New 04/2013 Radiance firmware
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products
Corleone88
Posted: Fri Apr 12, 2013 6:46 pm    Post subject:
CIR Engineering wrote:
I'll try 1080i 96Hz later if you want me to? I suspect it works fine now as when Pat says something is fixed 99.9999999% of the time he nailed the problem and it is fixed. He is a very thorough engineer.
Still does not work Sad. Either I have a faulty unit or there is something in the timings different from the HDQ that the Barco doesn't like.
I don't have Excel, so is it possible to get the timings values for 1080i@96, please?
I am also not able to get a stable picture with the oppo pluged whatever resolution I have on the XD. I did a factory reset on the XD and I have now this new issue.
Thanks for the help
Corleone88
Posted: Fri Apr 12, 2013 7:04 pm    Post subject:
I also tried the predefined resolutions. 720p@120 works fine for example.
Posted: Fri Apr 12, 2013 8:40 pm    Post subject:
Firstly, I lead you guys a little wrong with the timings... I haven't thought in terms of interlaced in a while. My spreadsheet for clock calculation will not quite get you the correct clock with interlaced resolutions. What you need to do instead is just copy my timings from the photos above, or use this formula for interlaced.
Fc = [Vt * Ht * (72/1.001)] / 2
Where
Fc = the clock rate
Vt = Vertical total pixels
Ht = Horizontal total pixels
With standard 1080i timings just change the clock to 89010989 Hz to get an output of 1080i 71.93 Hz.
I tested 1080i 96 Hz but it did not work. The Radiance reported 96 Hz, but the projector did not.
Corleone88
Posted: Fri Apr 12, 2013 9:43 pm    Post subject:
Thanks a lot Craig for all your explanations and screen captures., but I give up because it still doesn't work even by putting the exact same values as yours.
I will keep my HDQ (unfortunately) to get the 1080i@96.
There will still be a mystery to me that the HDQ can give me 1080i@96 when my XD Radiance cannot.
Tomorrow I will do a last test with my Pionner TV instead of the BG808.
Posted: Fri Apr 12, 2013 10:55 pm    Post subject:
1080i 96Hz does not work. The timings and screen shots are for 1080i 72Hz.
AVphile
Posted: Sat Apr 13, 2013 12:29 am    Post subject:
the equation is:
562 x 2200 x (72/1.001) = 88931868
All you have to do is go into the Radiance modes menu and select 1080i 60Hz. The projector will then switch to 1080i 59.94Hz. Go into the timings menu for the 1080i that you just set up. Set the clock to 88931868. Select "test" and the projector will switch to 1080i 72Hz.
Done and it doesn't work for me either.
First thing I notice, like I said before, the Radiance Vrate calcualtion is a bit off. Entering the above numbers results in 71.86 Hz instead of 71.93 Hz.
Where did you get the number 89010989 in your screen shot? That one results in the desired Vrate at least, but the Radiance still only outputs 60 Hz.
AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
Posted: Sat Apr 13, 2013 12:31 am    Post subject:
the equation is:
As you can see in my screen shots, both the Radiance and the G90 are reporting 72Hz.
Posted: Sat Apr 13, 2013 12:32 am    Post subject:
the equation is:
Are you sure you are displaying the mode that you are adjusting. If you are using the 72Hz mode (the one with the * next to it) than it has to work.
AVphile
Posted: Sat Apr 13, 2013 12:36 am    Post subject:
It doesn't work with the Radiance Mini either. I suspect it works for craigr because he has an XE+
I believe there is a software limit preventing 72Hz with 1920x1080 resolution in the non + models. It should only restrict 1080p72 but I am guessing Patrick forgot to lift the restriction for interlaced formats.
Posted: Sat Apr 13, 2013 12:39 am    Post subject:
No.
You can run 818x1920 72Hz from the standard modes menu without the PLUS option. Why don't you give that mode a try and see what you get?
AVphile
Posted: Sat Apr 13, 2013 2:51 am    Post subject:
If I select that mode or any other non-60Hz mode, then switch to the new 1080i 72Hz mode I get what looks like 1080i 60Hz (not sure how to tell for sure) along with a bizarre status indication like Fh=31.7k, Fv=56 (it varies) on the Barco. If I switch to the 1080i 72Hz mode from a 60Hz mode I get what looks like 1080i 60Hz along with the usual indication (Fh=33.8k, Fv=60). It seems to be trying to keep the refresh rate of the previous mode.
I saw the same behavior before the firmware update.
Posted: Sat Apr 13, 2013 4:12 am    Post subject:
It doesn't sound like you are following the basic instructions.
You must start with 1080i (interlaced) 60Hz. Select that first. Then go into the timings menu for 1080i 60Hz and change the clock to 89010989. Then you will have 1080i 72Hz.
I want to know though, if you select 818x1920 72Hz from the modes menu does your projector display 818x1920 72Hz? I think you will find that you can display 72Hz just fine.
The difficult part is the interlaced, not the refresh rate. The Radiance can only do interlaced with 1080 and at 60Hz and 72Hz.
However, any progressive mode will work at 72Hz including 720p 72Hz, 818p 72Hz, or whatever. The Radiance doesn't care what the refresh rate is on the PLUS or nonPLUS units. The nonPLUS are locked to the clock rate, not the refresh rate.
Understand?
AVphile
Posted: Sat Apr 13, 2013 4:43 am    Post subject:
Yes, I am past that now. I was talking about other custom modes I have already been using including 1080p48, 900p72 and 817p72 which all work as expected. Then I am switching from one of those, or even a standard HDTV mode, to the already CORRECTLY programmed 1080i 72Hz. I am not going back in the Custom Modes Timing menu. My only point was that the outcome on the Barco seems to vary depending on which of the other custom modes I transition from. In any case the status either changes to nonsense values or stays at 60Hz.
The indication on the Radiance however, is the same as yours "1080i 71.93Hz" regardless how I get there.
We had this discussion before about hardware vs. Software limits in the non+ Radiance models. I don't remember exactly the outcome but there was some doubt I thought. I wouldn't be surprised if the software is limiting output in some way based on a combination of factors, which increases possibility for a bug.
Corleone88
Posted: Sat Apr 13, 2013 10:16 am    Post subject:
Craig,
I can display 72, 96 even 120Hz correctly with my XD on my BG808 but only with progressive signal (720p in my case). The problem is on interlaced mode.
Anyway, I tried on my PC monitor and I have the same result as on the Barco ie 33.7KHz 60Hz (1080i@60) whatever interlaced signal I put on the Lumagen (1080i@72 or 1080i@96).
It seems that there is something wrong with my XD.
I don't know if it is related, but after I installed the last firmware some of Custom Mode labels have strange values. For example, instead of having Custom Mode0, I have BAR80i or BAR80p for Custom Mode7. If I do a factory reset, I have sync problems (with any input signal) on the BG808.
I'll email Patrick with my results.
AVphile
Posted: Sat Apr 13, 2013 1:14 pm    Post subject:
That's weird about the labels!
What are you using for a video DAC, HDFury?
AVStefan
Corleone88
Posted: Sat Apr 13, 2013 1:36 pm    Post subject:
Greg Eisemann's HDMI input card
AVphile
Posted: Sat Apr 13, 2013 1:51 pm    Post subject: new Radiance firmware
Test repeated with 040513 - still no go.
Email sent to Jim and support@lumagen.
Posted: Sat Apr 13, 2013 1:57 pm    Post subject:
I talked to Patrick again and he may add 1080i 72Hz to the default output modes so that you guys can just select it instead of creating it. He says he will also look at 1080i 96Hz and if it's any easy fix he will make it.
OK got it. I find it hard to believe / understand, but I understand what you are saying now.
Corleone88 wrote:
Craig,
I think you have done so much stuff with the Radiance that you may have managed to get it confused somehow. Also, autocal can sometimes cause issues. I think you need to do a service level reset (service menu then "menu-0-9-9-9") and then save. I think your configuration is hosed.
What were your custom mode labels before the last update? I don't think the Radiance would have magically created mode names that look like Barcoi and Barcop all on its own. What did you call them?
Can you guys email me your config files. I will look at them and see if they run 1080i 72Hz for me here.
Corleone88
Posted: Sat Apr 13, 2013 2:11 pm    Post subject:
Craig, believe me or not, I never changed the custom mode names. I don't even know it was possible Wink. All I did on my XD is calibration (auto-cal and manual) and chage of resolution.
I'll try your service level reset and I'll send you my config. file
Posted: Sat Apr 13, 2013 2:16 pm    Post subject:
Please you two, send me your config files!!!
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products All times are GMT
Page 2 of 5
