| Posted: Fri Jun 21, 2013 10:33 am Post subject: |
| stridsvognen wrote: |
I also removed the cables going from the shields on the tube to the neck boards, and put them directly to chassis.
I cant see any reason to ground them true to the neck boards.
Ill see if i get any problems later... Worked fine last night.. |
I don't think that was a good idea, It's all about ground loops, or grounding resistance, I think it is even mentioned in the service manual that these ground taps must have connected to the neck boards the way they were intended.
stridsvognen Guest
| Posted: Fri Jun 21, 2013 10:41 am Post subject: |
| gjaky wrote: | | stridsvognen wrote: |
I don't think that was a good idea, It's all about ground loops, or grounding resistance, I think it is even mentioned in the service manual that these ground taps must have connected to the neck boards the way they were intended. |
Well if you look in the service manual, i think they would tell us all to keep hands out and not change anything..
It looks more to me like the marquee is born with plenty of ground loops. im actualy trying to remove some of them.
| Posted: Fri Jun 21, 2013 10:45 am Post subject: |
No comment.
| Description: |
| Filesize: |
24.81 KB |
| Viewed: |
4032 Time(s) |
stridsvognen Guest
| Posted: Fri Jun 21, 2013 10:59 am Post subject: |
so the arc are going from the neck board, and to the aquadag.?
| Posted: Fri Jun 21, 2013 4:44 pm Post subject: |
| stridsvognen wrote: | | so the arc are going from the neck board, and to the aquadag.? |
no, the surge protectors are the round things holding up the ground connector plate on the VNB. you need to connect it!!! Don't blow up your HDM or FGM by not connecting them. And for better grounding add two more aquadags tot he extra two connectors on the VNB.
| Posted: Fri Jun 21, 2013 5:06 pm Post subject: |
Guys
When the Marquees first rolled out in late 1992 the dealers were very excited. We installed the first twenty M8000s in three months, then the problems began. Streaks in the video or just dead tubes. Electrohome sent us dozens of neckboards to change out but those failed too. They halted all shipments of projectors for a month and spared no effort to identify the cause of the failures. Tube arcs were suspect, but how do you make tubes arc on demand to study the problem? The answer was lasers! They brought in some consultants, and they looked at things and returned shortly with some gear. By shooting the electron guns with lasers they got a tiny poof of vaporized metal, and they got an arc nearly every time. They identified the need to add diodes in certain points on the neckboards, and the next batch of neckboards had extra stuff tacked on everywhere. Those were not pretty boards but they held under arc, and foil layouts were redone to incorporate the diodes onto the boards.
stridsvognen Guest
| Posted: Fri Jun 21, 2013 7:40 pm Post subject: |
| Nashou66 wrote: | | stridsvognen wrote: | | so the arc are going from the neck board, and to the aquadag.? |
Athanasios |
I need better understanding of this, Why are those aquadag caled grounding, are they leading a arc to or from the tube bell.?
The neck board is grounded to the VIM true the coax cable, and from the motherboard right ?, and then 2 conections to the shield around the neck board and from there to the rear heat sink with those fly wires, and its conected to chassis true the HDM and FGM boxes.
I would think that would make a nice potential ground loop.. looks to me the neck board is grounded 3 Places, that i guess all endes to chassis somewhere.. Or am i wrong.?
| Posted: Fri Jun 21, 2013 7:58 pm Post subject: |
Probably Scott (tse) is the only one here who could give the most statisfactory answer.
Read here:
http://en.wikipedia.org/wiki/Aquadag
The driving of the tube is referenced to the ground that is on the VNB, so connecting the aquadag there would be the best solution, if you connect it somewhere else that means if any current flows there it elevates the ground of the VNB through its ground resistance.
In a CRT projector the ground loop is not that bad as is an audio amplifiers because of it's more complex structure, eg. focus and convergence have no real effect on each other, so the ground loop neither affects their function. But good surge protection is crucial, as everything near to the tube is endangered of high voltage arcs.
stridsvognen Guest
| Posted: Fri Jun 21, 2013 8:04 pm Post subject: |
The hole crazy idea trying something new is that i see both my Marquee have some crosstalk betwen colors, anyone try put up a 100% IRE window on green tube and look into blue and red and tell me whats going on there.
Also try look the blue and red when it writes no sync on the screen.
| Posted: Sat Jun 22, 2013 1:04 am Post subject: |
Kurt the static build up on the Tube is very high and the best place to remove that ground was on the VNB surge arrestors since the tube and VNB are sort of a closed system.
Now I have noticed the raster light up on all tubes when for instance onl;y showing the Green grid etc.
I have been wondering about it for some time. I used to think it was the HVPS G2 resitors. I had to use a higher resistor on one HVPS and it corrected the issue. Then I noticed it from a certain CLM I had. If i moved it from PJ to PJ the issue followed.
So I think it might be the G2 section on the CLM but not sure. It is all on one chip, a quad op amp. I am wondering if a better chip there might help.
But this is all theory.
stridsvognen Guest
| Posted: Sat Jun 22, 2013 1:18 am Post subject: |
I actualy noticed changes when changing the G2 resistor in the HVPS to, so im sure it can be some sort of noise traveling true the G2 conections.
The thing is that its mostly visible on the right and left side of high level stuff. Put the green 100% IRE test window from your radiance, and i think you will see 2 vertical lines one on left and on another on right side of the window.
I cant pin it on any of my 3 different CLM.
I moved the aquadag cables back on the neck board, and im sure i liked the image better before, it was sharper and had more low level details.
| Posted: Sat Jun 22, 2013 1:23 am Post subject: |
| stridsvognen wrote: | I actualy noticed changes when changing the G2 resistor in the HVPS to, so im sure it can be some sort of noise traveling true the G2 conections.
The thing is that its mostly visibleon on the right and left side of high level stuff. Put the green 100% IRE test window from your radiance, and i think you will see 2 vertical lines one on left and on another on right side of the window.
I moved the aquadag cables back on the neck board, and im sure i liked the image better before, it was sharper and had more low level details. |
That is the radiance doing it. MY HDQ does not add the lines on the edge. I just use blanking, it is only one pixel line.
stridsvognen Guest
| Posted: Sat Jun 22, 2013 1:32 am Post subject: |
| Nashou66 wrote: | | stridsvognen wrote: | I actualy noticed changes when changing the G2 resistor in the HVPS to, so im sure it can be some sort of noise traveling true the G2 conections.
Athanasios |
Its there with the NO SYNC text on green tube with no signal, you can see that on red and blue to.
And my Picture will be quite small if i have to blank the borders of the small test window..
You have 3 different size Windows on the radiance.. full screen medium and small, i use the medium size when measure colors and gray scale.
But if it is anything to do with the radiance we have to make Jim to take a look at it.
