $4K premium for the 933 over the 930, so I figured there had to be something...
http://www.curtpalme.com/PJSpecs_Runco.shtm
There's not much use for a tripler these days anyways... hopefully/thankfully not too many people using 480i sources anymore. I don't know if it has the optional point convergence board. Maybe wallace will know what to look for.
Sorry for the OT... we now return to the Barco/HD144 thread.
bbfarmht
Joined: 27 May 2006 Posts: 1273 Location: Where the Mississippi runs east to west!!
| Posted: Tue Apr 14, 2009 5:53 pm Post subject: |
Clarence, I pissed Don off last fall by picking up a Runco 933 for less than 150$. Only had 1500 hours on it. Don bugged me for weeks to give it to him, but I wasn't close to having the Barco up and running. Now the 933 is hanging from the living room ceiling and thats what we watch NCIS on all the time now. (must start whoring myself out to afford satellite)
| Quote: | | OK thanks. I found this "The Runco 933 is the same as the 930, but with an outboard line tripler/video processor." So it seems like it's not an internal card. |
No it was not, I also received the Vp with the projector.
_________________ Adam
Benjamin Franklin
Clarence
| Posted: Tue Apr 14, 2009 7:03 pm Post subject: |
| bbfarmht wrote: | | Clarence, I pissed Don off last fall by picking up a Runco 933 for less than 150$. Only had 1500 hours on it. Don bugged me for weeks to give it to him, but I wasn't close to having the Barco up and running. Now the 933 is hanging from the living room ceiling |
OK, then maybe he'll be glad to see this one and I might even be able to get a few cases of beer and some BBQ in trade for it.
Adam, you already collected all of the LC parts that you needed for your Barco conversion, right? I've still got a G70 that I'm ripping apart, so before I put the c-elements and lenses on F/S, I figured I'd double check to see if you needed them.
bbfarmht
| Posted: Tue Apr 14, 2009 7:15 pm Post subject: |
Yes I would still like them that's the last part I need to finish this project off. I was going to ask you if you were still going to send those with Don.
Benjamin Franklin
Clarence
| Posted: Tue Apr 14, 2009 7:26 pm Post subject: |
Oh, glad I asked. I thought I saw somewhere that you'd finished your Barco mods, so I didn't think you needed them.
I might just send the entire G70 tubes and lenses with Don instead of trying to figure out how to remove the c-elements. Although I haven't looked at it yet... maybe it's easier than I think. It's been several years, but my G90 c-element just lifted straight off.
Maybe I'm confusing the PITA of removing a Marquee's LC bellows.
You just need lenses and c-elements? No G70 mounting plates or anything? I'll get them to Don before he drives to Cliff's. Unfortunately I'll be in San Jose for the next 3 weeks, so I can't attend the meet.
bbfarmht
| Posted: Tue Apr 14, 2009 7:44 pm Post subject: |
It doesn't matter if you send the whole assembly,it might give me a chance to see if I could modify the other 808 chassis to hold them.(like I need another project)
That sux I was hoping you'd be there also.
Benjamin Franklin
| Posted: Wed Apr 15, 2009 12:42 am Post subject: |
| bbfarmht wrote: | Clarence, I pissed Don off last fall by picking up a Runco 933 for less than 150$. Only had 1500 hours on it. Don bugged me for weeks to give it to him, but I wasn't close to having the Barco up and running. Now the 933 is hanging from the living room ceiling and thats what we watch NCIS on all the time now. (must start whoring myself out to afford satellite)
No it was not, I also received the Vp with the projector. |
I sit corrected. I had a runco dealer tell me that back in 1999!
BB what does the processor look like?
bbfarmht
| Posted: Wed Apr 15, 2009 1:59 am Post subject: |
Alright I just spent an hour trying to find a pic on the net. The model # is a VHD 3xf. I will try to take a picture of it tomorrow. I would like to find out more about it but there is not much to find. Seems Runco doesn't keep records on the net of their legacy products. The menu on it is just as veg. I was able to get into the install menu but that was as far as I could get.
Benjamin Franklin
| Posted: Wed Apr 15, 2009 3:31 am Post subject: |
Cool, I'd like to see an honest to goodness $25 000 line tripler
