stridsvognen Guest
| Posted: Fri May 03, 2013 7:00 am Post subject: |
At a time i noticed that there was some points where the old non ultra and the ultra had some differences, specially how they had organised, the cables, and different grounding.
First a Picture of how the cables to the different coils were twisted together on my Ultra, im not sure if it makes any difference, better or worse, but i did separate them like in my non ultra.
I also moved HV leads and coil leads as far apart as possible, mine came with all in one Stack together under the HV leads, right in front of the splitter.
stridsvognen Guest
| Posted: Fri May 03, 2013 7:10 am Post subject: |
Then i put the ground cable on the vertical board like on my non ultra, there is a ground pin in the top right corner of the board, it was not used.
I made the ground cable to the Convergence/ stigmator board.
I removed 2 of the ground cables from the neck boards to the back plate, and grounded the neck boards directly to the chassis.
When testing it was clear that something changed i got more light output on a 5% IRE test pattern.. lokking on the tube while putting ground on off.
Im not sure i have not made any ground loop, but im sure its now grounded, and i think this might work.
| Posted: Fri May 03, 2013 4:21 pm Post subject: |
Yeah I found there was more weird distortions in the image when the convergence and astig cables and VNB cables were all twisted together. I found out it was due to the Astig cables and the noise in them. the ferrite clamps fixed the issues but i still left it all loose.
Also move the HV spliter box up. Flip the plastic cover under it around so the HV splitter is at the top of that pannel and not right next to the VNB. It was a tech bulletin.
Also move that HDM cable bunch to the red away from the Back board. run it over the top of the focus board.
Opps I was wrong, leave it as is. I was wrong it used to come up higher and lowering it fixed it.
stridsvognen Guest
| Posted: Fri May 03, 2013 5:11 pm Post subject: |
Is there anyone that have the diagram, and component list for the Ultra convergence board, it would be a great help to get that one up running.
stridsvognen Guest
| Posted: Fri May 03, 2013 5:18 pm Post subject: |
| Nashou66 wrote: | Oh and the P22 is the 9 inch version of P43 of the 8 inch tube. its the fast persistent Green phosphor for stereoptic use or 3D. So calibration will be all messed up and lower light output. Put Curts new Green in and you'll be good to go.
nashou |
So its good for 3D.?
I had it up around 8-9fl with balanced White level, the problem has mostly been the blooming, think im in controle of that now.
So ill see how goes if i get the convergence board up running.
| Posted: Sat May 04, 2013 3:54 am Post subject: |
| Nashou66 wrote: | Yeah I found there was more weird distortions in the image when the convergence and astig cables and VNB cables were all twisted together. I found out it was due to the Astig cables and the noise in them. the ferrite clamps fixed the issues but i still left it all loose.
Nashou |
stridsvognen Guest
| Posted: Sat May 04, 2013 10:58 am Post subject: |
| Nashou66 wrote: | | Nashou66 wrote: | Yeah I found there was more weird distortions in the image when the convergence and astig cables and VNB cables were all twisted together. I found out it was due to the Astig cables and the noise in them. the ferrite clamps fixed the issues but i still left it all loose.
Nashou |
Opps I was wrong, leave it as is. I was wrong it used to come up higher and lowering it fixed it. |
I found out last night after moving it.
it did tik tik every 10 sec, and i got anoyed.. put it back, and it was gone..
| Posted: Sat May 04, 2013 11:28 am Post subject: |
| stridsvognen wrote: | | Nashou66 wrote: | | Nashou66 wrote: | Yeah I found there was more weird distortions in the image when the convergence and astig cables and VNB cables were all twisted together. I found out it was due to the Astig cables and the noise in them. the ferrite clamps fixed the issues but i still left it all loose.
Nashou |
it did tik tik every 10 sec, and i got anoyed.. put it back, and it was gone..  |
Exactly what are you trying to accomplish...what is the intent or goal in doing all this...are there supposed to be some worthwhile results achieved from doing all of this at the end of the day, weeks or months..?
stridsvognen Guest
| Posted: Sat May 04, 2013 11:43 am Post subject: |
Mike..
The goal is for me to be wiser, and 2nd to improve the image.
I dont know everything, and it all started with the extremely bad focus, and the green gamma run.
Standard i would drop this ULTRA in the bin and be more happy with my JVC, but i have my non ultra, and with different, and much better experience and Picture quality.
Now with all this changing boards, and stuff i now have a idea what i dont want in my ultra.
From extremly fussy focus, i have now seen scanlines on the tube with 1080P 60hz at 5-15% IRE. well then i f*ck*** up and let smoke out of the convergence board, so thats status right now.
So in the ende i hope this CRT will be my favorite projector instead of just putting it in a corner accepting that its not worth looking at.
So when no one can explain me why the resolving power is so bad on this machine, and why the green gamma is f*ck***, i have to find out myself.
I know it dont sound positive to mess up a 800hour 2003 ULTRA, but for me there is nothing to Loose and everything to win.
If it had just performed like my non ultra, or a bit better i would never have touched it.
| Posted: Sat May 04, 2013 12:27 pm Post subject: |
Kurt did you notice where we said the Green tube is the fast phosphor type like the P43. It wont get the same gamma or color calibration as your other machine and those tubes do not focus as well at higher Contrast levels. These were used in simulators that have smaller screens that what you have. So they did not need to be bright.
Lesson learned, if things seem weird check the type of tube first .
| Posted: Sat May 04, 2013 12:33 pm Post subject: |
Playing around with the wires is what I was referring to. Because some things are just best left alone.
If you were playing around in an 1995 or 1997 Marquee, what you have been doing with the wires would make sense. But on the later ones, especially from VDC, there's no need to get that involved with the cables (the HV cables are different and better). You'll not going see or get any real differences, mainly because some of the noise problems that's related to the cables and the chassis design can not be so easily fixed by just moving the cables here and there.
For instance, the HDM emits noise into the neck boards, and if you'll not trying to relocate the HDM away from the CRT neck boards, then going after the miniscule noise that's possibly also coming from the cables would be a waste of time.
There could be some merits in better grounding, but for some reason the neck boards and video chain seem to have no interest in whatever noise could be coming from the cables. Also, once you installed the convergence board ground strap, you solved most correctable problems associated with the cables and grounding. So there's no need to put Band Bides on stitches.
I've gone through all of this using both scopes and spectrum devices. And that's how I arrived at the ground strap fix.
stridsvognen Guest
| Posted: Sat May 04, 2013 12:40 pm Post subject: |
| Nashou66 wrote: | Kurt did you notice where we said the Green tube is the fast phosphor type like the P43. It wont get the same gamma or color calibration as your other machine and those tubes do not focus as well at higher Contrast levels. These were used in simulators that have smaller screens that what you have. So they did not need to be bright.
Nashou |
Yeah, im not hunting that one anymore, well it got visible sharper in the ende, but the way of the gamma i just dont mess with it.. I corected green in the Radiance for now untill i get the new tube.
In time i might like to change it for a LUG tube, to have the option and try that on green, i can see there is some using the PT22 tubes, and they are hard to find.
Ill never buy a Marquee Again without checking the tubes..
stridsvognen Guest
| Posted: Sat May 04, 2013 1:02 pm Post subject: |
| mp20748 wrote: | Playing around with the wires is what I was referring to. Because some things are just best left alone.
I've gone through all of this using both scopes and spectrum devices. And that's how I arrived at the ground strap fix. |
yeah the ground strap was a big improvement, That isue was not on my non ultra, and that noise was the first thing i noticed.
Im sure your right about the cables, like i dident notice any improvement moving them around, but no harm done to.
So for that one i just feel better not having to look at that terrible cable mess, and it hurt my mind mixing 35Kv with low voltage cables.
Putting the ground cables directley on the Neck boards have made changes, and i still miss to find out if thats why i suddently could resolve 1080P 60hz, but i know for sure its only possible with the ultra stigmator convergence and vertical board iinstaled.
Im not sure what board makes the difference, my best bet is the stigmator board.
I now know for sure that the VIM with the trimpots make a very soft image.
| Posted: Sat May 04, 2013 1:28 pm Post subject: |
I now know for sure that the VIM with the trimpots make a very soft image. |
you've posted one of the best kept secrets. We have to now cast you from the forum..
Again, that VIM does very well for graphics and other commercial application, and it can be made to look good on a scope. But in my opinion, It's not good for high resolution HD video.
Dude.. you have a very discerning eye..
| Posted: Sat May 04, 2013 1:41 pm Post subject: |
| mp20748 wrote: | | stridsvognen wrote: |
Dude.. you have a very discerning eye.. |
I found it did 1080p@72 very very well. Like I said before it just takes time to get the Peak circuit dialed in.
Scott design is wrong?
Here is what Craig said
| CIR Engineering wrote: |
This is my biggest complaint with Marquee; that the resolving power varies tremendiously from machine to machine. When I roll up to calibrate a Marqueee I never know what I'm going to get out of it. I just did an 8500 Longbow that had no trouble running full 1080p 72Hz with the contrast at 75. I've had plenty of 9500's that couldn't fully resolve 1080p 60Hz and that would bloom at 60 on the contrast.
It can be frustrating.
craigr |
So for me and Craig we found that it does high resolutions very well.
But each machine is different. Maybe you have just come across those machines that can't.
The Mysteries of the Marquee, it is why I love them!
stridsvognen Guest
| Posted: Sat May 04, 2013 1:48 pm Post subject: |
Ill not accept that i got a machine that cant resolve, there is always a reason. I seen it, it went totaly hardcore 5 min before it smoked. so im exited to get the boards back and find out what did the difference.
It will have to be some specifik board or grounding or stuff that makes the difference, i doubt its just a part of the chassis nr.
| Posted: Sat May 04, 2013 2:27 pm Post subject: |
| Nashou66 wrote: | | mp20748 wrote: | | stridsvognen wrote: |
craigr |
Nashou |
No mysteries at all...
Scott did make the changes, and they were perfect for the application that the VDC Marquee was redesigned and being sold for. But you have to also be mindful, that Scott never indicted that he used his own concept in HT use, nor had ever indicated (from my experience and readings) that he calibrated one of these machines and watched these resolutions on it. All I remember him saying and posting was what he found and implemented in his lab. And what showed up on the scope using test patterns and screen.
I'm sure however, that if Scott was in the redesign mode for HT application and had first hand at home or lab use doing both color calibration and watching of high resolution HD content, he would have experienced the same things I as well as others have experienced. With the most important being that you cannot properly calibrate a stable and solid image with one of those boards in it. And I'm not only talking about the circuit with the pots, there is also the line mod, that has no respect for the low end performance of HD content.
Give a little thought to this line you posted earlier:
| Quote: |
Now if it takes time to get the peak circuit dialed in, then for HD use, every owner operator would need an extender card and scope to stabilize the colors.....but besides that, how do you get around the elevated pedestal that literally removes all possibility of getting the proper low end performance for HD content?
stridsvognen Guest
| Posted: Sat May 04, 2013 3:12 pm Post subject: |
I was looking for the mentioned thread about how to change a stigmator board into a ultra board, i would like to add those vima caps on my non ultra board to see if it will make a improvement.
